UHD  003.000.c6c4b01e0
serial.hpp
18 #ifndef INCLUDED_UHD_TYPES_SERIAL_HPP
19 #define INCLUDED_UHD_TYPES_SERIAL_HPP
23 #include <vector>
25 namespace uhd{
26
30  typedef std::vector<boost::uint8_t> byte_vector_t;
31
45  public:
51  virtual void write_i2c(
52  boost::uint8_t addr,
53  const byte_vector_t &buf
54  ) = 0;
55
62  virtual byte_vector_t read_i2c(
63  boost::uint8_t addr,
64  size_t num_bytes
65  ) = 0;
66
73  virtual void write_eeprom(
74  boost::uint8_t addr,
75  boost::uint8_t offset,
76  const byte_vector_t &buf
77  );
78
86  virtual byte_vector_t read_eeprom(
87  boost::uint8_t addr,
88  boost::uint8_t offset,
89  size_t num_bytes
90  );
91  };
92
102  enum edge_t{
103  EDGE_RISE = 'r',
104  EDGE_FALL = 'f'
105  };
106
109
112
117  spi_config_t(edge_t edge = EDGE_RISE);
118  };
119
125  public:
135  virtual boost::uint32_t transact_spi(
136  int which_slave,
137  const spi_config_t &config,
138  boost::uint32_t data,
139  size_t num_bits,
140  bool readback
141  ) = 0;
142
151  virtual boost::uint32_t read_spi(
152  int which_slave,
153  const spi_config_t &config,
154  boost::uint32_t data,
155  size_t num_bits
156  );
157
165  virtual void write_spi(
166  int which_slave,
167  const spi_config_t &config,
168  boost::uint32_t data,
169  size_t num_bits
170  );
171  };
172
173 } //namespace uhd
174
175 #endif /* INCLUDED_UHD_TYPES_SERIAL_HPP */
Definition: serial.hpp:124
Definition: serial.hpp:44
edge_t mosi_edge
on what edge is the mosi data valid?
Definition: serial.hpp:108
Definition: config.hpp:76
Definition: serial.hpp:97
std::vector< boost::uint8_t > byte_vector_t
Definition: serial.hpp:30
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:111
edge_t
Definition: serial.hpp:102
