Version: 3.11.0.HEAD-0-gdca39145
All
Classes
Namespaces
Files
Functions
Variables
Typedefs
Enumerations
Enumerator
Friends
Macros
Pages
config.hpp
1
2
// Copyright 2010-2011,2014-2016 Ettus Research LLC
3
4
// SPDX-License-Identifier: GPL-3.0
5
6
7
#ifndef INCLUDED_UHD_CONFIG_HPP
8
#define INCLUDED_UHD_CONFIG_HPP
9
10
#include <boost/config.hpp>
11
12
#ifdef BOOST_MSVC
13
// suppress warnings
14
//# pragma warning(push)
15
//# pragma warning(disable: 4511) // copy constructor can't not be generated
16
//# pragma warning(disable: 4512) // assignment operator can't not be generated
//# pragma warning(disable: 4100) // unreferenced formal parameter
18
//# pragma warning(disable: 4996) // <symbol> was declared deprecated
19
# pragma warning(disable: 4355) // 'this' : used in base member initializer list
//# pragma warning(disable: 4706) // assignment within conditional expression
21
# pragma warning(disable: 4251) // class 'A<T>' needs to have dll-interface to be used by clients of class 'B'
22
//# pragma warning(disable: 4127) // conditional expression is constant
23
//# pragma warning(disable: 4290) // C++ exception specification ignored except to ...
//# pragma warning(disable: 4180) // qualifier applied to function type has no meaning; ignored
25
# pragma warning(disable: 4275) // non dll-interface class ... used as base for dll-interface class ...
26
//# pragma warning(disable: 4267) // 'var' : conversion from 'size_t' to 'type', possible loss of data
27
//# pragma warning(disable: 4511) // 'class' : copy constructor could not be generated
28
# pragma warning(disable: 4250) // 'class' : inherits 'method' via dominance
29
# pragma warning(disable: 4200) // nonstandard extension used : zero-sized array in struct/union
30
31
// define logical operators
32
#include <ciso646>
33
34
// define ssize_t
35
#include <cstddef>
36
typedef
ptrdiff_t ssize_t;
37
38
#endif //BOOST_MSVC
39
40
//define cross platform attribute macros
41
#if defined(BOOST_MSVC)
42
#define UHD_EXPORT __declspec(dllexport)
43
#define UHD_IMPORT __declspec(dllimport)
44
#define UHD_INLINE __forceinline
45
#define UHD_FORCE_INLINE __forceinline
46
#define UHD_DEPRECATED __declspec(deprecated)
47
#define UHD_ALIGNED(x) __declspec(align(x))
48
#define UHD_UNUSED(x) x
49
#elif defined(__MINGW32__)
50
51
52
#define UHD_INLINE inline
53
#define UHD_FORCE_INLINE inline
54
55
56
#define UHD_UNUSED(x) x __attribute__((unused))
57
#elif defined(__GNUG__) && __GNUG__ >= 4
58
#define UHD_EXPORT __attribute__((visibility("default")))
59
#define UHD_IMPORT __attribute__((visibility("default")))
60
#define UHD_INLINE inline __attribute__((always_inline))
61
#define UHD_FORCE_INLINE inline __attribute__((always_inline))
62
#define UHD_DEPRECATED __attribute__((deprecated))
63
#define UHD_ALIGNED(x) __attribute__((aligned(x)))
64
65
#elif defined(__clang__)
66
67
68
69
70
71
72
73
#else
74
#define UHD_EXPORT
75
#define UHD_IMPORT
76
77
78
79
80
81
#endif
82
83
// Define API declaration macro
84
#ifdef UHD_DLL_EXPORTS
85
#define UHD_API UHD_EXPORT
86
#else
87
#define UHD_API UHD_IMPORT
88
#endif // UHD_DLL_EXPORTS
89
#ifdef UHD_RFNOC_ENABLED
90
#define UHD_RFNOC_API UHD_API
91
#else
92
93
#endif // UHD_RFNOC_ENABLED
94
95
96
// Platform defines for conditional parts of headers:
97
// Taken from boost/config/select_platform_config.hpp,
98
// however, we define macros, not strings for platforms.
99
#if (defined(linux) || defined(__linux) || defined(__linux__) || defined(__GLIBC__)) && !defined(_CRAYC) && !defined(__FreeBSD_kernel__) && !defined(__GNU__)
100
#define UHD_PLATFORM_LINUX
101
#elif defined(_WIN32) || defined(__WIN32__) || defined(WIN32)
102
#define UHD_PLATFORM_WIN32
103
#elif defined(macintosh) || defined(__APPLE__) || defined(__APPLE_CC__)
104
#define UHD_PLATFORM_MACOS
105
#elif defined(__FreeBSD__) || defined(__NetBSD__) || defined(__OpenBSD__) || defined(__FreeBSD_kernel__)
106
#define UHD_PLATFORM_BSD
107
#endif
108
109
// Define 'stringize' preprocessor macros. The stringize macro, XSTR, takes
110
// variable arguments so that it can deal with strings that contain commas.
111
// There are two different versions because MSVC handles this syntax a bit
112
// differently than other compilers.
113
114
#define XSTR(x,...) #x
115
#else
116
#define XSTR(x...) #x
117
#endif
118
119
#define STR(x) XSTR(x)
120
121
#endif
/* INCLUDED_UHD_CONFIG_HPP */
include
uhd
config.hpp
Generated by
1.8.13
