config.h
2 // Copyright 2015-2016 Ettus Research LLC
4 //
6 //
7
8 #pragma once
9
10 #ifdef _MSC_VER
11 // Bring in "and", "or", and "not"
12 # include <iso646.h>
13
14 // Define ssize_t
15 # ifndef _SSIZE_T_DEFINED
16 # define _SSIZE_T_DEFINED
17 # include <BaseTsd.h>
18 typedef SSIZE_T ssize_t;
19 # endif /* _SSIZE_T_DEFINED */
21 #endif /* _MSC_VER */
22
23 // Define cross-platform macros
24 #if defined(_MSC_VER)
25 # define UHD_EXPORT __declspec(dllexport)
26 # define UHD_IMPORT __declspec(dllimport)
27 # define UHD_EXPORT_HEADER
28 # define UHD_IMPORT_HEADER
29 # define UHD_INLINE __forceinline
30 # define UHD_DEPRECATED __declspec(deprecated)
31 # define UHD_ALIGNED(x) __declspec(align(x))
32 # define UHD_UNUSED(x) x
33 #elif defined(__MINGW32__)
34 # define UHD_EXPORT __declspec(dllexport)
35 # define UHD_IMPORT __declspec(dllimport)
36 # define UHD_EXPORT_HEADER
37 # define UHD_IMPORT_HEADER
38 # define UHD_INLINE inline
39 # define UHD_DEPRECATED __declspec(deprecated)
40 # define UHD_ALIGNED(x) __declspec(align(x))
41 # define UHD_UNUSED(x) x __attribute__((unused))
42 #elif defined(__clang__)
43 # define UHD_EXPORT __attribute__((visibility("default")))
44 # define UHD_IMPORT __attribute__((visibility("default")))
45 # define UHD_EXPORT_HEADER __attribute__((visibility("default")))
46 # define UHD_IMPORT_HEADER __attribute__((visibility("default")))
47 # define UHD_INLINE inline __attribute__((always_inline))
48 # define UHD_DEPRECATED __attribute__((deprecated))
49 # define UHD_ALIGNED(x) __attribute__((aligned(x)))
50 # define UHD_UNUSED(x) x __attribute__((unused))
51 #elif defined(__GNUC__) && (__GNUC__ >= 4)
52 # define UHD_EXPORT __attribute__((visibility("default")))
53 # define UHD_IMPORT __attribute__((visibility("default")))
54 # define UHD_EXPORT_HEADER __attribute__((visibility("default")))
55 # define UHD_IMPORT_HEADER __attribute__((visibility("default")))
56 # define UHD_INLINE inline __attribute__((always_inline))
57 # define UHD_DEPRECATED __attribute__((deprecated))
58 # define UHD_ALIGNED(x) __attribute__((aligned(x)))
59 # define UHD_UNUSED(x) x __attribute__((unused))
60 #else
61 # define UHD_EXPORT
62 # define UHD_IMPORT
63 # define UHD_EXPORT_HEADER
64 # define UHD_IMPORT_HEADER
65 # define UHD_INLINE inline
66 # define UHD_DEPRECATED
67 # define UHD_ALIGNED(x)
68 # define UHD_UNUSED(x) x
69 #endif
70
71 // Define API declaration macro
72 //
73 // UHD_API should be used for classes/structs that
74 // have a direct cpp implementations that get directly
75 // built into a so/dylib/dll.
76 //
77 // UHD_API_HEADER should be used for classes/structs
78 // that are implemented in header only like hpp/ipp.
79 #ifdef UHD_STATIC_LIB
80 # define UHD_API
81 # define UHD_API_HEADER
82 #else
83 # ifdef UHD_DLL_EXPORTS
84 # define UHD_API UHD_EXPORT
85 # define UHD_API_HEADER UHD_EXPORT_HEADER
86 # else
87 # define UHD_API UHD_IMPORT
88 # define UHD_API_HEADER UHD_IMPORT_HEADER
89 # endif // UHD_DLL_EXPORTS
90 #endif // UHD_STATIC_LIB
91
92 // Platform defines for conditional code:
93 // Taken from boost/config/select_platform_config.hpp,
94 // However, we define macros, not strings, for platforms.
95 #if (defined(linux) || defined(__linux) || defined(__linux__) || defined(__GLIBC__)) \
96  && !defined(_CRAYC) && !defined(__FreeBSD_kernel__) && !defined(__GNU__)
97 # define UHD_PLATFORM_LINUX
98 #elif defined(_WIN32) || defined(__WIN32__) || defined(WIN32)
99 # define UHD_PLATFORM_WIN32
100 #elif defined(macintosh) || defined(__APPLE__) || defined(__APPLE_CC__)
101 # define UHD_PLATFORM_MACOS
102 #elif defined(__FreeBSD__) || defined(__NetBSD__) || defined(__OpenBSD__) \
103  || defined(__FreeBSD_kernel__)
104 # define UHD_PLATFORM_BSD
105 #endif
