metadata.h
1 /*
2  * Copyright 2015 Ettus Research
3  * Copyright 2018 Ettus Research, a National Instruments Company
4  *
5  * SPDX-License-Identifier: GPL-3.0-or-later
6  */
7
8 #pragma once
9
10 #include <uhd/config.h>
11 #include <uhd/error.h>
12
13 #include <stdbool.h>
14 #include <stdint.h>
15 #include <stdlib.h>
16 #include <time.h>
18 #ifdef __cplusplus
19 # include <uhd/types/metadata.hpp>
20 # include <string>
21
22 struct uhd_rx_metadata_t
23 {
24  uhd::rx_metadata_t rx_metadata_cpp;
25  std::string last_error;
26 };
27
28 struct uhd_tx_metadata_t
29 {
30  uhd::tx_metadata_t tx_metadata_cpp;
31  std::string last_error;
32 };
33
34 struct uhd_async_metadata_t
35 {
36  uhd::async_metadata_t async_metadata_cpp;
37  std::string last_error;
38 };
39
40 extern "C" {
41 #else
42 struct uhd_rx_metadata_t;
43 struct uhd_tx_metadata_t;
44 struct uhd_async_metadata_t;
45 #endif
46
48
54 typedef struct uhd_rx_metadata_t* uhd_rx_metadata_handle;
55
57
63 typedef struct uhd_tx_metadata_t* uhd_tx_metadata_handle;
64
66
72 typedef struct uhd_async_metadata_t* uhd_async_metadata_handle;
73
75
78 typedef enum {
94
95
98
100
104
107  uhd_rx_metadata_handle h, bool* result_out);
108
111  uhd_rx_metadata_handle h, int64_t* full_secs_out, double* frac_secs_out);
112
115  uhd_rx_metadata_handle h, bool* result_out);
116
119  uhd_rx_metadata_handle h, size_t* fragment_offset_out);
120
123  uhd_rx_metadata_handle h, bool* result_out);
124
127  uhd_rx_metadata_handle h, bool* result_out);
128
131  uhd_rx_metadata_handle h, bool* result_out);
132
134
143  uhd_rx_metadata_handle h, char* pp_string_out, size_t strbuffer_len);
144
148
150
164  uhd_rx_metadata_handle h, char* strerror_out, size_t strbuffer_len);
165
167
181  uhd_rx_metadata_handle h, char* error_out, size_t strbuffer_len);
182
185  bool has_time_spec,
186  int64_t full_secs,
187  double frac_secs,
188  bool start_of_burst,
189  bool end_of_burst);
190
191
193
197
200  uhd_tx_metadata_handle h, bool* result_out);
201
204  uhd_tx_metadata_handle h, int64_t* full_secs_out, double* frac_secs_out);
205
208  uhd_tx_metadata_handle h, bool* result_out);
209
212  uhd_tx_metadata_handle h, bool* result_out);
213
215
224  uhd_tx_metadata_handle h, char* error_out, size_t strbuffer_len);
225
227
230 typedef enum {
246
249
251
255
258  uhd_async_metadata_handle h, size_t* channel_out);
259
262  uhd_async_metadata_handle h, bool* result_out);
263
266  uhd_async_metadata_handle h, int64_t* full_secs_out, double* frac_secs_out);
267
271
274  uhd_async_metadata_handle h, uint32_t user_payload_out[4]);
275
277
286  uhd_async_metadata_handle h, char* error_out, size_t strbuffer_len);
287
288 #ifdef __cplusplus
289 }
290 #endif
Definition: config.h:87
uhd_error
UHD error codes.
Definition: error.h:20
UHD_API uhd_error uhd_async_metadata_has_time_spec(uhd_async_metadata_handle h, bool *result_out)
Has time specification?
UHD_API uhd_error uhd_rx_metadata_make(uhd_rx_metadata_handle *handle)
Create a new RX metadata handle.
UHD_API uhd_error uhd_rx_metadata_end_of_burst(uhd_rx_metadata_handle h, bool *result_out)
End of burst?
UHD_API uhd_error uhd_rx_metadata_last_error(uhd_rx_metadata_handle h, char *error_out, size_t strbuffer_len)
Get the last error logged by the RX metadata object.
UHD_API uhd_error uhd_async_metadata_user_payload(uhd_async_metadata_handle h, uint32_t user_payload_out[4])
Get payload from custom FPGA fabric.
UHD_API uhd_error uhd_tx_metadata_has_time_spec(uhd_tx_metadata_handle h, bool *result_out)
UHD_API uhd_error uhd_rx_metadata_has_time_spec(uhd_rx_metadata_handle h, bool *result_out)
UHD_API uhd_error uhd_async_metadata_channel(uhd_async_metadata_handle h, size_t *channel_out)
Channel number in a MIMO configuration.
UHD_API uhd_error uhd_async_metadata_free(uhd_async_metadata_handle *handle)
Free an async metadata handle.
struct uhd_rx_metadata_t * uhd_rx_metadata_handle
RX metadata interface for describing sent IF data.
Definition: metadata.h:54
UHD_API uhd_error uhd_async_metadata_last_error(uhd_async_metadata_handle h, char *error_out, size_t strbuffer_len)
Get the last error logged by the async metadata object.
UHD_API uhd_error uhd_rx_metadata_error_code(uhd_rx_metadata_handle h, uhd_rx_metadata_error_code_t *error_code_out)
Get the last error state of the RX metadata object.
Error condition on a receive call.
Definition: metadata.h:78
@ UHD_RX_METADATA_ERROR_CODE_TIMEOUT
No packet received, implementation timed out.
Definition: metadata.h:82
@ UHD_RX_METADATA_ERROR_CODE_LATE_COMMAND
A stream command was issued in the past.
Definition: metadata.h:84
@ UHD_RX_METADATA_ERROR_CODE_NONE
No error code associated with this metadata.
Definition: metadata.h:80
@ UHD_RX_METADATA_ERROR_CODE_BAD_PACKET
The packet could not be parsed.
Definition: metadata.h:92
@ UHD_RX_METADATA_ERROR_CODE_OVERFLOW
Overflow or sequence error.
Definition: metadata.h:88
@ UHD_RX_METADATA_ERROR_CODE_BROKEN_CHAIN
Expected another stream command.
Definition: metadata.h:86
@ UHD_RX_METADATA_ERROR_CODE_ALIGNMENT
Multi-channel alignment failed.
Definition: metadata.h:90
UHD_API uhd_error uhd_rx_metadata_fragment_offset(uhd_rx_metadata_handle h, size_t *fragment_offset_out)
Fragmentation offset.
struct uhd_tx_metadata_t * uhd_tx_metadata_handle
TX metadata interface for describing received IF data.
Definition: metadata.h:63
UHD_API uhd_error uhd_tx_metadata_start_of_burst(uhd_tx_metadata_handle h, bool *result_out)
Start of burst?
uhd_async_metadata_event_code_t
The type of event for a receive async message call.
Definition: metadata.h:230
@ UHD_ASYNC_METADATA_EVENT_CODE_UNDERFLOW
An internal send buffer has emptied.
Definition: metadata.h:234
@ UHD_ASYNC_METADATA_EVENT_CODE_SEQ_ERROR_IN_BURST
Packet loss within a burst.
Definition: metadata.h:242
@ UHD_ASYNC_METADATA_EVENT_CODE_USER_PAYLOAD
Some kind of custom user payload.
Definition: metadata.h:244
@ UHD_ASYNC_METADATA_EVENT_CODE_TIME_ERROR
Packet had time that was late.
Definition: metadata.h:238
@ UHD_ASYNC_METADATA_EVENT_CODE_UNDERFLOW_IN_PACKET
Underflow occurred inside a packet.
Definition: metadata.h:240
Packet loss error between host and device.
Definition: metadata.h:236
@ UHD_ASYNC_METADATA_EVENT_CODE_BURST_ACK
A burst was successfully transmitted.
Definition: metadata.h:232
UHD_API uhd_error uhd_rx_metadata_to_pp_string(uhd_rx_metadata_handle h, char *pp_string_out, size_t strbuffer_len)
Return a pretty-print representation of this metadata.
UHD_API uhd_error uhd_rx_metadata_start_of_burst(uhd_rx_metadata_handle h, bool *result_out)
Start of burst?
UHD_API uhd_error uhd_rx_metadata_more_fragments(uhd_rx_metadata_handle h, bool *result_out)
Fragmentation flag.
UHD_API uhd_error uhd_rx_metadata_out_of_sequence(uhd_rx_metadata_handle h, bool *result_out)
Result out of sequence?
UHD_API uhd_error uhd_tx_metadata_end_of_burst(uhd_tx_metadata_handle h, bool *result_out)
End of burst?
UHD_API uhd_error uhd_tx_metadata_time_spec(uhd_tx_metadata_handle h, int64_t *full_secs_out, double *frac_secs_out)
Get time specification.
UHD_API uhd_error uhd_rx_metadata_strerror(uhd_rx_metadata_handle h, char *strerror_out, size_t strbuffer_len)
Get a string representation of the last error state of the RX metadata object.
UHD_API uhd_error uhd_tx_metadata_last_error(uhd_tx_metadata_handle h, char *error_out, size_t strbuffer_len)
Get the last error logged by the TX metadata object.
UHD_API uhd_error uhd_tx_metadata_make(uhd_tx_metadata_handle *handle, bool has_time_spec, int64_t full_secs, double frac_secs, bool start_of_burst, bool end_of_burst)
Create a new TX metadata handle.
struct uhd_async_metadata_t * uhd_async_metadata_handle
Interface for describing transmit-related events.
Definition: metadata.h:72
UHD_API uhd_error uhd_tx_metadata_free(uhd_tx_metadata_handle *handle)
Free an TX metadata handle.
UHD_API uhd_error uhd_async_metadata_make(uhd_async_metadata_handle *handle)
Create a new async metadata handle.
UHD_API uhd_error uhd_async_metadata_time_spec(uhd_async_metadata_handle h, int64_t *full_secs_out, double *frac_secs_out)
UHD_API uhd_error uhd_rx_metadata_free(uhd_rx_metadata_handle *handle)
Free an RX metadata handle.
UHD_API uhd_error uhd_async_metadata_event_code(uhd_async_metadata_handle h, uhd_async_metadata_event_code_t *event_code_out)
Get last event code.
UHD_API uhd_error uhd_rx_metadata_time_spec(uhd_rx_metadata_handle h, int64_t *full_secs_out, double *frac_secs_out)
Time of first sample.
Definition: metadata.hpp:203
Definition: metadata.hpp:23
Definition: metadata.hpp:163
