UHD  003.001.001
metadata.hpp
18 #ifndef INCLUDED_UHD_TYPES_METADATA_HPP
19 #define INCLUDED_UHD_TYPES_METADATA_HPP
23
24 namespace uhd{
25
34
37
45
52
55
58
73  enum error_code_t {
75  ERROR_CODE_NONE = 0x0,
77  ERROR_CODE_TIMEOUT = 0x1,
79  ERROR_CODE_LATE_COMMAND = 0x2,
81  ERROR_CODE_BROKEN_CHAIN = 0x4,
83  ERROR_CODE_OVERFLOW = 0x8,
85  ERROR_CODE_ALIGNMENT = 0xc,
87  ERROR_CODE_BAD_PACKET = 0xf
88  } error_code;
89  };
90
103
106
109
112
117  tx_metadata_t(void);
118  };
119
125  size_t channel;
126
129
132
138  EVENT_CODE_BURST_ACK = 0x1,
140  EVENT_CODE_UNDERFLOW = 0x2,
142  EVENT_CODE_SEQ_ERROR = 0x4,
144  EVENT_CODE_TIME_ERROR = 0x8,
146  EVENT_CODE_UNDERFLOW_IN_PACKET = 0x10,
148  EVENT_CODE_SEQ_ERROR_IN_BURST = 0x20
149  } event_code;
150  };
151
152 } //namespace uhd
153
154 #endif /* INCLUDED_UHD_TYPES_METADATA_HPP */
time_spec_t time_spec
Time of the first sample.
Definition: metadata.hpp:36
bool end_of_burst
Definition: metadata.hpp:111
Definition: metadata.hpp:105
Definition: time_spec.hpp:39
bool has_time_spec
Has time specification?
Definition: metadata.hpp:128
size_t fragment_offset
Definition: metadata.hpp:51
event_code_t
Definition: metadata.hpp:136
Definition: metadata.hpp:31
Definition: metadata.hpp:96
Definition: config.hpp:76
bool has_time_spec
Definition: metadata.hpp:102
bool start_of_burst
Start of burst will be true for the first packet in the chain.
Definition: metadata.hpp:54
error_code_t
Definition: metadata.hpp:73
bool start_of_burst
Definition: metadata.hpp:108
bool has_time_spec
Definition: metadata.hpp:33
Definition: metadata.hpp:123
size_t channel
The channel number in a mimo configuration.
Definition: metadata.hpp:125
bool more_fragments
Definition: metadata.hpp:44
bool end_of_burst
End of burst will be true for the last packet in the chain.
Definition: metadata.hpp:57
When the async event occurred.
Definition: metadata.hpp:131
