USRP Hardware Driver and USRP Manual  Version: 4.0.0.0-147-g6728ec40b
uhd::io_type_t Class Reference
#include <uhd/types/io_type.hpp>
enum  tid_t {
  CUSTOM_TYPE = int('?'), COMPLEX_FLOAT64 = int('d'), COMPLEX_FLOAT32 = int('f'), COMPLEX_INT16 = int('s'),
  COMPLEX_INT8 = int('b')
 io_type_t (tid_t tid)
 io_type_t (size_t size)
Public Attributes
const size_t size
const tid_t tid
The DEPRECATED Input/Output configuration struct: Used to specify the IO type with device send/recv.
Deprecated in favor of streamer interface. Its still in this file for the sake of gr-uhd swig.
◆ tid_t
Built in IO types known to the system.
Enumerator
CUSTOM_TYPE
Custom type (technically unsupported by implementation)
COMPLEX_FLOAT64
Complex floating point (64-bit floats) range [-1.0, +1.0].
COMPLEX_FLOAT32
Complex floating point (32-bit floats) range [-1.0, +1.0].
COMPLEX_INT16
Complex signed integer (16-bit integers) range [-32768, +32767].
COMPLEX_INT8
Complex signed integer (8-bit integers) range [-128, 127].
◆ io_type_t() [1/2]
uhd::io_type_t::io_type_t ( tid_t  tid)
Create an io type from a built-in type id.
tida type id known to the system
◆ io_type_t() [2/2]
uhd::io_type_t::io_type_t ( size_t  size)
Create an io type from attributes. The tid will be set to custom.
sizethe size in bytes
◆ size
const size_t uhd::io_type_t::size
The size of this io type in bytes.
◆ tid
const tid_t uhd::io_type_t::tid
The type id of this io type. Good for using with switch statements.
