# Protocase Designer Configuration
Assembly:
  designer: 4.4.1
  QuotedUnits: MM
  DesignID: 1U Extruded Aluminum Type A Template
  name: 1U Extruded Aluminum Type A
  version: 7.2
  description: |-
    1U Enclosure with extruded aluminum sides
        Front and rear panels have folded top and bottom and profiled sides
  manufacturer: Protocase
  partnumber: 1U Extruded Aluminum Type A Template
  verified: true
  Parser:
    verified: true
    version: 7.2
    Parameters:
    - {name: Front and Rear Metal, default: Aluminum, description: the type of metal used,
      template: true, units: MetalType}
    - {name: MetalType, default: Aluminum, description: the type of metal used, template: true,
      units: MetalType}
    - {name: FrontRearThick, default: '18', description: the thickness of the Front and Rear Panels,
      units: MetalThickness}
    - {name: TopBottomThick, default: '14', description: the thickness of the top and bottom panels,
    - {name: BendRad, default: '.025', description: the bend radius}
    - {name: PartsGap, default: '.01', description: the gap between parts (for manufacturing)}
    Parser:
      verified: false
      version: 7.2
      Parameters:
      - {name: Chem Film, default: '0', description: whether to use Chem Film treatment,
        template: true, boolean: true, displays: '"Front and Rear Metal" CONTAINS
          STRING "Aluminum"'}
      Parser:
        verified: false
        version: 7.2
        Parameters:
        - {name: useStainlessPEMs, default: '1.0', description: whether to use stainless steel fasteners.,
          boolean: true}
        Parser:
          verified: true
          version: 7.2
          Parameters:
          - {name: Screw Type, default: Black Panhead, description: Use Black Finish Screws instead of Natural Finish,
            template: true, units: ScrewType}
          Parser:
            verified: false
            version: 7.2
            Parameters:
            - {name: 6-32 screw, default: 'IfElse("Screw Type" CONTAINS STRING "Natural
                Panhead", "6-32 3/8in natural panhead screw", IfElse("Screw Type"
                CONTAINS STRING "Natural Flathead", "6-32 3/8in natural flathead screw",
                IfElse("Screw Type" CONTAINS STRING "Black Panhead", "6-32 3/8in black
                panhead screw", IfElse("Screw Type" CONTAINS STRING "Black Flathead",
                "6-32 3/8in black flathead screw", IfElse("Screw Type" CONTAINS STRING
                "Stainless Panhead", "6-32 3/8in stainless panhead screw", "6-32 3/8in
                stainless flathead screw")))))'}
            - {name: 8-32 screw, default: 'IfElse("Screw Type" CONTAINS STRING "Natural
                Panhead", "8-32 3/8in natural panhead screw", IfElse("Screw Type"
                CONTAINS STRING "Natural Flathead", "8-32 3/8in natural flathead screw",
                IfElse("Screw Type" CONTAINS STRING "Black Panhead", "8-32 3/8in black
                "8-32 3/8in black flathead screw", IfElse("Screw Type" CONTAINS STRING
                "Stainless Panhead", "8-32 3/8in stainless panhead screw", "8-32 3/8in
            - {name: 6-32 handle screw, default: 'IfElse("Screw Type" CONTAINS STRING
                "Natural", "6-32 3/8in natural panhead screw", IfElse("Screw Type"
                CONTAINS STRING "Black", "6-32 3/8in black panhead screw", "6-32 3/8in
                stainless panhead screw"))'}
            - {name: 8-32 handle screw, default: 'IfElse("Screw Type" CONTAINS STRING
                "Natural", "8-32 3/8in natural panhead screw", IfElse("Screw Type"
                CONTAINS STRING "Black", "8-32 3/8in black panhead screw", "8-32 3/8in
            - {name: 8-32 bracket screw, default: 'IfElse("Screw Type" CONTAINS STRING
                "Natural", "8-32 3/8in natural flathead screw", IfElse("Screw Type"
                CONTAINS STRING "Black", "8-32 3/8in black flathead screw", "8-32
                3/8in stainless flathead screw"))'}
            - {name: 6-32 bracket screw, default: 'IfElse("Screw Type" CONTAINS STRING
                "Natural", "6-32 3/8in natural flathead screw", IfElse("Screw Type"
                CONTAINS STRING "Black", "6-32 3/8in black flathead screw", "6-32
            - {name: 10-32 handle screw, default: '"10-32 1 1/4 natural flathead screw"'}
            - {name: 8-32 flathead screw, default: 'IfElse("Screw Type" CONTAINS STRING
            Parser:
              verified: false
              version: 7.2
              Parameters:
              - {name: useStainlessPEMs, default: ("MetalType" CONTAINS STRING "Stainless") OR (("MetalType" CONTAINS STRING "Aluminum") AND (Chem Film)),
                description: whether to use stainless steel fasteners., boolean: true}
              Parser:
                verified: false
                version: 7.2
                Parameters:
                - {name: 6-32 nut, default: 'IfElse(useStainlessPEMs,"SP-632-1","S-632-1ZI")'}
                - {name: 8-32 nut, default: 'IfElse(useStainlessPEMs,"SP-832-1","S-832-1ZI")'}
                - {name: 10-32 nut, default: 'IfElse(useStainlessPEMs,"SP-032-1","SS-032-1ZI")'}
                - {name: 8-32 stud, default: 'IfElse(useStainlessPEMs,"FH4-832-6","FH-832-6ZI")'}
                Parser:
                  verified: false
                  version: 7.2
                  Parameters:
                  - {name: Width, default: '4.330708661417323', description: the width of the enclosure,
                    template: true, min: '1', max: '23'}
                  - {name: Depth, default: '6.141732283464568', description: the depth of the enclosure,
                    template: true, min: '1', max: '35'}
                  - {name: Height, default: '1.718', description: the height of the enclosure}
                  - {name: Default Color, default: 'RAL 5017 Traffic Blue, High Gloss,
                      Smooth Polyester Powder', description: The default color for the enclosure,
                    template: true, units: MetalColor}
                  - {name: Extrusion Color, default: 'RAL 5017 Traffic Blue, High
                      Gloss, Smooth Polyester Powder', description: The color of the sides,
                  - {name: Front Color, default: Use Default, description: the color of the front,
                  - {name: Rear Color, default: Use Default, description: the color of the rear,
                  - {name: Top Color, default: Use Default, description: the color of the top,
                  - {name: Bottom Color, default: Use Default, description: the color of the bottom,
                  - {name: HoleOffsetV, default: '.381', description: the distance from the top or bottom of the extrusion side to the center of the screw holes}
                  Parser:
                    verified: false
                    version: 7.2
                    Parameters:
                    - {name: StraightDownForBend, default: BendRad+.062-.06055-.001}
                    - {name: StraightUpForBend, default: BendRad+.062-.062-.001}
                    - {name: FlushLength, default: Width-2*0.388, description: length of the flush portion of the front}
  revision: '10'
  revisionList:
  - {name: RevisionMessage, baseRevision: '9', message: fixed problem that prevented ordering}
  - {name: FaceFeatureTransfer, baseRevision: '9', from: Front Panel, to: Front Panel}
  - {name: FaceFeatureTransfer, baseRevision: '9', from: Rear Panel, to: Rear Panel}
  - {name: FaceFeatureTransfer, baseRevision: '9', from: Top, to: Top}
  - {name: FaceFeatureTransfer, baseRevision: '9', from: Bottom, to: Bottom}
  Transforms:
    View3D: {invertZ: '0', shiftX: '-.15', shiftY: '0.0', shiftZ: '-.07'}
  Components:
  - Part:
      name: Extruded Bottom Part
      version: 7.2
      description: The Bottom Cover
      partnumber: 1U Extruded Enclosure Bottom Part
      template: true
      verified: true
      Parser:
        verified: false
        version: 7.2
        Parameters:
        - {name: Width, default: Width-2*.02-2*.13}
        - {name: Depth, default: Depth}
        - {name: FrontRearThick, default: FrontRearThick}
        - {name: TopBottomThick, default: TopBottomThick}
        - {name: MetalType, default: MetalType}
        - {name: BottomColor, default: Bottom Color}
      MetalInfo: {material: MetalType, color: BottomColor, thickness: TopBottomThick}
      Connections:
      - {className: Absolute}
      Components:
      - RectFace:
          layers: [Default]
          version: 7.2
          verified: true
          pickable: true
          length: Width
          width: Depth
          FaceCoordinateTransform:
            invertX: 'true'
            Origin: [-1*(.02+.13), '0']
            xDir: ['1.0', '0.0']
            yDir: ['0.0', '1.0']
          AttachPts:
          - {className: MatePt, name: Bottom-Front, ID: a6e86ab3-73c4-421e-b3b9-9a4622a18448,
            x: Width/2, y: '0', z: '0', rotationAroundX: '-90', rotationAroundY: '180'}
          Connections:
          Attachment2Ds:
          - Rectangle: {width: .75-.02+.13, height: Depth, type: EXCLUSION, name: exclusion for clamping flange,
              version: 7.2, template: true, verified: true, layer: Default, OriginX: Width-(.75-.02+.13),
              OriginY: '0', onBottom: true}
          - Rectangle: {width: .75-.02+.13, height: Depth-.002, type: EXCLUSION, name: exclusion for clamping flange,
              version: 7.2, template: true, verified: true, layer: Default, OriginX: '0.0',
              OriginY: '0.0', onBottom: true}
  - Part:
      name: Extruded A Front Part
      version: 7.2
      description: The Front Cover (profiled with bends)
      partnumber: Extruded A Front Part
      template: true
      verified: true
      Parser:
        verified: false
        version: 7.2
        Parameters:
        - {name: Width, default: Width}
        - {name: Height, default: Height}
        - {name: TabSize, default: '.53582'}
        - {name: FlangeSize, default: .38-(BendRad+FrontRearThick)}
        - {name: NotchSize, default: '.032'}
        - {name: BendRad, default: BendRad, description: the bend radius}
        - {name: MetalType, default: Front and Rear Metal, description: the type of metal used}
        - {name: FrontColor, default: Front Color}
        - {name: FlushLength, default: FlushLength}
        - {name: StraightDownForBend, default: StraightDownForBend}
        - {name: StraightUpForBend, default: StraightUpForBend}
        - {name: HoleOffsetV, default: HoleOffsetV}
        - {name: 6-32 screw, default: 6-32 screw}
        - {name: PartsGap, default: PartsGap}
      MetalInfo: {material: MetalType, color: FrontColor, thickness: FrontRearThick}
      Connections:
      - {className: Relative, parent: Bottom-Front, child: Front-Bottom, rotation: '0',
        virtual: '0.0'}
      Components:
      - PathFace:
          layers: [Default]
          version: 7.2
          exist: '1.0'
          verified: true
          pickable: true
          Direct Printing: {Top: true, Bottom: true, Asked Bottom: true, Asked Top: false}
          BaseProfile:
            type: CONSTRUCT
            name: front panel profiled profile
            version: '7.2'
            verified: true
            layer: Default
            pathSegments:
            - CircleArc3:
                end: ['0.06999999999999999', '-0.07000000000000002']
                mid: ['0.02050252531694166', '-0.04949747468305834']
            - Line: ['0.2672030163', '0.0']
            - CircleArc3:
                end: ['0.03279698371310791', '0.042549881626554716']
                mid: ['0.02364617822778814', '0.015688503371187393']
            - Line: ['0.0', StraightDownForBend]
            - CircleArc3:
                end: ['0.018000000000000016', '0.018000000000000002']
                mid: ['0.00527207793864215', '0.012727922061357852']
            - Line: [FlushLength, '0.0']
            - CircleArc3:
                end: ['0.018000000000000682', '-0.018000000000000696']
                mid: ['0.012727922061358754', '-0.005272077938642344']
            - Line: ['0.0', -StraightDownForBend]
            - CircleArc3:
                end: ['0.03279698371717821', '-0.04254988163183553']
                mid: ['0.009150805486455305', '-0.02686137825870106']
            - Line: ['0.2672030162999999', '0.0']
            - CircleArc3:
                end: ['0.07000000000000028', '0.0700000000000003']
                mid: ['0.04949747468305876', '0.02050252531694175']
            - Line: ['0.0', '0.07148032299999998']
            - CircleArc3:
                end: ['-0.023999999982539322', '0.029393876898707566']
                mid: ['-0.006762099917566822', '0.018973665949799184']
            - CircleArc3:
                end: ['-0.015999999984717128', '0.019595917928010936']
                mid: ['-0.01149193337403176', '0.006946807297690899']
            - Line: ['0.0', '0.034835779899999975']
            - CircleArc3:
                end: ['0.01739765355285261', '0.019829972101348875']
                mid: ['0.004965923224497182', '0.013190016515203434']
            - Line: ['0.005204692900000474', '6.830274000000081E-4']
            - CircleArc3:
                end: ['0.017397653538574254', '0.019829972085073616']
                mid: ['0.012431730318152923', '0.006639955580695772']
            - Line: ['0.0', '0.014604866600000044']
            - CircleArc3:
                end: ['-0.01739765355281886', '0.01982997210134485']
                mid: ['-0.0049659232244856355', '0.013190016515190639']
            - Line: ['-0.005204692900000474', '6.830273999999803E-4']
            - CircleArc3:
                end: ['-0.01739765353853695', '0.019829972085066816']
                mid: ['-0.012431730318128054', '0.0066399555807035715']
            - Line: ['0.0', '0.03470919019999996']
            - CircleArc3:
                end: ['0.017397653552820636', '0.019829972101347793']
                mid: ['0.004965923224486524', '0.013190016515192637']
            - Line: ['0.005204692900000474', '6.830273999999803E-4']
            - CircleArc3:
                end: ['0.01739765353853695', '0.019829972085066816']
                mid: ['0.012431730318128054', '0.0066399555807035715']
            - CircleArc3:
                end: ['-0.017397653552854386', '0.019829972101350568']
                mid: ['-0.004965923224497182', '0.013190016515204572']
            - CircleArc3:
                end: ['-0.017397653538572477', '0.019829972085072534']
                mid: ['-0.012431730318152034', '0.006639955580695411']
            - CircleArc3:
                end: ['0.01739765355281797', '0.019829972101344295']
                mid: ['0.0049659232244856355', '0.013190016515190306']
            - Line: ['0.005204692900000474', '6.830273999999248E-4']
            - CircleArc3:
                end: ['0.017397653538572477', '0.01982997208507231']
                mid: ['0.012431730318152034', '0.0066399555806953']
            - CircleArc3:
                end: ['-0.017397653552853498', '0.019829972101349624']
                mid: ['-0.004965923224497182', '0.013190016515203906']
            - Line: ['-0.005204692900000474', '6.830274000000358E-4']
            - CircleArc3:
                end: ['-0.017397653538573365', '0.01982997208507331']
                mid: ['-0.012431730318152034', '0.006639955580695633']
            - CircleArc3:
                end: ['0.017397653552817083', '0.01982997210134363']
                mid: ['0.004965923224484747', '0.013190016515189806']
            - CircleArc3:
                end: ['0.01739765353853695', '0.01982997208506676']
                mid: ['0.012431730318128054', '0.006639955580703516']
            - CircleArc3:
                end: ['-0.017397653552854386', '0.019829972101350513']
            - CircleArc3:
                end: ['-0.017397653538574254', '0.019829972085073533']
                mid: ['-0.012431730318152923', '0.006639955580695744']
            - CircleArc3:
                end: ['0.017397653552816195', '0.019829972101342297']
                mid: ['0.0049659232244856355', '0.01319001651518903']
            - CircleArc3:
                end: ['0.01739765353853784', '0.01982997208506765']
                mid: ['0.012431730318128054', '0.006639955580703849']
            - Line: ['0.0', '0.14460486660000005']
            - CircleArc3:
                end: ['-0.01739765355281797', '0.019829972101344406']
                mid: ['-0.0049659232244856355', '0.013190016515190361']
            - CircleArc3:
                end: ['-0.01739765353853695', '0.01982997208506676']
                mid: ['-0.012431730318128054', '0.006639955580703516']
            - CircleArc3:
                end: ['0.017397653552817083', '0.019829972101343518']
                mid: ['0.0049659232244856355', '0.013190016515189695']
            - Line: ['0.005204692900000474', '6.830274000000358E-4']
            - CircleArc3:
                end: ['0.01739765353853784', '0.01982997208506787']
                mid: ['0.012431730318128942', '0.00663995558070396']
            - Line: ['0.0', '0.014604866599999822']
            - CircleArc3:
                end: ['-0.017397653552817083', '0.01982997210134374']
                mid: ['-0.004965923224484747', '0.013190016515189917']
            - Line: ['-0.005204692900000474', '6.830273999998138E-4']
            - CircleArc3:
                end: ['-0.01739765353853784', '0.01982997208506765']
                mid: ['-0.012431730318128054', '0.006639955580703738']
            - Line: ['0.0', '0.03470919019999985']
            - CircleArc3:
                end: ['0.01739765355281797', '0.019829972101344406']
                mid: ['0.0049659232244856355', '0.013190016515190361']
            - CircleArc3:
            - CircleArc3:
                end: ['-0.017397653552851722', '0.01982997210134796']
                mid: ['-0.004965923224497182', '0.013190016515202796']
            - CircleArc3:
                end: ['-0.017397653538574254', '0.019829972085074754']
                mid: ['-0.012431730318152923', '0.0066399555806961885']
            - Line: ['0.0', '0.03470919020000007']
            - CircleArc3:
                end: ['0.017397653552816195', '0.01982997210134263']
                mid: ['0.004965923224484747', '0.01319001651518903']
            - CircleArc3:
                end: ['0.017397653538536062', '0.019829972085065872']
                mid: ['0.012431730318127165', '0.006639955580703294']
            - CircleArc3:
                end: ['-0.01739765355281886', '0.019829972101345072']
                mid: ['-0.0049659232244856355', '0.013190016515190806']
            - CircleArc3:
                end: ['-0.01739765353853695', '0.01982997208506654']
                mid: ['-0.012431730318127165', '0.006639955580703516']
            - CircleArc3:
                end: ['0.017397653552817083', '0.019829972101343296']
            - CircleArc3:
                end: ['0.01739765353853695', '0.019829972085066983']
                mid: ['0.012431730318128054', '0.006639955580703738']
            - CircleArc3:
                end: ['-0.01739765355281797', '0.019829972101343962']
                mid: ['-0.0049659232244856355', '0.01319001651519014']
            - CircleArc3:
                end: ['-0.017397653538534286', '0.01982997208506454']
                mid: ['-0.012431730318126277', '0.00663995558070285']
            - Line: ['0.0', '0.034835779900000086']
            - CircleArc3:
                end: ['0.015999999962903466', '0.019595917901295']
                mid: ['0.004508066604539174', '0.012649110613075054']
            - CircleArc3:
                end: ['0.0239999999934426', '0.02939387691206119']
                mid: ['0.01723790007280357', '0.010420210953642428']
            - Line: ['0.0', '0.07312759940000002']
            - CircleArc3:
                end: ['-0.07000000000000028', '0.07000000000000006']
                mid: ['-0.020502525316941522', '0.04949747468305832']
            - Line: ['-0.2560000000000002', '0.0']
            - CircleArc3:
                end: ['-0.04400000000000315', '-0.04400000000000315']
                mid: ['-0.03111269837221009', '-0.012887301627792835']
            - Line: ['0.0', -StraightUpForBend]
            - CircleArc3:
                end: ['-0.017999999999999794', '-0.018000000000000016']
                mid: ['-0.005272077938641928', '-0.012727922061357866']
            - Line: [-FlushLength, '0.0']
            - CircleArc3:
                end: ['-0.018000000000000016', '0.018000000000000016']
                mid: ['-0.012727922061357866', '0.00527207793864215']
            - Line: ['0.0', StraightUpForBend]
            - CircleArc3:
                end: ['-0.04400000000000309', '0.04400000000000315']
                mid: ['-0.012887301627792835', '0.031112698372210312']
            - Line: ['-0.256', '0.0']
            - CircleArc3:
                end: ['-0.0700000000000001', '-0.07000000000000006']
                mid: ['-0.049497474683058394', '-0.020502525316941744']
            - Line: ['0.0', '-0.07312759940000002']
            - CircleArc3:
                end: ['0.02399999999344323', '-0.029393876912061634']
                mid: ['0.006762099920639222', '-0.018973665958419206']
            - CircleArc3:
                end: ['0.015999999962937963', '-0.019595917901301663']
                mid: ['0.01149193335838786', '-0.006946807288213508']
            - Line: ['0.0', '-0.034835779900000086']
            - CircleArc3:
                end: ['-0.017397653538534986', '-0.01982997208506454']
                mid: ['-0.004965923220408647', '-0.01319001650436169']
            - Line: ['-0.005204692900000002', '-6.830274000000358E-4']
            - CircleArc3:
                end: ['-0.017397653552817846', '-0.019829972101344184']
                mid: ['-0.012431730328332353', '-0.006639955586154045']
            - Line: ['0.0', '-0.014604866600000044']
            - CircleArc3:
                end: ['0.017397653538536804', '-0.01982997208506654']
                mid: ['0.004965923220409164', '-0.013190016504363022']
            - Line: ['0.005204692900000002', '-6.830274000000358E-4']
            - CircleArc3:
                end: ['0.017397653552816805', '-0.019829972101343074']
                mid: ['0.012431730328331607', '-0.006639955586153601']
            - Line: ['0.0', '-0.03470919019999985']
            - CircleArc3:
                end: ['-0.017397653538536985', '-0.01982997208506676']
                mid: ['-0.004965923220409216', '-0.013190016504363244']
            - Line: ['-0.005204692900000002', '-6.830273999998138E-4']
            - CircleArc3:
            - Line: ['0.0', '-0.014604866599999822']
            - CircleArc3:
                end: ['0.017397653538535934', '-0.01982997208506565']
                mid: ['0.004965923220408916', '-0.013190016504362356']
            - CircleArc3:
                end: ['0.017397653552815844', '-0.019829972101341964']
                mid: ['0.012431730328330923', '-0.006639955586153157']
            - Line: ['0.0', '-0.03470919020000007']
            - CircleArc3:
                end: ['-0.01739765353857359', '-0.019829972085073644']
                mid: ['-0.004965923220421289', '-0.0131900165043779']
            - CircleArc3:
                end: ['-0.017397653552852367', '-0.019829972101348625']
                mid: ['-0.012431730328355386', '-0.006639955586145385']
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
                end: ['-0.017397653538537075', '-0.019829972085066983']
                mid: ['-0.0049659232204092435', '-0.013190016504363244']
            - CircleArc3:
                end: ['-0.01739765355281776', '-0.019829972101344184']
                mid: ['-0.01243173032833229', '-0.006639955586154045']
            - CircleArc3:
                end: ['0.017397653538537936', '-0.01982997208506787']
                mid: ['0.004965923220409486', '-0.01319001650436391']
            - CircleArc3:
                end: ['0.017397653552816895', '-0.019829972101343074']
                mid: ['0.01243173032833167', '-0.006639955586153601']
            - Line: ['0.0', '-0.03470919019999996']
            - CircleArc3:
                end: ['-0.017397653538536024', '-0.01982997208506565']
                mid: ['-0.004965923220408938', '-0.013190016504362467']
            - CircleArc3:
                mid: ['-0.012431730328332353', '-0.006639955586153934']
            - Line: ['0.0', '-0.14460486660000005']
            - CircleArc3:
                end: ['0.01739765353853776', '-0.01982997208506765']
                mid: ['0.004965923220409438', '-0.0131900165043638']
            - Line: ['0.005204692900000002', '-6.830273999999248E-4']
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
                end: ['-0.017397653552853325', '-0.019829972101349735']
                mid: ['-0.012431730328356072', '-0.006639955586145718']
            - CircleArc3:
                mid: ['0.004965923220409164', '-0.013190016504363133']
            - CircleArc3:
                end: ['0.017397653552817763', '-0.019829972101344073']
                mid: ['0.012431730328332294', '-0.006639955586153934']
            - CircleArc3:
                end: ['-0.017397653538573424', '-0.019829972085073422']
                mid: ['-0.004965923220421248', '-0.013190016504377677']
            - CircleArc3:
                mid: ['-0.012431730328355386', '-0.006639955586145274']
            - CircleArc3:
                end: ['0.017397653538572456', '-0.01982997208507231']
                mid: ['0.004965923220420972', '-0.013190016504377011']
            - CircleArc3:
                end: ['0.017397653552852277', '-0.019829972101348625']
                mid: ['0.012431730328355324', '-0.006639955586145385']
            - CircleArc3:
                end: ['-0.017397653538572554', '-0.019829972085072423']
                mid: ['-0.004965923220420998', '-0.013190016504377067']
            - Line: ['-0.005204692900000002', '-6.830273999999803E-4']
            - CircleArc3:
            - CircleArc3:
                end: ['0.017397653538536804', '-0.019829972085066594']
                mid: ['0.004965923220409164', '-0.013190016504363078']
            - Line: ['0.005204692900000002', '-6.830273999999803E-4']
            - CircleArc3:
                end: ['0.01739765355281967', '-0.019829972101346294']
                mid: ['0.01243173032833366', '-0.0066399555861546555']
            - CircleArc3:
                end: ['-0.017397653538536725', '-0.019829972085066483']
                mid: ['-0.004965923220409146', '-0.013190016504363022']
            - CircleArc3:
                end: ['-0.017397653552818717', '-0.01982997210134524']
                mid: ['-0.012431730328332974', '-0.0066399555861543225']
            - CircleArc3:
                end: ['0.017397653538573588', '-0.019829972085073616']
                mid: ['0.004965923220421296', '-0.013190016504377844']
            - Line: ['0.005204692900000002', '-6.830274000000081E-4']
            - CircleArc3:
                end: ['0.017397653552852367', '-0.01982997210134868']
                mid: ['0.012431730328355386', '-0.006639955586145385']
            - Line: ['0.0', '-0.034835779899999975']
            - CircleArc3:
                end: ['-0.01599999998471769', '-0.01959591792801113']
                mid: ['-0.00450806661068523', '-0.012649110630320148']
            - CircleArc3:
                end: ['-0.023999999982539374', '-0.02939387689870729']
                mid: ['-0.017237900064972347', '-0.010420210948908298']
            - Line: [((((((0.0)-(-2.1234483615906186E-10))-(-1.2344836159061849E-11))-(-1.2344836159061849E-11))-(-1.2344836159061849E-11))-(-1.2344836159061849E-11))-(-1.2344836159061849E-11),
                ((((((-0.07148032299999998)-(-1.779055514017358E-10))-(2.2094451268550586E-11))-(2.2094451268550586E-11))-(2.2094451268550586E-11))-(2.2094451268550586E-11))-(2.2094451268550586E-11)]
            Origin: ['0', Height-.07]
            yDir: ['0.0', '-1.0']
          Components:
          - Bend:
              layers: [Default]
              version: 7.2
              verified: true
              length: FlushLength
              angle: '90'
              irad: BendRad
              kfactor: '0.5'
                Origin: ['0.0', '0.0']
              Components:
              - RectFace:
                  layers: [Default]
                  version: 7.2
                  exist: '1.0'
                  verified: true
                  length: FlushLength
                  width: FlangeSize
                  Connections:
                  - {className: Seam, parentSide: '2.0', parentSideLoc: (FlushLength) - (0),
                    childSideLoc: '0'}
              Connections:
              - {className: Seam, parentSide: '5', parentSideLoc: FlushLength, childSideLoc: '0'}
          - Bend:
              layers: [Default]
              version: 7.2
              verified: true
              length: FlushLength
              angle: '90'
              irad: BendRad
              kfactor: '0.5'
              Components:
              - RectFace:
                  layers: [Default]
                  version: 7.2
                  exist: '1.0'
                  verified: true
                  length: FlushLength
                  width: FlangeSize
                  Connections:
                    childSideLoc: '0'}
              Connections:
              - {className: Seam, parentSide: '95', parentSideLoc: FlushLength, childSideLoc: '0'}
          AttachPts:
          - {className: MatePt, name: Front-LeftSide, ID: b2422e8e-b465-4478-bdea-dec96114b072,
            x: '0', y: '0', z: '0', onBottom: false, gap: PartsGap}
          - {className: MatePt, name: Front-RightSide, ID: 70c36296-c54c-48bd-9fe1-ce2dfd205e94,
            x: Width, y: '0', z: '0', onBottom: false, gap: PartsGap}
          - {className: MatePt, name: Front-Top, ID: 8b6f6e42-cbb1-4ef4-b94f-f9374fdf3dc3,
            x: Width/2, y: '-.005', z: PartsGap, onBottom: false}
          - {className: MatePt, name: Front-Bottom, ID: e2380e58-9d6d-4de7-91bc-a5b1cffd6513,
            x: Width/2, y: Height-2*.068, z: PartsGap, onBottom: false}
          Connections:
          Attachment2Ds:
          - Rectangle: {width: '3.3475296966024093', height: '0.09042502222732884',
              type: SILKSCREEN, color: Blue Pantone Process C, name: rectangle, version: 7.2,
              ID: ee6b0c37-d5ea-4e22-9463-2aa4cfcad682, verified: false, layer: Default,
              OriginX: '0.5041875912670194', OriginY: '0.4518452538018003', onBottom: true,
              scaleFactorY: '-1.0'}
          - Circle: {radius: '0.06692913385826772', type: CUTOUT, name: circle, version: 7.2,
              ID: fc8426a8-1629-43cc-9840-6f53afe68065, verified: false, layer: Default,
              OriginX: '0.9133858267716536', OriginY: '0.7424881889763778', onBottom: true,
          - Rectangle: {width: '0.5511811023622047', height: '0.1456692913385827',
              type: CUTOUT, name: rectangle, version: 7.2, ID: f6f70590-8d40-406b-9156-bcc01cc5aa77,
              verified: false, layer: Default, OriginX: '1.8976377952755907', OriginY: '0.9668976377952755',
              onBottom: true, scaleFactorY: '-1.0'}
          - Circle: {radius: '0.13385826771653545', type: CUTOUT, name: circle, version: 7.2,
              ID: 803c355c-31a4-40ae-a9ce-e54c1ca9f224, verified: false, layer: Default,
              OriginX: '0.594488188976378', OriginY: '0.9314645669291337', onBottom: true,
          - CompositePath:
              type: EXCLUSION
              name: Left Extrusion Profile
              version: '7.2'
              template: true
              verified: true
              layer: Default
              OriginX: ((0)+((1.0)*(((0)-(0))*(1.0))))+((0.0)*(((0)-(1*(Height-.134)))*(-1.0)))
              OriginY: ((1*(Height-.134))+((0.0)*(((0)-(0))*(1.0))))+((-1.0)*(((0)-(1*(Height-.134)))*(-1.0)))
              onBottom: true
              scaleFactorY: -1*(1.0)
              thickness: '1.0'
              pathSegments:
              - CircleArc3:
                  end: ['0.07000000000000028', '0.07']
                  mid: ['0.020502525316941522', '0.0494974747']
              - Line: ['0.2560000000000002', '-0.0']
              - CircleArc3:
                  end: ['0.043999999999999595', '-0.04400000000069104']
                  mid: ['0.031112698372452563', '-0.012887301628036418']
              - CircleArc3:
                  end: ['-0.020000000000017337', '-0.019999999999702922']
                  mid: ['-0.005857864376385358', '-0.014142135623540053']
              - Line: ['-0.20000000000000018', '-0.0']
              - Line: ['-0.019999999999999574', '-0.020000000000000018']
              - Line: ['0.0', '-0.040000000000000036']
              - Line: ['0.019999999999999574', '-0.020000000000000018']
              - Line: ['0.43899609370000015', '-0.0']
              - Line: ['0.007653668599999719', '0.0015224093']
              - Line: ['0.03133450890000056', '0.0208972257']
              - Line: ['0.10171572879999946', '-0.0']
              - Line: ['0.014142135600000216', '-0.0058578643999998015']
              - Line: ['0.0058578644000002456', '-0.014142135600000216']
              - Line: ['0.0', '-0.009496089999999846']
              - Line: ['-0.0058578644000002456', '-0.014142135600000216']
              - Line: ['-0.014142135600000216', '-0.0058578643999998015']
              - Line: ['-0.08121377699999943', '-0.0']
              - Line: ['-0.02484603949999986', '-0.01656176829999989']
              - Line: ['-0.014142135700000225', '-0.005857864300000237']
              - Line: ['-0.45949804780000036', '-0.0']
              - Line: ['-0.019999999999999574', '-0.019999999999999574']
              - Line: ['0.0', '-0.03000000000000025']
              - Line: ['0.019999999999999574', '-0.020000000000000462']
              - Line: ['0.07354499120000035', '-0.0']
              - Line: ['0.050098144199999695', '-0.0111628532000001']
              - Line: ['0.040619530199999865', '-0.03137653759999992']
              - Line: ['0.006936184500000664', '-0.019184900700000007']
              - Line: ['-0.01081509940000025', '-0.023063815499999585']
              - Line: ['-0.0191849006', '-0.006936184499999776']
              - Line: ['-0.023063815500000473', '0.0108150994']
              - CircleArc3:
                  end: ['-0.007499235430590723', '-0.08168085129369906']
                  mid: ['-0.10234712720391403', '-0.031788047704970346']
              - Line: ['0.019184900700000007', '0.0069361845']
              - Line: ['0.023063815499999585', '-0.010815099399999362']
              - Line: ['0.006936184499999776', '-0.0191849006']
              - Line: ['-0.010815099399999362', '-0.02306381560000048']
              - Line: ['-0.03534007570000064', '-0.02025233409999938']
              - Line: ['-0.04012053349999967', '-0.00702999140000049']
              - Line: ['-0.07354582770000029', '-3.0759999996021747E-6']
              - Line: ['-0.01999916349999964', '-0.020000000000000462']
              - Line: ['0.0', '-0.030000836400000175']
              - Line: ['0.019999999999999574', '-0.019999999999999574']
              - Line: ['0.08999999999999986', '-0.0']
              - Line: ['0.020000000000000462', '-0.020000000000000462']
              - Line: ['0.0', '-0.019999999999999574']
              - Line: ['-0.020000000000000462', '-0.020000000000000462']
              - Line: ['-0.08999999999999986', '-0.0']
              - Line: ['0.014142135600000216', '-0.0058578644000002456']
              - Line: ['0.020000000000000462', '-0.019999999999999574']
              - Line: ['0.0', '-0.020000000000000462']
              - Line: ['-0.020000000000000462', '-0.019999999999999574']
              - Line: ['0.0', '-0.030000836500000183']
              - Line: ['0.01999916349999964', '-0.019999999900000454']
              - Line: ['0.07354582770000029', '-3.0759999996021747E-6']
              - Line: ['0.04012053349999967', '-0.007029991500000499']
              - Line: ['0.03534007570000064', '-0.02025233409999938']
              - Line: ['0.010815099399999362', '-0.023063815500000473']
              - Line: ['-0.006936184499999776', '-0.0191849006']
              - Line: ['-0.023063815499999585', '-0.01081509940000025']
              - Line: ['-0.019184900700000007', '0.0069361845']
              - CircleArc3:
                  end: ['0.0074992354305898346', '-0.08168085129369906']
                  mid: ['-0.0948478917733242', '-0.04989280358872872']
              - Line: ['0.023063815500000473', '0.0108150993']
              - Line: ['0.0191849006', '-0.0069361843999997674']
              - Line: ['0.01081509940000025', '-0.02306381560000048']
              - Line: ['-0.006936184500000664', '-0.0191849006']
              - Line: ['-0.040619530199999865', '-0.03137653759999992']
              - Line: ['-0.050098144199999695', '-0.011162853199999212']
              - Line: ['-0.07354499120000035', '-0.0']
              - Line: ['-0.019999999999999574', '-0.020000000000000462']
              - Line: ['0.45949804780000036', '-0.0']
              - Line: ['0.02484603959999987', '-0.01656176829999989']
              - Line: ['0.014142135600000216', '-0.005857864300000237']
              - Line: ['0.08121377699999943', '-0.0']
              - Line: ['-0.0058578644000002456', '-0.014142135699999336']
              - Line: ['-0.014142135600000216', '-0.005857864300000237']
              - Line: ['-0.09674516599999983', '-0.0']
              - Line: ['-0.026301886099999727', '0.013047052']
              - Line: ['-0.022627416999999816', '0.009372583']
              - Line: ['-0.4340255309000005', '-0.0']
              - CircleArc3:
                  end: ['-0.019999999999999574', '-0.019999999999999574']
                  mid: ['-0.014142135623730567', '-0.005857864376269006']
              - CircleArc3:
                  end: ['0.019999999999846807', '-0.01999999999998625']
                  mid: ['0.0058578643761748594', '-0.014142135623712804']
              - Line: ['0.20000000000000018', '-0.0']
              - CircleArc3:
                  end: ['0.020000000000018225', '-0.020000000000297113']
                  mid: ['0.014142135623842478', '-0.005857864376372923']
              - CircleArc3:
                  end: ['-0.044000000000370854', '-0.043999999999756234']
                  mid: ['-0.01288730162811813', '-0.03111269837207331']
              - Line: ['-0.2560000000000002', '-0.0']
              - CircleArc3:
                  end: ['-0.07000000000000028', '0.07']
                  mid: ['-0.04949747468305876', '0.0205025253']
              - Line: ['0.0', '0.0731275994']
              - Line: ['0.040000000000000036', '0.0489897948']
              - Line: ['0.0', '0.0348357799']
              - Line: ['-0.040000000000000036', '0.0403429716']
              - Line: ['0.0', '0.0146048666']
              - Line: ['0.040000000000000036', '0.0403429717']
              - Line: ['0.0', '0.0347091901']
              - Line: ['0.0', '0.1446048666']
              - Line: ['0.0', '0.0348357798']
              - Line: ['-0.040000000000000036', '0.0489897948']
              - Line: ['0.0', '0.0729304414']
          - CompositePath:
              type: EXCLUSION
              version: '7.2'
              template: true
              verified: true
              layer: Default
              rotation: '-180.0'
              OriginX: ((0)+((1.0)*(((Width)-(0))*(1.0))))+((0.0)*(((Height-0.139)-(1*(Height-.134)))*(-1.0)))
              OriginY: ((1*(Height-.134))+((0.0)*(((Width)-(0))*(1.0))))+((-1.0)*(((Height-0.139)-(1*(Height-.134)))*(-1.0)))
              onBottom: true
              thickness: '1.0'
              pathSegments:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
          - Rectangle: {width: Width, height: -1*(Height), type: NO_SILK, name: Inside Silk Exclusion,
              version: 7.2, template: true, verified: true, layer: Default, OriginX: ((0)+((1.0)*(((0)-(0))*(1.0))))+((0.0)*((((-.07)-(1*(Height-.134)))*(-1.0))-(Height))),
              OriginY: ((1*(Height-.134))+((0.0)*(((0)-(0))*(1.0))))+((-1.0)*((((-.07)-(1*(Height-.134)))*(-1.0))-(Height))),
              onBottom: false}
          - Rectangle: {width: Width-0.72, height: -1*(0.25), type: EXCLUSION, name: exclusion for top,
              version: 7.2, template: true, verified: true, layer: Default, OriginX: ((0)+((1.0)*(0.36)))+((0.0)*(0.156-.134)),
              OriginY: ((1*(Height-.134))+((0.0)*(0.36)))+((-1.0)*(0.156-.134)), onBottom: true}
          - Rectangle: {width: Width-0.72, height: -1*(0.25), type: EXCLUSION, name: exclusion for bottom,
              version: 7.2, template: true, verified: true, layer: Default, OriginX: ((0)+((1.0)*(0.36)))+((0.0)*(-0.016 + Height-.134-0.25)),
              OriginY: ((1*(Height-.134))+((0.0)*(0.36)))+((-1.0)*(-0.016 + Height-.134-0.25)),
              onBottom: true}
          - Screw: {partnumber: 6-32 screw, inLibrary: byParsedPartNum, name: 6-32 3/8in black panhead screw,
              version: 7.2, description: 6-32 3/8 inch black finish pan head screw,
              template: true, verified: true, layer: Default, OriginX: Width - .22354,
              OriginY: HoleOffsetV - .070, onBottom: true}
              OriginY: Height - HoleOffsetV - 0.070, onBottom: true}
              template: true, verified: true, layer: Default, OriginX: '0.22354',
              ID: 86e76ab7-cd70-49b9-8d07-1de0e83e9577, verified: false, layer: Default,
              OriginX: '1.3779527559055118', OriginY: '0.9314645669291337', onBottom: true,
              ID: 6d72f270-46f3-49b6-b4fe-4ee21af83b4b, verified: false, layer: Default,
              OriginX: '2.8976377952755903', OriginY: '0.9314645669291337', onBottom: true,
          - Rectangle: {width: '0.3779527559055118', height: '0.4867631015799883',
              type: CUTOUT, name: rectangle, version: 7.2, ID: 7459903e-d5f1-4421-9b07-d1e96b3b1db2,
              verified: false, layer: Default, OriginX: '3.4803149606299217', OriginY: '0.9615347551232952',
          - Text2D: {type: SILKSCREEN, color: Blue Pantone Process C, name: Text,
              version: 7.2, ID: 2e1661d4-b77a-48d2-8ecf-3c99c9eac7a3, verified: false,
              layer: Default, OriginX: '3.374175817540523', OriginY: '1.1445033408659908',
              onBottom: true, scaleFactorY: '-1.0', content: 6V - 15Vdc, fontFamily: Arial,
              fontStyle: Regular, fontSize: '9.0', sizeCorrected: true}
              version: 7.2, ID: 2429865e-eaea-4a6c-823b-0ceb99f73d29, verified: false,
              layer: Default, OriginX: '0.4453394874291893', OriginY: '0.6633803297594059',
              onBottom: true, scaleFactorY: '-1.0', content: GPS, fontFamily: Arial,
              fontStyle: Regular, fontSize: '11.0', sizeCorrected: true}
              version: 7.2, ID: 652293c0-c87b-4354-a263-382998f96379, verified: false,
              layer: Default, OriginX: '1.1489818911725695', OriginY: '0.6633803297594059',
              onBottom: true, scaleFactorY: '-1.0', content: 10 Mhz, fontFamily: Arial,
              version: 7.2, ID: a5994e51-11d5-4021-a9bc-d6e886ba98b5, verified: false,
              layer: Default, OriginX: '2.754729940740796', OriginY: '0.6633803297594059',
              onBottom: true, scaleFactorY: '-1.0', content: PPS, fontFamily: Arial,
              version: 7.2, ID: 658ec383-0ee4-4911-b7af-99f7a2119710, verified: false,
              layer: Default, OriginX: '0.4874377509010157', OriginY: '0.320580184345965',
              onBottom: true, scaleFactorY: '-1.0', content: USRP, fontFamily: Arial,
              fontStyle: Bold, fontSize: '16.0', sizeCorrected: true}
              version: 7.2, ID: 70801589-0187-48ef-a355-f0186dad147e, verified: false,
              layer: Default, OriginX: '0.535550052011674', OriginY: '1.3670227335027862',
              onBottom: true, scaleFactorY: '-1.0', content: www.sigteq.com, fontFamily: Arial,
              version: 7.2, ID: a16e5381-820c-4aef-87bd-b37d0f30c83b, verified: false,
              layer: Default, OriginX: '1.9488488971372666', OriginY: '1.180587566698985',
              onBottom: true, scaleFactorY: '-1.0', content: USB 3.0, fontFamily: Arial,
              version: 7.2, ID: 073b531b-3afc-494d-ae5d-74502b1ebf75, verified: false,
              layer: Default, OriginX: '1.2091222675608926', OriginY: '0.320580184345965',
              onBottom: true, scaleFactorY: '-1.0', content: Software Defined Radio,
              fontFamily: Arial, fontStyle: Regular, fontSize: '9.0', sizeCorrected: true}
  - Part:
      name: Extruded Left Side Part
      version: 7.2
      description: The left side
      partnumber: 1U Extruded Enclosure Left Side Part
      template: true
      verified: true
      Parser:
        verified: false
        version: 7.2
        Parameters:
        - {name: color, default: Extrusion Color}
        - {name: Length, default: Depth}
      MetalInfo: {material: Aluminum, color: color, thickness: '0'}
      Connections:
      - {className: Relative, parent: Front-LeftSide, child: LeftSide-Front, rotation: '0',
        virtual: '0.0'}
      Components:
      - Sweep:
          name: 1U Extruded Aluminum Sweep
          version: 7.2
          partnumber: 1U Extruded Side
          verified: false
          Rotation: '0'
          CrossSection:
            CompositePath:
              type: CONSTRUCT
              name: Un-named 2D Thing
              version: '7.2'
              verified: false
              Parser:
                verified: false
                version: 7.2
                Parameters:
              layer: Default
              pathSegments:
              - CircleArc3:
                  end: ['0.07000000000000028', '-0.07000000000000028']
                  mid: ['0.020502525316941522', '-0.04949747468305832']
              - Line: ['0.2560000000000002', '0.0']
              - CircleArc3:
                  end: ['0.043999999999999595', '0.04400000000069104']
                  mid: ['0.031112698372452563', '0.012887301628036418']
              - CircleArc3:
                  end: ['-0.020000000000017337', '0.019999999999702922']
                  mid: ['-0.005857864376385358', '0.014142135623540053']
              - Line: ['-0.20000000000000018', '0.0']
              - Line: ['-0.019999999999999574', '0.020000000000000018']
              - Line: ['0.0', '0.040000000000000036']
              - Line: ['0.019999999999999574', '0.020000000000000018']
              - Line: ['0.43899609370000015', '0.0']
              - Line: ['0.007653668599999719', '-0.0015224093000001382']
              - Line: ['0.03133450890000056', '-0.020897225699999744']
              - Line: ['0.10171572879999946', '0.0']
              - Line: ['0.014142135600000216', '0.0058578643999998015']
              - Line: ['0.0058578644000002456', '0.014142135600000216']
              - Line: ['0.0', '0.009496089999999846']
              - Line: ['-0.0058578644000002456', '0.014142135600000216']
              - Line: ['-0.014142135600000216', '0.0058578643999998015']
              - Line: ['-0.08121377699999943', '0.0']
              - Line: ['-0.02484603949999986', '0.01656176829999989']
              - Line: ['-0.014142135700000225', '0.005857864300000237']
              - Line: ['-0.45949804780000036', '0.0']
              - Line: ['-0.019999999999999574', '0.019999999999999574']
              - Line: ['0.0', '0.03000000000000025']
              - Line: ['0.019999999999999574', '0.020000000000000462']
              - Line: ['0.07354499120000035', '0.0']
              - Line: ['0.050098144199999695', '0.0111628532000001']
              - Line: ['0.040619530199999865', '0.03137653759999992']
              - Line: ['0.006936184500000664', '0.019184900700000007']
              - Line: ['-0.01081509940000025', '0.023063815499999585']
              - Line: ['-0.0191849006', '0.006936184499999776']
              - Line: ['-0.023063815500000473', '-0.010815099399999362']
              - CircleArc3:
                  end: ['-0.007499235430590723', '0.08168085129369906']
                  mid: ['-0.10234712720391403', '0.031788047704970346']
              - Line: ['0.019184900700000007', '-0.006936184499999776']
              - Line: ['0.023063815499999585', '0.010815099399999362']
              - Line: ['0.006936184499999776', '0.0191849006']
              - Line: ['-0.010815099399999362', '0.02306381560000048']
              - Line: ['-0.03534007570000064', '0.02025233409999938']
              - Line: ['-0.04012053349999967', '0.00702999140000049']
              - Line: ['-0.07354582770000029', '3.0759999996021747E-6']
              - Line: ['-0.01999916349999964', '0.020000000000000462']
              - Line: ['0.0', '0.030000836400000175']
              - Line: ['0.019999999999999574', '0.019999999999999574']
              - Line: ['0.08999999999999986', '0.0']
              - Line: ['0.020000000000000462', '0.020000000000000462']
              - Line: ['0.0', '0.019999999999999574']
              - Line: ['-0.020000000000000462', '0.020000000000000462']
              - Line: ['-0.08999999999999986', '0.0']
              - Line: ['0.014142135600000216', '0.0058578644000002456']
              - Line: ['0.020000000000000462', '0.019999999999999574']
              - Line: ['0.0', '0.020000000000000462']
              - Line: ['-0.020000000000000462', '0.019999999999999574']
              - Line: ['0.0', '0.030000836500000183']
              - Line: ['0.01999916349999964', '0.019999999900000454']
              - Line: ['0.07354582770000029', '3.0759999996021747E-6']
              - Line: ['0.04012053349999967', '0.007029991500000499']
              - Line: ['0.03534007570000064', '0.02025233409999938']
              - Line: ['0.010815099399999362', '0.023063815500000473']
              - Line: ['-0.006936184499999776', '0.0191849006']
              - Line: ['-0.023063815499999585', '0.01081509940000025']
              - Line: ['-0.019184900700000007', '-0.006936184500000664']
              - CircleArc3:
                  end: ['0.0074992354305898346', '0.08168085129369906']
                  mid: ['-0.0948478917733242', '0.04989280358872872']
              - Line: ['0.023063815500000473', '-0.010815099300000242']
              - Line: ['0.0191849006', '0.0069361843999997674']
              - Line: ['0.01081509940000025', '0.02306381560000048']
              - Line: ['-0.006936184500000664', '0.0191849006']
              - Line: ['-0.040619530199999865', '0.03137653759999992']
              - Line: ['-0.050098144199999695', '0.011162853199999212']
              - Line: ['-0.07354499120000035', '0.0']
              - Line: ['-0.019999999999999574', '0.020000000000000462']
              - Line: ['0.45949804780000036', '0.0']
              - Line: ['0.02484603959999987', '0.01656176829999989']
              - Line: ['0.014142135600000216', '0.005857864300000237']
              - Line: ['0.08121377699999943', '0.0']
              - Line: ['-0.0058578644000002456', '0.014142135699999336']
              - Line: ['-0.014142135600000216', '0.005857864300000237']
              - Line: ['-0.09674516599999983', '0.0']
              - Line: ['-0.026301886099999727', '-0.013047052000000114']
              - Line: ['-0.022627416999999816', '-0.009372582999999324']
              - Line: ['-0.4340255309000005', '0.0']
              - CircleArc3:
                  end: ['-0.019999999999999574', '0.019999999999999574']
                  mid: ['-0.014142135623730567', '0.005857864376269006']
              - CircleArc3:
                  end: ['0.019999999999846807', '0.01999999999998625']
                  mid: ['0.0058578643761748594', '0.014142135623712804']
              - Line: ['0.20000000000000018', '0.0']
              - CircleArc3:
                  end: ['0.020000000000018225', '0.020000000000297113']
                  mid: ['0.014142135623842478', '0.005857864376372923']
              - CircleArc3:
                  end: ['-0.044000000000370854', '0.043999999999756234']
                  mid: ['-0.01288730162811813', '0.03111269837207331']
              - CircleArc3:
                  end: ['-0.07000000000000028', '-0.07000000000000028']
                  mid: ['-0.04949747468305876', '-0.020502525316941522']
              - Line: ['0.0', '-0.07312759940000024']
              - Line: ['0.040000000000000036', '-0.048989794799999764']
              - Line: ['0.0', '-0.034835779899999864']
              - Line: ['-0.040000000000000036', '-0.04034297160000033']
              - Line: ['0.040000000000000036', '-0.04034297170000034']
              - Line: ['0.0', '-0.034709190100000065']
              - Line: ['-0.040000000000000036', '-0.040342971599999444']
              - Line: ['0.0', '-0.14460486659999994']
              - Line: ['0.040000000000000036', '-0.04034297169999945']
              - Line: ['0.0', '-0.034835779799999855']
              - Line: ['-0.040000000000000036', '-0.048989794799999764']
              - Line: ['0.0', '-0.07293044140000005']
          SweepPath:
            CompositePath:
              type: CONSTRUCT
              version: '7.2'
              verified: false
              Parser:
                verified: false
                version: 7.2
                Parameters:
              layer: Default
              pathSegments:
              - Line: ['0', Length]
          AttachPts:
          - {className: MatePt, name: LeftSide-Front, ID: 8d23204f-4689-4555-8380-206d51c0a736,
            x: '0', y: '0', z: '0'}
          Connections:
  - Part:
      name: Extruded Right Side Part
      version: 7.2
      description: The right side
      partnumber: 1U Extruded Enclosure Right Side Part
      template: true
      verified: true
      Parser:
        verified: false
        version: 7.2
        Parameters:
      Connections:
      - {className: Relative, parent: Front-RightSide, child: RightSide-Front, rotation: '180',
        virtual: '0.0'}
      Components:
      - Sweep:
          version: 7.2
          verified: false
          Rotation: '0'
          CrossSection:
            CompositePath:
              type: CONSTRUCT
              version: '7.2'
              verified: false
              Parser:
                verified: false
                version: 7.2
                Parameters:
              layer: Default
              pathSegments:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
          SweepPath:
            CompositePath:
              type: CONSTRUCT
              version: '7.2'
              verified: false
              Parser:
                verified: false
                version: 7.2
                Parameters:
              layer: Default
              pathSegments:
          AttachPts:
          - {className: MatePt, name: RightSide-Front, ID: 2310aab7-f9a0-4cde-8085-966e49349438,
            x: '0', y: Height-.14, z: '0'}
          - {className: MatePt, name: Right-Back, ID: e040002b-b13d-412d-8adb-1dc615df8343,
            x: '0', y: Height-.14, z: Length}
          Connections:
  - Part:
      version: 7.2
      description: The Top Cover
      partnumber: 1U Extruded Enclosure Top Part
      template: true
      verified: true
      Parser:
        verified: false
        version: 7.2
        Parameters:
        - {name: TopColor, default: Top Color}
      MetalInfo: {material: MetalType, color: TopColor, thickness: TopBottomThick}
      Connections:
      - {className: Relative, parent: Front-Top, child: Top-Front, rotation: '0',
        virtual: '0.0'}
      Components:
      - RectFace:
          layers: [Default]
          version: 7.2
          verified: true
          pickable: true
          length: Width
          width: Depth
            Origin: [1*(Width+.02+.13), '0']
            xDir: ['-1.0', '0.0']
          AttachPts:
          - {className: MatePt, name: Top-Front, ID: a1edc16f-7628-49e7-a020-3a636cc24e61,
            x: Width/2, y: '0', z: '0', rotationAroundX: '90', rotationAroundY: '180'}
          Connections:
          Attachment2Ds:
          - Rectangle: {width: -1*(.75-.02+.13), height: Depth, type: EXCLUSION, name: exclusion for clamping flange,
              version: 7.2, template: true, verified: true, layer: Default, OriginX: ((1*(Width+.02+.13))+((-1.0)*((((Width-(.75-.02+.13))-(1*(Width+.02+.13)))*(-1.0))-(.75-.02+.13))))+((0.0)*(((0)-(0))*(1.0))),
              OriginY: ((0)+((0.0)*((((Width-(.75-.02+.13))-(1*(Width+.02+.13)))*(-1.0))-(.75-.02+.13))))+((1.0)*(((0)-(0))*(1.0))),
              onBottom: true}
              version: 7.2, template: true, verified: true, layer: Default, OriginX: ((1*(Width+.02+.13))+((-1.0)*((((0)-(1*(Width+.02+.13)))*(-1.0))-(.75-.02+.13))))+((0.0)*(((0)-(0))*(1.0))),
              OriginY: ((0)+((0.0)*((((0)-(1*(Width+.02+.13)))*(-1.0))-(.75-.02+.13))))+((1.0)*(((0)-(0))*(1.0))),
              onBottom: true}
  - Part:
      name: Extruded A Rear Part
      version: 7.2
      description: The rear panel
      partnumber: Extruded A Rear Part
      template: true
      verified: true
      Parser:
        verified: false
        version: 7.2
        Parameters:
        - {name: RearColor, default: Rear Color}
      MetalInfo: {material: MetalType, color: RearColor, thickness: FrontRearThick}
      Connections:
      - {className: Relative, parent: Right-Back, child: Back-Right, rotation: '180',
        virtual: '0.0'}
      Components:
      - PathFace:
          layers: [Default]
          version: 7.2
          verified: true
          pickable: true
          Direct Printing: {Top: false, Bottom: false, Asked Bottom: true, Asked Top: false}
          BaseProfile:
            type: CONSTRUCT
            version: '7.2'
            verified: true
            layer: Default
            pathSegments:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            - CircleArc3:
            invertX: 'true'
            Origin: [Width, Height-.07]
          Components:
          - Bend:
              layers: [Default]
              version: 7.2
              verified: true
              length: FlushLength
              angle: '90'
              irad: BendRad
              kfactor: '0.5'
              Components:
              - RectFace:
                  layers: [Default]
                  version: 7.2
                  exist: '1.0'
                  verified: true
                  length: FlushLength
                  width: FlangeSize
                  Connections:
                  - {className: Seam, parentSide: '2.0', parentSideLoc: FlushLength,
                    childSideLoc: '0'}
              Connections:
          - Bend:
              layers: [Default]
              version: 7.2
              verified: true
              length: FlushLength
              angle: '90'
              irad: BendRad
              kfactor: '0.5'
              Components:
              - RectFace:
                  layers: [Default]
                  version: 7.2
                  exist: '1.0'
                  verified: true
                  length: FlushLength
                  width: FlangeSize
                  Connections:
                    childSideLoc: '0'}
              Connections:
          AttachPts:
          - {className: MatePt, name: Back-Right, ID: a8178e02-fb41-418e-85ed-f207d08cae04,
          Connections:
          Attachment2Ds:
              version: 7.2, ID: a4afd865-99d7-4d0e-b747-5b15d303501b, verified: false,
              layer: Default, OriginX: '1.7203157822499962', OriginY: '0.6814224426759031',
              onBottom: true, scaleFactorY: '-1.0', content: RX-2, fontFamily: Arial,
              version: 7.2, ID: 0ece4359-d09c-4058-b346-953d241bf198, verified: false,
              layer: Default, OriginX: '0.8903785880911377', OriginY: '0.6814224426759031',
              onBottom: true, scaleFactorY: '-1.0', content: TX/RX, fontFamily: Arial,
          - Circle: {radius: '0.12598425196850396', type: CUTOUT, name: circle, version: 7.2,
              ID: fb07c74d-5f92-4a1d-9d02-1a757734c89b, verified: false, layer: Default,
              OriginX: '1.0590551181102366', OriginY: '0.9314645669291337', onBottom: true,
              scaleFactorX: '-1.0', scaleFactorY: '-1.0'}
          - Rectangle: {width: -1*(Width-0.72), height: -1*(0.25), type: EXCLUSION,
              name: exclusion for bottom, version: 7.2, template: true, verified: true,
              layer: Default, OriginX: ((1*(Width))+((-1.0)*(0.36)))+((0.0)*(-0.016 + Height-.134-0.25)),
              onBottom: true}
              name: exclusion for top, version: 7.2, template: true, verified: true,
              layer: Default, OriginX: ((1*(Width))+((-1.0)*(0.36)))+((0.0)*(0.156-.134)),
          - Rectangle: {width: -1*(Width), height: -1*(Height), type: NO_SILK, name: Inside Silk Exclusion,
              version: 7.2, template: true, verified: true, layer: Default, OriginX: ((1*(Width))+((-1.0)*(((0)-(0))*(1.0))))+((0.0)*((((-.07)-(1*(Height-.134)))*(-1.0))-(Height))),
              onBottom: false}
          - CompositePath:
              type: EXCLUSION
              version: '7.2'
              template: true
              verified: true
              layer: Default
              rotation: '180.0'
              OriginX: ((1*(Width))+((-1.0)*(((Width)-(0))*(1.0))))+((0.0)*(((Height-0.139)-(1*(Height-.134)))*(-1.0)))
              onBottom: true
              scaleFactorX: '-1'
              scaleFactorY: '-1'
              pathSegments:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
          - CompositePath:
              type: EXCLUSION
              version: '7.2'
              template: true
              verified: true
              layer: Default
              OriginX: ((1*(Width))+((-1.0)*(((0)-(0))*(1.0))))+((0.0)*(((0)-(1*(Height-.134)))*(-1.0)))
              onBottom: true
              scaleFactorX: '-1'
              scaleFactorY: '-1'
              pathSegments:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
              - CircleArc3:
          - Rectangle: {width: '3.937007874015748', height: '0.07216845166598773',
              type: MASKING, name: rectangle, version: 7.2, ID: dc8c9d22-2060-4698-9643-893bbe7a8cb4,
              verified: false, layer: Default, OriginX: '4.124070859687402', OriginY: '1.0182085504771652',
              onBottom: true, scaleFactorX: '-1.0', scaleFactorY: '-1.0', filled: 'False'}
              ID: 80a431cc-bef4-4481-af9c-8db133e2060c, verified: false, layer: Default,
              OriginX: '0.6023622047244093', OriginY: '0.7424881889763778', onBottom: true,
              ID: b65d9fee-980d-4990-8cfe-a16945f3d029, verified: false, layer: Default,
              OriginX: '1.4566929133858268', OriginY: '0.7424881889763778', onBottom: true,
              ID: 7f27eb58-e5f3-4c75-86fa-e3253d2f73bc, verified: false, layer: Default,
              OriginX: '2.236220472440945', OriginY: '0.7424881889763778', onBottom: true,
              ID: 4847ab7a-c863-4e6e-8e75-8881004f2bd8, verified: false, layer: Default,
              OriginX: '1.8503937007874018', OriginY: '0.9314645669291337', onBottom: true,
              version: 7.2, ID: 5b489129-3c99-4ede-9c2d-66cb13f53416, verified: false,
              layer: Default, OriginX: '1.2512208464210763', OriginY: '0.4288328618449464',
              onBottom: true, scaleFactorY: '-1.0', content: RF-A, fontFamily: Arial,
              fontStyle: Bold, fontSize: '12.0', sizeCorrected: true}
          - Rectangle: {width: '1.7500849529002016', height: '0.036084225832993866',
              ID: 602fd161-0e83-4130-b877-179e313c220f, verified: false, layer: Default,
              OriginX: '2.2856353203002335', OriginY: '0.5250574640662633', onBottom: true,
