register_iface.hpp
2 // Copyright 2019 Ettus Research, a National Instruments Brand
5 //
6
7 #pragma once
8
10 #include <uhd/types/time_spec.hpp>
11 #include <boost/optional.hpp>
12 #include <cstdint>
13 #include <functional>
14 #include <memory>
15 #include <optional>
16 #include <vector>
18 namespace uhd { namespace rfnoc {
19
24 {
25  uint32_t end_addr;
26  std::function<void(uint32_t, uint32_t)> poke_fn;
27  std::function<uint32_t(uint32_t)> peek_fn;
28 };
29
49 {
51  uint64_t ctrl_packets_sent = 0;
53  uint64_t ack_packets_received = 0;
55  uint64_t async_packets_received = 0;
57  uint64_t ack_packets_sent = 0;
59  uint64_t ctrl_dropped = 0;
61  uint64_t ctrl_out_of_sequence = 0;
63  ssize_t buffer_fullness = 0;
64
65  std::string UHD_API to_string() const;
66 };
67
78 {
79 public:
80  using sptr = std::shared_ptr<register_iface>;
81
82  virtual ~register_iface() = default;
83
93  std::function<bool(uint32_t addr, const std::vector<uint32_t>& data)>;
94
108  using async_msg_callback_t = std::function<void(
109  uint32_t addr, const std::vector<uint32_t>& data, std::optional<uint64_t>)>;
110
115  using async_msg_callback_legacy_t = std::function<void(
116  uint32_t addr, const std::vector<uint32_t>& data, boost::optional<uint64_t>)>;
117
130  virtual void poke32(uint32_t addr,
131  uint32_t data,
133  bool ack = false) = 0;
134
152  void poke64(uint32_t addr,
153  uint64_t data,
155  bool ack = false)
156  {
157  block_poke32(addr,
158  {uint32_t(data & 0xFFFFFFFF), uint32_t((data >> 32) & 0xFFFFFFFF)},
159  time,
160  ack);
161  }
162
181  virtual void multi_poke32(const std::vector<uint32_t> addrs,
182  const std::vector<uint32_t> data,
184  bool ack = false) = 0;
185
207  virtual void block_poke32(uint32_t first_addr,
208  const std::vector<uint32_t> data,
210  bool ack = false) = 0;
211
233  virtual void burst_poke32(uint32_t addr,
234  const std::vector<uint32_t> data,
236  bool ack = false) = 0;
237
247  virtual uint32_t peek32(uint32_t addr, time_spec_t time = uhd::time_spec_t::ASAP) = 0;
248
264  uint64_t peek64(uint32_t addr, time_spec_t time = uhd::time_spec_t::ASAP)
265  {
266  const auto vals = block_peek32(addr, 2, time);
267  return uint64_t(vals[0]) | (uint64_t(vals[1]) << 32);
268  }
269
290  virtual std::vector<uint32_t> block_peek32(uint32_t first_addr,
291  size_t length,
293
314  virtual std::vector<uint32_t> burst_peek32(
315  uint32_t addr, size_t length, time_spec_t time = uhd::time_spec_t::ASAP) = 0;
316
360  virtual std::optional<uint32_t> poll32(uint32_t addr,
361  uint32_t data,
362  uint32_t mask,
363  time_spec_t timeout,
365  bool ack = false) = 0;
366
367
378  virtual void sleep(time_spec_t duration, bool ack = false) = 0;
379
400
408  virtual void register_async_msg_handler(async_msg_callback_t callback_f) = 0;
409
417  [[deprecated("Prefer std::optional over boost::optional.")]] void
419  {
420  auto wrapper_f = [callback_f](uint32_t addr,
421  const std::vector<uint32_t>& data,
422  std::optional<uint64_t> timestamp) {
423  boost::optional<uint64_t> legacy_timestamp;
424  if (timestamp.has_value()) {
425  legacy_timestamp = timestamp.value();
426  }
427  callback_f(addr, data, legacy_timestamp);
428  };
429  register_async_msg_handler(wrapper_f);
430  }
431
439  virtual void set_policy(const std::string& name, const uhd::device_addr_t& args) = 0;
440
446  virtual uint16_t get_src_epid() const = 0;
447
453  virtual uint16_t get_port_num() const = 0;
454
467  virtual void define_custom_register_space(const uint32_t start_addr,
468  const uint32_t length,
469  std::function<void(uint32_t, uint32_t)> poke_fn,
470  std::function<uint32_t(uint32_t)> peek_fn) = 0;
471
472  virtual register_iface_stats get_stats() const = 0;
473
474 }; // class register_iface
475
476 }} /* namespace uhd::rfnoc */
Definition: device_addr.hpp:39
Definition: register_iface.hpp:78
virtual void register_async_msg_handler(async_msg_callback_t callback_f)=0
virtual void block_poke32(uint32_t first_addr, const std::vector< uint32_t > data, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
uint64_t peek64(uint32_t addr, time_spec_t time=uhd::time_spec_t::ASAP)
Definition: register_iface.hpp:264
virtual void burst_poke32(uint32_t addr, const std::vector< uint32_t > data, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
virtual std::optional< uint32_t > poll32(uint32_t addr, uint32_t data, uint32_t mask, time_spec_t timeout, time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
std::shared_ptr< register_iface > sptr
Definition: register_iface.hpp:80
virtual register_iface_stats get_stats() const =0
virtual void multi_poke32(const std::vector< uint32_t > addrs, const std::vector< uint32_t > data, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
virtual void register_async_msg_validator(async_msg_validator_t callback_f)=0
void register_async_msg_handler(async_msg_callback_legacy_t callback_f)
Definition: register_iface.hpp:418
std::function< bool(uint32_t addr, const std::vector< uint32_t > &data)> async_msg_validator_t
Definition: register_iface.hpp:93
virtual uint16_t get_port_num() const =0
virtual std::vector< uint32_t > block_peek32(uint32_t first_addr, size_t length, time_spec_t time=uhd::time_spec_t::ASAP)=0
std::function< void(uint32_t addr, const std::vector< uint32_t > &data, std::optional< uint64_t >)> async_msg_callback_t
Definition: register_iface.hpp:109
virtual ~register_iface()=default
virtual void set_policy(const std::string &name, const uhd::device_addr_t &args)=0
virtual uint32_t peek32(uint32_t addr, time_spec_t time=uhd::time_spec_t::ASAP)=0
virtual uint16_t get_src_epid() const =0
virtual void define_custom_register_space(const uint32_t start_addr, const uint32_t length, std::function< void(uint32_t, uint32_t)> poke_fn, std::function< uint32_t(uint32_t)> peek_fn)=0
virtual std::vector< uint32_t > burst_peek32(uint32_t addr, size_t length, time_spec_t time=uhd::time_spec_t::ASAP)=0
void poke64(uint32_t addr, uint64_t data, time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)
Definition: register_iface.hpp:152
virtual void sleep(time_spec_t duration, bool ack=false)=0
std::function< void(uint32_t addr, const std::vector< uint32_t > &data, boost::optional< uint64_t >)> async_msg_callback_legacy_t
Definition: register_iface.hpp:116
virtual void poke32(uint32_t addr, uint32_t data, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
Definition: time_spec.hpp:31
static constexpr double ASAP
Definition: time_spec.hpp:34
Definition: config.h:87
Definition: soft_register.hpp:86
Definition: build_info.hpp:12
Definition: register_iface.hpp:24
uint32_t end_addr
Definition: register_iface.hpp:25
Definition: register_iface.hpp:27
Definition: register_iface.hpp:49
Number of control packets dropped (or ACKs not received)
Definition: register_iface.hpp:59
Number of out-of-sequence control packets.
Definition: register_iface.hpp:61
Number of ACK packets received.
Definition: register_iface.hpp:53
Number of async packets received.
Definition: register_iface.hpp:55
The fullness of the buffer in the FPGA, as calculated by the software.
Definition: register_iface.hpp:63
Number of ACK packets sent.
Definition: register_iface.hpp:57
Number of control packets sent.
Definition: register_iface.hpp:51
