UHD  003.000.001
multi_usrp.hpp
18 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP
19 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP
22 #include <uhd/device.hpp>
23 #include <uhd/types/ranges.hpp>
24 #include <uhd/types/stream_cmd.hpp>
28 #include <uhd/types/sensors.hpp>
29 #include <uhd/usrp/subdev_spec.hpp>
32 #include <boost/shared_ptr.hpp>
33 #include <boost/utility.hpp>
34 #include <vector>
35
36 namespace uhd{ namespace usrp{
37
84 class UHD_API multi_usrp : boost::noncopyable{
85 public:
86  typedef boost::shared_ptr<multi_usrp> sptr;
87
89  static const size_t ALL_MBOARDS = size_t(~0);
90
92  static const size_t ALL_CHANS = size_t(~0);
93
95  static const std::string ALL_GAINS;
96
102  static sptr make(const device_addr_t &dev_addr);
103
109  virtual device::sptr get_device(void) = 0;
110
111  /*******************************************************************
112  * Mboard methods
113  ******************************************************************/
114
125  virtual void set_master_clock_rate(double rate, size_t mboard = ALL_MBOARDS) = 0;
126
132  virtual double get_master_clock_rate(size_t mboard = 0) = 0;
133
138  virtual std::string get_pp_string(void) = 0;
139
145  virtual std::string get_mboard_name(size_t mboard = 0) = 0;
146
152  virtual time_spec_t get_time_now(size_t mboard = 0) = 0;
153
159  virtual time_spec_t get_time_last_pps(size_t mboard = 0) = 0;
160
172  virtual void set_time_now(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
173
185  virtual void set_time_next_pps(const time_spec_t &time_spec) = 0;
186
202  virtual void set_time_unknown_pps(const time_spec_t &time_spec) = 0;
203
210  virtual bool get_time_synchronized(void) = 0;
211
224  virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan = ALL_CHANS) = 0;
225
233  virtual void set_clock_config(const clock_config_t &clock_config, size_t mboard = ALL_MBOARDS) = 0;
234
238  virtual size_t get_num_mboards(void) = 0;
239
246  virtual sensor_value_t get_mboard_sensor(const std::string &name, size_t mboard = 0) = 0;
247
253  virtual std::vector<std::string> get_mboard_sensor_names(size_t mboard = 0) = 0;
254
259  virtual mboard_iface::sptr get_mboard_iface(size_t mboard) = 0;
260
261  /*******************************************************************
262  * RX methods
263  ******************************************************************/
272  virtual void set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
273
279  virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard = 0) = 0;
280
286  virtual size_t get_rx_num_channels(void) = 0;
287
293  virtual std::string get_rx_subdev_name(size_t chan = 0) = 0;
294
300  virtual void set_rx_rate(double rate, size_t chan = ALL_CHANS) = 0;
301
307  virtual double get_rx_rate(size_t chan = 0) = 0;
308
315  virtual tune_result_t set_rx_freq(
316  const tune_request_t &tune_request, size_t chan = 0
317  ) = 0;
318
324  virtual double get_rx_freq(size_t chan = 0) = 0;
325
331  virtual freq_range_t get_rx_freq_range(size_t chan = 0) = 0;
332
340  virtual void set_rx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
341
343  void set_rx_gain(double gain, size_t chan = 0){
344  return this->set_rx_gain(gain, ALL_GAINS, chan);
345  }
346
354  virtual double get_rx_gain(const std::string &name, size_t chan = 0) = 0;
355
357  double get_rx_gain(size_t chan = 0){
358  return this->get_rx_gain(ALL_GAINS, chan);
359  }
360
368  virtual gain_range_t get_rx_gain_range(const std::string &name, size_t chan = 0) = 0;
369
371  gain_range_t get_rx_gain_range(size_t chan = 0){
372  return this->get_rx_gain_range(ALL_GAINS, chan);
373  }
374
381  virtual std::vector<std::string> get_rx_gain_names(size_t chan = 0) = 0;
382
388  virtual void set_rx_antenna(const std::string &ant, size_t chan = 0) = 0;
389
395  virtual std::string get_rx_antenna(size_t chan = 0) = 0;
396
402  virtual std::vector<std::string> get_rx_antennas(size_t chan = 0) = 0;
403
409  UHD_DEPRECATED bool get_rx_lo_locked(size_t chan = 0){
410  return this->get_rx_sensor("lo_locked", chan).to_bool();
411  }
412
418  virtual void set_rx_bandwidth(double bandwidth, size_t chan = 0) = 0;
419
425  virtual double get_rx_bandwidth(size_t chan = 0) = 0;
426
433  UHD_DEPRECATED double read_rssi(size_t chan = 0){
434  return this->get_rx_sensor("rssi", chan).to_real();
435  }
436
444  virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan = 0) = 0;
445
452  virtual sensor_value_t get_rx_sensor(const std::string &name, size_t chan = 0) = 0;
453
459  virtual std::vector<std::string> get_rx_sensor_names(size_t chan = 0) = 0;
460
461  /*******************************************************************
462  * TX methods
463  ******************************************************************/
472  virtual void set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
473
479  virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard = 0) = 0;
480
486  virtual size_t get_tx_num_channels(void) = 0;
487
493  virtual std::string get_tx_subdev_name(size_t chan = 0) = 0;
494
500  virtual void set_tx_rate(double rate, size_t chan = ALL_CHANS) = 0;
501
507  virtual double get_tx_rate(size_t chan = 0) = 0;
508
515  virtual tune_result_t set_tx_freq(
516  const tune_request_t &tune_request, size_t chan = 0
517  ) = 0;
518
524  virtual double get_tx_freq(size_t chan = 0) = 0;
525
531  virtual freq_range_t get_tx_freq_range(size_t chan = 0) = 0;
532
540  virtual void set_tx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
541
543  void set_tx_gain(double gain, size_t chan = 0){
544  return this->set_tx_gain(gain, ALL_GAINS, chan);
545  }
546
554  virtual double get_tx_gain(const std::string &name, size_t chan = 0) = 0;
555
557  double get_tx_gain(size_t chan = 0){
558  return this->get_tx_gain(ALL_GAINS, chan);
559  }
560
568  virtual gain_range_t get_tx_gain_range(const std::string &name, size_t chan = 0) = 0;
569
571  gain_range_t get_tx_gain_range(size_t chan = 0){
572  return this->get_tx_gain_range(ALL_GAINS, chan);
573  }
574
581  virtual std::vector<std::string> get_tx_gain_names(size_t chan = 0) = 0;
582
588  virtual void set_tx_antenna(const std::string &ant, size_t chan = 0) = 0;
589
595  virtual std::string get_tx_antenna(size_t chan = 0) = 0;
596
602  virtual std::vector<std::string> get_tx_antennas(size_t chan = 0) = 0;
603
609  UHD_DEPRECATED bool get_tx_lo_locked(size_t chan = 0){
610  return this->get_tx_sensor("lo_locked", chan).to_bool();
611  }
612
618  virtual void set_tx_bandwidth(double bandwidth, size_t chan = 0) = 0;
619
625  virtual double get_tx_bandwidth(size_t chan = 0) = 0;
626
634  virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan = 0) = 0;
635
642  virtual sensor_value_t get_tx_sensor(const std::string &name, size_t chan = 0) = 0;
643
649  virtual std::vector<std::string> get_tx_sensor_names(size_t chan = 0) = 0;
650 };
651
652 }}
653
654 #endif /* INCLUDED_UHD_USRP_MULTI_USRP_HPP */
Definition: multi_usrp.hpp:371
Definition: stream_cmd.hpp:46
UHD_DEPRECATED bool get_tx_lo_locked(size_t chan=0)
Definition: multi_usrp.hpp:609
Definition: tune_result.hpp:33
Definition: multi_usrp.hpp:557
#define UHD_DEPRECATED
Definition: config.hpp:68
Definition: multi_usrp.hpp:543
Definition: time_spec.hpp:39
Definition: device.hpp:40
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:86
Definition: multi_usrp.hpp:357
Definition: tune_request.hpp:32
A wildcard gain element name.
Definition: multi_usrp.hpp:95
Definition: config.hpp:76
Definition: sensors.hpp:38
Definition: clock_config.hpp:33
Definition: multi_usrp.hpp:84
boost::shared_ptr< mboard_iface > sptr
Definition: mboard_iface.hpp:38
UHD_DEPRECATED bool get_rx_lo_locked(size_t chan=0)
Definition: multi_usrp.hpp:409
Definition: multi_usrp.hpp:343
Definition: subdev_spec.hpp:71
UHD_DEPRECATED double read_rssi(size_t chan=0)
Definition: multi_usrp.hpp:433
Definition: ranges.hpp:69
Definition: multi_usrp.hpp:571
