muxed_zero_copy_if.hpp
2 // Copyright 2016 Ettus Research LLC
4 // SPDX-License-Identifier: GPL-3.0
5 //
6
7 #ifndef INCLUDED_LIBUHD_TRANSPORT_MUXED_ZERO_COPY_IF_HPP
8 #define INCLUDED_LIBUHD_TRANSPORT_MUXED_ZERO_COPY_IF_HPP
9
11 #include <uhd/config.hpp>
12 #include <boost/function.hpp>
13 #include <boost/noncopyable.hpp>
14 #include <stdint.h>
15
16 namespace uhd { namespace transport {
27 class muxed_zero_copy_if : private boost::noncopyable {
28 public:
29  typedef boost::shared_ptr<muxed_zero_copy_if> sptr;
30
41  typedef boost::function<uint32_t(void* buff, size_t size)> stream_classifier_fn;
42
44  virtual ~muxed_zero_copy_if() {}
45
47  virtual zero_copy_if::sptr make_stream(const uint32_t stream_num) = 0;
48
50  virtual void remove_stream(const uint32_t stream_num) = 0;
51
53  virtual size_t get_num_dropped_frames() const = 0;
54
56  static sptr make(zero_copy_if::sptr base_xport, stream_classifier_fn classify_fn, size_t max_streams);
57 };
58
59 }} //namespace uhd::transport
60
61 #endif /* INCLUDED_LIBUHD_TRANSPORT_MUXED_ZERO_COPY_IF_HPP */
Definition: muxed_zero_copy_if.hpp:27
boost::shared_ptr< zero_copy_if > sptr
Definition: zero_copy.hpp:143
virtual dtor
Definition: muxed_zero_copy_if.hpp:44
Definition: build_info.hpp:14
boost::function< uint32_t(void *buff, size_t size)> stream_classifier_fn
Definition: muxed_zero_copy_if.hpp:41
virtual size_t get_num_dropped_frames() const =0
Get number of frames dropped due to unregistered streams.
virtual zero_copy_if::sptr make_stream(const uint32_t stream_num)=0
Make a virtual transport for the specified stream number.
boost::shared_ptr< muxed_zero_copy_if > sptr
Definition: muxed_zero_copy_if.hpp:29
Make a new demuxer from a transport and parameters.
virtual void remove_stream(const uint32_t stream_num)=0
Unregister the stream number. All packets destined to the stream will be dropped. ...
