USRP Hardware Driver and USRP Manual  Version: 4.6.0.0-7-gece7c4811
multi_usrp.hpp
2 // Copyright 2010-2012,2014-2015 Ettus Research LLC
4 //
6 //
7
8 #pragma once
9
10 // define API capabilities for compile time detection of new features
11 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API
12 #define UHD_USRP_MULTI_USRP_GET_RATES_API
13 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
14 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API
15 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
16 #define UHD_USRP_MULTI_USRP_BW_RANGE_API
17 #define UHD_USRP_MULTI_USRP_USER_REGS_API
18 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
19 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN
20 #define UHD_USRP_MULTI_USRP_GPIO_API
21 #define UHD_USRP_MULTI_USRP_REGISTER_API
22 #define UHD_USRP_MULTI_USRP_FILTER_API
23 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API
24 #define UHD_USRP_MULTI_USRP_TX_LO_CONFIG_API
25 #define UHD_USRP_MULTI_USRP_POWER_LEVEL
26
27 #include <uhd/config.hpp>
28 #include <uhd/device.hpp>
32 #include <uhd/types/filters.hpp>
33 #include <uhd/types/ranges.hpp>
34 #include <uhd/types/sensors.hpp>
35 #include <uhd/types/stream_cmd.hpp>
38 #include <uhd/types/wb_iface.hpp>
40 #include <uhd/usrp/subdev_spec.hpp>
42 #include <complex>
43 #include <memory>
44 #include <string>
45 #include <vector>
46
47 namespace uhd { namespace usrp {
48
96 {
97 public:
98  typedef std::shared_ptr<multi_usrp> sptr;
99
100  virtual ~multi_usrp(void) = 0;
101
103  static const size_t ALL_MBOARDS;
104
106  static const size_t ALL_CHANS;
107
109  static const std::string ALL_GAINS;
110
112  static const std::string ALL_LOS;
113
121  static sptr make(const device_addr_t& dev_addr);
122
137  virtual device::sptr get_device(void) = 0;
138
141  virtual uhd::property_tree::sptr get_tree(void) const = 0;
142
144  virtual rx_streamer::sptr get_rx_stream(const stream_args_t& args) = 0;
145
147  virtual tx_streamer::sptr get_tx_stream(const stream_args_t& args) = 0;
148
156  virtual dict<std::string, std::string> get_usrp_rx_info(size_t chan = 0) = 0;
157
165  virtual dict<std::string, std::string> get_usrp_tx_info(size_t chan = 0) = 0;
166
167  /*******************************************************************
168  * Mboard methods
169  ******************************************************************/
170
193  virtual void set_master_clock_rate(double rate, size_t mboard = ALL_MBOARDS) = 0;
194
200  virtual double get_master_clock_rate(size_t mboard = 0) = 0;
201
220  virtual meta_range_t get_master_clock_rate_range(const size_t mboard = 0) = 0;
221
226  virtual std::string get_pp_string(void) = 0;
227
233  virtual std::string get_mboard_name(size_t mboard = 0) = 0;
234
245  virtual time_spec_t get_time_now(size_t mboard = 0) = 0;
246
257  virtual time_spec_t get_time_last_pps(size_t mboard = 0) = 0;
258
268  virtual void set_time_now(
269  const time_spec_t& time_spec, size_t mboard = ALL_MBOARDS) = 0;
270
294  virtual void set_time_next_pps(
295  const time_spec_t& time_spec, size_t mboard = ALL_MBOARDS) = 0;
296
312  virtual void set_time_unknown_pps(const time_spec_t& time_spec) = 0;
313
320  virtual bool get_time_synchronized(void) = 0;
321
332  virtual void set_command_time(
333  const uhd::time_spec_t& time_spec, size_t mboard = ALL_MBOARDS) = 0;
334
340  virtual void clear_command_time(size_t mboard = ALL_MBOARDS) = 0;
341
354  virtual void issue_stream_cmd(
355  const stream_cmd_t& stream_cmd, size_t chan = ALL_CHANS) = 0;
356
399  virtual void set_time_source(
400  const std::string& source, const size_t mboard = ALL_MBOARDS) = 0;
401
407  virtual std::string get_time_source(const size_t mboard) = 0;
408
414  virtual std::vector<std::string> get_time_sources(const size_t mboard) = 0;
415
458  virtual void set_clock_source(
459  const std::string& source, const size_t mboard = ALL_MBOARDS) = 0;
460
466  virtual std::string get_clock_source(const size_t mboard) = 0;
467
473  virtual std::vector<std::string> get_clock_sources(const size_t mboard) = 0;
474
485  virtual void set_sync_source(const std::string& clock_source,
486  const std::string& time_source,
487  const size_t mboard = ALL_MBOARDS) = 0;
488
511  virtual void set_sync_source(
512  const device_addr_t& sync_source, const size_t mboard = ALL_MBOARDS) = 0;
513
519  virtual device_addr_t get_sync_source(const size_t mboard) = 0;
520
526  virtual std::vector<device_addr_t> get_sync_sources(const size_t mboard) = 0;
527
542  virtual void set_clock_source_out(
543  const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
544
559  virtual void set_time_source_out(
560  const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
561
565  virtual size_t get_num_mboards(void) = 0;
566
573  virtual sensor_value_t get_mboard_sensor(
574  const std::string& name, size_t mboard = 0) = 0;
575
581  virtual std::vector<std::string> get_mboard_sensor_names(size_t mboard = 0) = 0;
582
592  virtual void set_user_register(
593  const uint8_t addr, const uint32_t data, size_t mboard = ALL_MBOARDS) = 0;
594
619  virtual uhd::wb_iface::sptr get_user_settings_iface(const size_t chan = 0) = 0;
620
638  virtual uhd::rfnoc::radio_control& get_radio_control(const size_t chan = 0) = 0;
639
647  virtual uhd::extension::extension::sptr get_extension(
648  const direction_t trx, const size_t chan) = 0;
649
659  template <typename T>
660  typename T::sptr get_extension(const direction_t trx, const size_t chan)
661  {
662  return std::dynamic_pointer_cast<T>(get_extension(trx, chan));
663  }
664
665  /*******************************************************************
666  * RX methods
667  ******************************************************************/
678  virtual void set_rx_subdev_spec(
679  const uhd::usrp::subdev_spec_t& spec, size_t mboard = ALL_MBOARDS) = 0;
680
686  virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard = 0) = 0;
687
693  virtual size_t get_rx_num_channels(void) = 0;
694
700  virtual std::string get_rx_subdev_name(size_t chan = 0) = 0;
701
711  virtual void set_rx_rate(double rate, size_t chan = ALL_CHANS) = 0;
712
722  virtual void set_rx_spp(const size_t spp, const size_t chan = ALL_CHANS) = 0;
723
729  virtual double get_rx_rate(size_t chan = 0) = 0;
730
736  virtual meta_range_t get_rx_rates(size_t chan = 0) = 0;
737
748  virtual tune_result_t set_rx_freq(
749  const tune_request_t& tune_request, size_t chan = 0) = 0;
750
756  virtual double get_rx_freq(size_t chan = 0) = 0;
757
767  virtual freq_range_t get_rx_freq_range(size_t chan = 0) = 0;
768
774  virtual freq_range_t get_fe_rx_freq_range(size_t chan = 0) = 0;
775
776  /**************************************************************************
777  * LO controls
778  *************************************************************************/
792  virtual std::vector<std::string> get_rx_lo_names(size_t chan = 0) = 0;
793
812  virtual void set_rx_lo_source(
813  const std::string& src, const std::string& name = ALL_LOS, size_t chan = 0) = 0;
814
823  virtual const std::string get_rx_lo_source(
824  const std::string& name = ALL_LOS, size_t chan = 0) = 0;
825
838  virtual std::vector<std::string> get_rx_lo_sources(
839  const std::string& name = ALL_LOS, size_t chan = 0) = 0;
840
851  virtual void set_rx_lo_export_enabled(
852  bool enabled, const std::string& name = ALL_LOS, size_t chan = 0) = 0;
853
859  virtual bool get_rx_lo_export_enabled(
860  const std::string& name = ALL_LOS, size_t chan = 0) = 0;
861
886  virtual double set_rx_lo_freq(
887  double freq, const std::string& name, size_t chan = 0) = 0;
888
899  virtual double get_rx_lo_freq(const std::string& name, size_t chan = 0) = 0;
900
910  virtual freq_range_t get_rx_lo_freq_range(
911  const std::string& name, size_t chan = 0) = 0;
912
925  virtual std::vector<std::string> get_tx_lo_names(size_t chan = 0) = 0;
926
942  virtual void set_tx_lo_source(const std::string& src,
943  const std::string& name = ALL_LOS,
944  const size_t chan = 0) = 0;
945
954  virtual const std::string get_tx_lo_source(
955  const std::string& name = ALL_LOS, const size_t chan = 0) = 0;
956
967  virtual std::vector<std::string> get_tx_lo_sources(
968  const std::string& name = ALL_LOS, const size_t chan = 0) = 0;
969
980  virtual void set_tx_lo_export_enabled(
981  const bool enabled, const std::string& name = ALL_LOS, const size_t chan = 0) = 0;
982
988  virtual bool get_tx_lo_export_enabled(
989  const std::string& name = ALL_LOS, const size_t chan = 0) = 0;
990
1015  virtual double set_tx_lo_freq(
1016  const double freq, const std::string& name, const size_t chan = 0) = 0;
1017
1028  virtual double get_tx_lo_freq(const std::string& name, const size_t chan = 0) = 0;
1029
1039  virtual freq_range_t get_tx_lo_freq_range(
1040  const std::string& name, const size_t chan = 0) = 0;
1041
1042  /**************************************************************************
1043  * Gain controls
1044  *************************************************************************/
1058  virtual void set_rx_gain(double gain, const std::string& name, size_t chan = 0) = 0;
1059
1072  virtual std::vector<std::string> get_rx_gain_profile_names(const size_t chan = 0) = 0;
1073
1082  virtual void set_rx_gain_profile(
1083  const std::string& profile, const size_t chan = 0) = 0;
1084
1090  virtual std::string get_rx_gain_profile(const size_t chan = 0) = 0;
1091
1093  void set_rx_gain(double gain, size_t chan = 0)
1094  {
1095  return this->set_rx_gain(gain, ALL_GAINS, chan);
1096  }
1097
1115  virtual void set_normalized_rx_gain(double gain, size_t chan = 0) = 0;
1116
1134  virtual void set_rx_agc(bool enable, size_t chan = 0) = 0;
1135
1143  virtual double get_rx_gain(const std::string& name, size_t chan = 0) = 0;
1144
1146  double get_rx_gain(size_t chan = 0)
1147  {
1148  return this->get_rx_gain(ALL_GAINS, chan);
1149  }
1150
1161  virtual double get_normalized_rx_gain(size_t chan = 0) = 0;
1162
1170  virtual gain_range_t get_rx_gain_range(const std::string& name, size_t chan = 0) = 0;
1171
1174  {
1175  return this->get_rx_gain_range(ALL_GAINS, chan);
1176  }
1177
1184  virtual std::vector<std::string> get_rx_gain_names(size_t chan = 0) = 0;
1185
1194  virtual void set_rx_antenna(const std::string& ant, size_t chan = 0) = 0;
1195
1201  virtual std::string get_rx_antenna(size_t chan = 0) = 0;
1202
1208  virtual std::vector<std::string> get_rx_antennas(size_t chan = 0) = 0;
1209
1219  virtual void set_rx_bandwidth(double bandwidth, size_t chan = 0) = 0;
1220
1226  virtual double get_rx_bandwidth(size_t chan = 0) = 0;
1227
1233  virtual meta_range_t get_rx_bandwidth_range(size_t chan = 0) = 0;
1234
1242  virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan = 0) = 0;
1243
1250  virtual sensor_value_t get_rx_sensor(const std::string& name, size_t chan = 0) = 0;
1251
1257  virtual std::vector<std::string> get_rx_sensor_names(size_t chan = 0) = 0;
1258
1271  virtual void set_rx_dc_offset(const bool enb, size_t chan = ALL_CHANS) = 0;
1272
1280  virtual void set_rx_dc_offset(
1281  const std::complex<double>& offset, size_t chan = ALL_CHANS) = 0;
1282
1287  virtual meta_range_t get_rx_dc_offset_range(size_t chan = 0) = 0;
1288
1295  virtual void set_rx_iq_balance(const bool enb, size_t chan) = 0;
1296
1304  virtual void set_rx_iq_balance(
1305  const std::complex<double>& correction, size_t chan = ALL_CHANS) = 0;
1306
1307
1308  /**************************************************************************
1309  * Power level controls
1310  *************************************************************************/
1327  virtual bool has_rx_power_reference(const size_t chan = 0) = 0;
1328
1343  virtual void set_rx_power_reference(
1344  const double power_dbm, const size_t chan = 0) = 0;
1345
1358  virtual double get_rx_power_reference(const size_t chan = 0) = 0;
1359
1369  virtual meta_range_t get_rx_power_range(const size_t chan) = 0;
1370
1371  /*******************************************************************
1372  * TX methods
1373  ******************************************************************/
1383  virtual void set_tx_subdev_spec(
1384  const uhd::usrp::subdev_spec_t& spec, size_t mboard = ALL_MBOARDS) = 0;
1385
1391  virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard = 0) = 0;
1392
1398  virtual size_t get_tx_num_channels(void) = 0;
1399
1405  virtual std::string get_tx_subdev_name(size_t chan = 0) = 0;
1406
1416  virtual void set_tx_rate(double rate, size_t chan = ALL_CHANS) = 0;
1417
1423  virtual double get_tx_rate(size_t chan = 0) = 0;
1424
1430  virtual meta_range_t get_tx_rates(size_t chan = 0) = 0;
1431
1442  virtual tune_result_t set_tx_freq(
1443  const tune_request_t& tune_request, size_t chan = 0) = 0;
1444
1450  virtual double get_tx_freq(size_t chan = 0) = 0;
1451
1461  virtual freq_range_t get_tx_freq_range(size_t chan = 0) = 0;
1462
1468  virtual freq_range_t get_fe_tx_freq_range(size_t chan = 0) = 0;
1469
1483  virtual void set_tx_gain(double gain, const std::string& name, size_t chan = 0) = 0;
1484
1497  virtual std::vector<std::string> get_tx_gain_profile_names(const size_t chan = 0) = 0;
1498
1507  virtual void set_tx_gain_profile(
1508  const std::string& profile, const size_t chan = 0) = 0;
1509
1515  virtual std::string get_tx_gain_profile(const size_t chan = 0) = 0;
1516
1518  void set_tx_gain(double gain, size_t chan = 0)
1519  {
1520  return this->set_tx_gain(gain, ALL_GAINS, chan);
1521  }
1522
1535  virtual void set_normalized_tx_gain(double gain, size_t chan = 0) = 0;
1536
1544  virtual double get_tx_gain(const std::string& name, size_t chan = 0) = 0;
1545
1547  double get_tx_gain(size_t chan = 0)
1548  {
1549  return this->get_tx_gain(ALL_GAINS, chan);
1550  }
1551
1562  virtual double get_normalized_tx_gain(size_t chan = 0) = 0;
1563
1571  virtual gain_range_t get_tx_gain_range(const std::string& name, size_t chan = 0) = 0;
1572
1575  {
1576  return this->get_tx_gain_range(ALL_GAINS, chan);
1577  }
1578
1585  virtual std::vector<std::string> get_tx_gain_names(size_t chan = 0) = 0;
1586
1587  /**************************************************************************
1588  * Power level controls
1589  *************************************************************************/
1606  virtual bool has_tx_power_reference(const size_t chan = 0) = 0;
1607
1622  virtual void set_tx_power_reference(
1623  const double power_dbm, const size_t chan = 0) = 0;
1624
1637  virtual double get_tx_power_reference(const size_t chan = 0) = 0;
1638
1648  virtual meta_range_t get_tx_power_range(const size_t chan) = 0;
1649
1658  virtual void set_tx_antenna(const std::string& ant, size_t chan = 0) = 0;
1659
1665  virtual std::string get_tx_antenna(size_t chan = 0) = 0;
1666
1672  virtual std::vector<std::string> get_tx_antennas(size_t chan = 0) = 0;
1673
1683  virtual void set_tx_bandwidth(double bandwidth, size_t chan = 0) = 0;
1684
1690  virtual double get_tx_bandwidth(size_t chan = 0) = 0;
1691
1697  virtual meta_range_t get_tx_bandwidth_range(size_t chan = 0) = 0;
1698
1706  virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan = 0) = 0;
1707
1714  virtual sensor_value_t get_tx_sensor(const std::string& name, size_t chan = 0) = 0;
1715
1721  virtual std::vector<std::string> get_tx_sensor_names(size_t chan = 0) = 0;
1722
1729  virtual void set_tx_dc_offset(
1730  const std::complex<double>& offset, size_t chan = ALL_CHANS) = 0;
1731
1736  virtual meta_range_t get_tx_dc_offset_range(size_t chan = 0) = 0;
1737
1745  virtual void set_tx_iq_balance(
1746  const std::complex<double>& correction, size_t chan = ALL_CHANS) = 0;
1747
1748  /*******************************************************************
1749  * GPIO methods
1750  ******************************************************************/
1751
1757  virtual std::vector<std::string> get_gpio_banks(const size_t mboard) = 0;
1758
1811  virtual void set_gpio_attr(const std::string& bank,
1812  const std::string& attr,
1813  const uint32_t value,
1814  const uint32_t mask = 0xffffffff,
1815  const size_t mboard = 0) = 0;
1816
1836  virtual uint32_t get_gpio_attr(
1837  const std::string& bank, const std::string& attr, const size_t mboard = 0) = 0;
1838
1855  virtual std::vector<std::string> get_gpio_src_banks(const size_t mboard = 0) = 0;
1856
1867  virtual std::vector<std::string> get_gpio_srcs(
1868  const std::string& bank, const size_t mboard = 0) = 0;
1869
1879  virtual std::vector<std::string> get_gpio_src(
1880  const std::string& bank, const size_t mboard = 0) = 0;
1881
1896  virtual void set_gpio_src(const std::string& bank,
1897  const std::vector<std::string>& src,
1898  const size_t mboard = 0) = 0;
1899
1900  /*******************************************************************
1901  * Filter API methods
1902  ******************************************************************/
1903  // TODO: This should be a const function, but I don't want to wrestle with the
1904  // compiler right now
1912  virtual std::vector<std::string> get_rx_filter_names(const size_t chan) = 0;
1913
1920  virtual uhd::filter_info_base::sptr get_rx_filter(
1921  const std::string& name, const size_t chan) = 0;
1922
1930  virtual void set_rx_filter(const std::string& name,
1932  const size_t chan) = 0;
1933
1934  // TODO: This should be a const function, but I don't want to wrestle with the
1935  // compiler right now
1943  virtual std::vector<std::string> get_tx_filter_names(const size_t chan) = 0;
1944
1951  virtual uhd::filter_info_base::sptr get_tx_filter(
1952  const std::string& name, const size_t chan) = 0;
1953
1961  virtual void set_tx_filter(const std::string& name,
1963  const size_t chan) = 0;
1964
1982  virtual uhd::rfnoc::mb_controller& get_mb_controller(const size_t mboard = 0) = 0;
1983 };
1984
1985 }} // namespace uhd::usrp
Definition: stream.hpp:169
Definition: multi_usrp.hpp:1173
Definition: multi_usrp.hpp:660
Definition: stream_cmd.hpp:39
Definition: tune_result.hpp:18
Definition: multi_usrp.hpp:1547
Definition: multi_usrp.hpp:1518
Definition: mb_controller.hpp:25
Definition: time_spec.hpp:28
A wildcard motherboard index.
Definition: multi_usrp.hpp:103
std::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:98
std::shared_ptr< device > sptr
Definition: device.hpp:29
Definition: multi_usrp.hpp:1146
Definition: tune_request.hpp:24
A wildcard gain element name.
Definition: multi_usrp.hpp:109
Definition: build_info.hpp:12
Definition: sensors.hpp:28
Definition: multi_usrp.hpp:95
source
Identify the source of calibration data, i.e., where was it stored.
Definition: database.hpp:23
std::shared_ptr< dboard_iface > sptr
Definition: dboard_iface.hpp:55
direction_t
Definition: direction.hpp:12
Definition: stream.hpp:47
std::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:26
Definition: config.h:87
Definition: soft_register.hpp:86
Definition: multi_usrp.hpp:1093
A wildcard LO stage name.
Definition: multi_usrp.hpp:112
Definition: radio_control.hpp:101
Definition: subdev_spec.hpp:59
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:267
Definition: ranges.hpp:65
std::shared_ptr< wb_iface > sptr
Definition: wb_iface.hpp:20
Definition: property_tree.hpp:223
A wildcard channel index.
Definition: multi_usrp.hpp:106
Definition: multi_usrp.hpp:1574
std::shared_ptr< extension > sptr
Definition: extension.hpp:38
Definition: device_addr.hpp:37
