Generation 2 USRP Build Documentation
Dependencies and Requirements
Dependencies
The USRP FPGA build system requires a UNIX-like environment with the following dependencies
The N200 will work with the WebPack version of ISE.
Requirements
What FPGA does my USRP have?
  • USRP N200: Spartan® 3A-DSP 1800
  • USRP N210: Spartan® 3A-DSP 3400
Build Instructions
  • Download and install Xilinx ISE 12.2
  • To add xtclsh to the PATH and to setup up the Xilinx build environment run
    • source <install_dir>/Xilinx/12.2/ISE_DS/settings64.sh (64-bit platform)
    • source <install_dir>/Xilinx/12.2/ISE_DS/settings32.sh (32-bit platform)
  • Navigate to usrp2/top/{project} where project is:
    • N2x0: For USRP N200 and USRP N210
  • To build a binary configuration bitstream run make <target> where the target is specific to each product. To get a list of supported targets run make help.
  • The build output will be specific to the product and will be located in the usrp2/top/{project}/build directory. Run make help for more information.
N2x0 Targets and Outputs
Supported Targets
  • N200R3: Builds the USRP N200 Rev 3 design.
  • N200R4: Builds the USRP N200 Rev 4 design.
  • N210R3: Builds the USRP N210 Rev 3 design.
  • N210R4: Builds the USRP N210 Rev 4 design.
Outputs
  • build-<target>/u2plus.bit : Configuration bitstream with header
  • build-<target>/u2plus.bin : Configuration bitstream without header
  • build-<target>/u2plus.syr : Xilinx system report
  • build-<target>/u2plus.twr : Xilinx timing report
Adding DSP logic to Generation 2 products
As part of the USRP FPGA build-framework, there are several convenient places for users to insert custom DSP modules into the transmit and receive chains.
  • Before the DDC module
  • After the DDC module
  • Replace the DDC module
  • Before the DUC module
  • After the DUC module
  • Replace the DUC module
  • As an RX packet engine
  • As an TX packet engine
Customizing the top level makefile
Each USRP device has a makefile associated with it. This makefile contains all of the necessary build rules. When making a customized FPGA design, start by copying the current makefile for your device. Makefiles can be found in usrp2/top/{product}/Makefile
Edit your new makefile:
  • Set BUILD_DIR to a unique directory name
  • Set CUSTOM_SRCS for your verilog sources
  • Set CUSTOM_DEFS (see section below)
Inserting custom modules
CUSTOM_DEFS is a string of space-separate key-value pairs. Set the CUSTOM_DEFS variable so the FPGA fabric glue will substitute your custom modules into the DSP chain.
Example:
CUSTOM_DEFS = "TX_ENG0_MODULE=my_tx_engine RX_ENG0_MODULE=my_rx_engine"
Where my_tx_engine and my_rx_engine are the names of custom verilog modules.
The following module definition keys are possible (X is a DSP number):
  • TX_ENG<X>_MODULE: Set the module for the transmit chain engine.
  • RX_ENG<X>_MODULE: Set the module for the receive chain engine.
  • RX_DSP<X>_MODULE: Set the module for the transmit dsp chain.
  • TX_DSP<X>_MODULE: Set the module for the receive dsp chain.
Examples of custom modules can be found in the Verilog files in usrp2/custom/.
