Each executable testbench has its own Makefile that automatically pulls in support for all supported simulators. The build infrastructure supports the following simulators:
In general running make <sim_target> will run the simulation and report results in the console. Running make help will print out all supported simulator targets. Currently, the following targets will work:
ipclean: Cleanup all IP intermediate files clean: Cleanup all simulator intermediate files cleanall: Cleanup everything! ip: Generate the IP required for this simulation xsim: Run the simulation using the Xilinx Vivado Simulator xclean: Cleanup Xilinx Vivado Simulator intermediate files vsim: Run the simulation using ModelSim from inside Vivado qsim: Run the simulation using Questa msim: Run the simulation using ModelSim vcom: Run ModelSim/Questa compiler to compile HDL files vclean: Cleanup ModelSim/Questa intermediate files
XSim is the built-in simulator in the Xilinx Vivado toolchain. If you already met the prerequisites for building an FPGA image, then you don't need to install anything else.
Follow these steps to run a testbench:
Run the setupenv.sh script for the USRP product that you are trying to simulate
$ source <repo>/fpga/usrp3/top/<product>/setupenv.sh
This step is required even if the simulation is generic because the toolchain requires an FPGA part number to load simulation models.
Run the simulator specific target
$ make xsim
ModelSim and Questa are third-party simulation tools that are compatible with Vivado and the USRP FPGA build infrastructure.
Use the following one-time setup to install and configure ModelSim on your system
Install the simulator of your choice from the Siemens website. It is recommended that you install it to one of these locations on Linux, depending on your simulator:
/opt/modelsim/opt/questasim/opt/questabaseOn Windows, use the default location for the simulator installer.
Run the setupenv.sh script for the USRP product that you want to simulate:
This step is required even if the simulation is not for a specific device because the toolchain requires an FPGA part number to load simulation models.
If setup was successful, then you should see something like the following:
Setting up X3x0 FPGA build environment (64-bit)... - Vivado: Found (/opt/Xilinx/Vivado/2021.1/bin) - ModelSim/Questa: Found (/opt/modelsim/modeltech/linux_x86_64) - ModelSim/Questa Compiled Libs: Found (/opt/Xilinx/Vivado/2021.1/modelsim) Environment successfully initialized.
If setupenv.sh did not report finding your simulator, then you may need to indicate where it is installed using the --modelsim-path argument:
$ source <repo>/fpga/usrp3/top/<product>/setupenv.sh --modelsim-path=/path/to/modelsim
If setupenv.sh could not find your simulation libraries, then you will need to either build them or set an environment variable to help the tool locate them. To build build the Xilinx simulation libraries, run the following:
$ build_simlibs
This will build the simulation libraries and put them, by default, in the Vivado installation directory. For other options, run:
$ build_simlibs --help
If they have already been built, you can set the SIM_COMPLIBDIR environment variable to point to their location and rerun setupenv.sh.
Follow these steps to run a testbench using ModelSim with Vivado:
$ make vsim
Using this method launches Vivado and uses Vivado to launch ModelSim. This ensures that Xilinx IP is properly included in the simulation.
To run the simulation in the Vivado GUI for debugging, add the GUI option:
$ make vsim GUI=1
To run the simulation using ModelSim natively, the process is the same as above, except use the modelsim make target.
$ make msim
This calls into Vivado only if Xilinx IP needs to be generated. Otherwise it calls ModelSim directly without invoking Vivado. This leads to significantly faster compile and load times for the simulation. However, this method does not work with all testbenches because some Xilinx IP requires special handling by Vivado.
To load the simulation into the ModelSim GUI for debugging, add the GUI option.
$ make msim GUI=1
You may also need to specify special arguments or libraries to use with ModelSim. These can be added using the MODELSIM_ARGS and MODELSIM_LIBS arguments. For example:
$ make msim MODELSIM_ARGS="-t 1fs" MODELSIM_LIBS="secureip xpm"
ARGS are simply appended to the ModelSim vsim command line invocation. LIBS are added to the "-L" vsim command line argument. These can also be added to the Makefile for the testbench.
For Questa, use the qsim target instead of msim. For example:
$ make qsim GUI=1
Because the commands for Questa are very similar to ModelSim, you can also use the msim target with Questa, but this will use the classic GUI and the legacy +acc mode with vopt. +acc mode is no longer recommended with Questa.
To compile your code in ModelSim or Questa, without running the simulation, use the vcom target.
$ make vcom
This can be used to quickly check for syntax errors, or to recompile your code prior to restarting a simulation from within the GUI.
Using the msim/qsim and vcom targets allows for more rapid simulation iterations than when using Vivado.
If running the setupenv.sh script returns an error like the following:
Vivado: Not found! (ERROR.. Builds and simulations will not work)
Then it is possible that Vivado was not installed or it was not installed in the default location. If Vivado is installed in a non-default location, just run the following:
$ source <repo>/fpga/usrp3/top/<product>/setupenv.sh --vivado-path=<PATH>
Setting up a 64-bit FPGA build environment for the USRP-X3x0... - Vivado: Found (/opt/Xilinx/Vivado/2019.1/bin) - ModelSim/Questa: Not found! (WARNING: Simulations with ModelSim/Questa might not work!) Environment successfully initialized.
Or something like this, even when ModelSim or Questa is installed:
Setting up a 64-bit FPGA build environment for the USRP-X3x0... - Vivado: Found (/opt/Xilinx/Vivado/2019.1/bin) Environment successfully initialized.
Then is possible that ModelSim or Questa was not properly installed, or that it was not installed in the default location. If ModelSim or Questa is installed in a non-default location, run the following:
$ source <repo>/fpga/usrp3/top/<product>/setupenv.sh --modelsim-path=<PATH>
Setting up a 64-bit FPGA build environment for the USRP-X3x0... - Vivado: Found (/opt/Xilinx/Vivado/2019.1/bin) - ModelSim/Questa: Found (/opt/modelsim/modeltech/bin) - ModelSim/Questa Compiled Libs: Not found! (Run build_simlibs to generate them.) Environment successfully initialized.
Then you need to build the simulation libraries. To do this, run:
$ build_simlibs
Note that it is okay if some of the Xilinx libraries fail to compile without errors. This is only a problem if you intend to simulate one of those libraries. If not, then those errors can be ignored.
