USRP Hardware Driver and USRP Manual  Version: 4.6.0.0-7-gece7c4811
#include <uhd/usrp/dboard_id.hpp>
 dboard_id_t (uint16_t id=0xffff)
uint16_t to_uint16 (void) const
static dboard_id_t from_uint16 (uint16_t uint16)
◆ dboard_id_t()
uhd::usrp::dboard_id_t::dboard_id_t ( uint16_t  id = 0xffff)
idthe integer representation
◆ from_string()
◆ from_uint16()
static dboard_id_t uhd::usrp::dboard_id_t::from_uint16 ( uint16_t  uint16)
◆ none()
◆ to_cname()
◆ to_pp_string()
◆ to_string()
◆ to_uint16()
uint16_t uhd::usrp::dboard_id_t::to_uint16 ( void  ) const
