dboard_eeprom.h
4 // SPDX-License-Identifier: GPL-3.0
5 //
6
7 #ifndef INCLUDED_UHD_USRP_DBOARD_EEPROM_H
8 #define INCLUDED_UHD_USRP_DBOARD_EEPROM_H
9
10 #include <uhd/config.h>
11 #include <uhd/error.h>
12
13 #ifdef __cplusplus
15 #include <string>
16
17 struct uhd_dboard_eeprom_t {
18  uhd::usrp::dboard_eeprom_t dboard_eeprom_cpp;
19  std::string last_error;
20 };
21
22 extern "C" {
23 #else
24 struct uhd_dboard_eeprom_t;
25 #endif
26
28
34 typedef struct uhd_dboard_eeprom_t* uhd_dboard_eeprom_handle;
35
38  uhd_dboard_eeprom_handle* h
39 );
40
42
47  uhd_dboard_eeprom_handle* h
48 );
49
52  uhd_dboard_eeprom_handle h,
53  char* id_out,
54  size_t strbuffer_len
55 );
56
59  uhd_dboard_eeprom_handle h,
60  const char* id
61 );
62
65  uhd_dboard_eeprom_handle h,
66  char* serial_out,
67  size_t strbuffer_len
68 );
69
72  uhd_dboard_eeprom_handle h,
73  const char* serial
74 );
75
82  uhd_dboard_eeprom_handle h,
83  int* revision_out
84 );
85
88  uhd_dboard_eeprom_handle h,
89  int revision
90 );
91
94  uhd_dboard_eeprom_handle h,
95  char* error_out,
96  size_t strbuffer_len
97 );
98
99 #ifdef __cplusplus
100 }
101 #endif
102
103 #endif /* INCLUDED_UHD_USRP_DBOARD_EEPROM_H */
UHD_API uhd_error uhd_dboard_eeprom_free(uhd_dboard_eeprom_handle *h)
Safely destroy the given handle.
UHD_API uhd_error uhd_dboard_eeprom_get_serial(uhd_dboard_eeprom_handle h, char *serial_out, size_t strbuffer_len)
Get the daughterboard&#39;s serial.
UHD_API uhd_error uhd_dboard_eeprom_set_revision(uhd_dboard_eeprom_handle h, int revision)
Set the daughterboard&#39;s revision.
uhd_error
UHD error codes.
Definition: error.h:20
UHD_API uhd_error uhd_dboard_eeprom_get_id(uhd_dboard_eeprom_handle h, char *id_out, size_t strbuffer_len)
Get the ID associated with the given daughterboard as a string hex representation.
struct uhd_dboard_eeprom_t * uhd_dboard_eeprom_handle
A C-level interface for interacting with a daughterboard EEPROM.
Definition: dboard_eeprom.h:34
Definition: dboard_eeprom.hpp:17
UHD_API uhd_error uhd_dboard_eeprom_get_revision(uhd_dboard_eeprom_handle h, int *revision_out)
UHD_API uhd_error uhd_dboard_eeprom_set_serial(uhd_dboard_eeprom_handle h, const char *serial)
Set the daughterboard&#39;s serial.
UHD_API uhd_error uhd_dboard_eeprom_make(uhd_dboard_eeprom_handle *h)
Create handle for a USRP daughterboard EEPROM.
Definition: config.h:62
UHD_API uhd_error uhd_dboard_eeprom_set_id(uhd_dboard_eeprom_handle h, const char *id)
Set the daughterboard ID using a string hex representation.
UHD_API uhd_error uhd_dboard_eeprom_last_error(uhd_dboard_eeprom_handle h, char *error_out, size_t strbuffer_len)
Get the last error reported by the handle.
