USRP Hardware Driver and USRP Manual  Version: 4.6.0.0-7-gece7c4811
uhd::usrp::subdev_spec_t Class Reference
Inheritance diagram for uhd::usrp::subdev_spec_t:
 subdev_spec_t (const std::string &markup="")
◆ subdev_spec_t()
uhd::usrp::subdev_spec_t::subdev_spec_t ( const std::string &  markup = "")
markupthe markup string
◆ to_pp_string()
std::string uhd::usrp::subdev_spec_t::to_pp_string ( void  ) const
a printable string representing the subdev specification
◆ to_string()
std::string uhd::usrp::subdev_spec_t::to_string ( void  ) const
