UHD  003.000.c6c4b01e0
udp_simple.hpp
18 #ifndef INCLUDED_UHD_TRANSPORT_UDP_SIMPLE_HPP
19 #define INCLUDED_UHD_TRANSPORT_UDP_SIMPLE_HPP
22 #include <boost/asio/buffer.hpp>
23 #include <boost/utility.hpp>
25
26 namespace uhd{ namespace transport{
27
28 class UHD_API udp_simple : boost::noncopyable{
29 public:
30  typedef boost::shared_ptr<udp_simple> sptr;
31
33  static const size_t mtu = 1500 - 20 - 8; //default ipv4 mtu - ipv4 header - udp header
34
48  static sptr make_connected(const std::string &addr, const std::string &port);
49
62  static sptr make_broadcast(const std::string &addr, const std::string &port);
63
70  virtual size_t send(const boost::asio::const_buffer &buff) = 0;
71
79  virtual size_t recv(const boost::asio::mutable_buffer &buff, double timeout = 0.1) = 0;
80 };
81
82 }} //namespace
83
84 #endif /* INCLUDED_UHD_TRANSPORT_UDP_SIMPLE_HPP */
Definition: udp_simple.hpp:28
Definition: config.hpp:76
boost::shared_ptr< udp_simple > sptr
Definition: udp_simple.hpp:30
