UHD  003.002.000
dboard_base.hpp
18 #ifndef INCLUDED_UHD_USRP_DBOARD_BASE_HPP
19 #define INCLUDED_UHD_USRP_DBOARD_BASE_HPP
22 #include <uhd/wax.hpp>
23 #include <uhd/utils/pimpl.hpp>
25 #include <boost/shared_ptr.hpp>
26 #include <uhd/usrp/dboard_id.hpp>
28
29 namespace uhd{ namespace usrp{
30
45  };
46
51  SUBDEV_PROP_NAME, //ro, std::string
52  SUBDEV_PROP_OTHERS, //ro, prop_names_t
53  SUBDEV_PROP_SENSOR, //ro, sensor_value_t
54  SUBDEV_PROP_SENSOR_NAMES, //ro, prop_names_t
55  SUBDEV_PROP_GAIN, //rw, double
56  SUBDEV_PROP_GAIN_RANGE, //ro, gain_range_t
57  SUBDEV_PROP_GAIN_NAMES, //ro, prop_names_t
58  SUBDEV_PROP_FREQ, //rw, double
59  SUBDEV_PROP_FREQ_RANGE, //ro, freq_range_t
60  SUBDEV_PROP_ANTENNA, //rw, std::string
61  SUBDEV_PROP_ANTENNA_NAMES, //ro, prop_names_t
62  SUBDEV_PROP_CONNECTION, //ro, subdev_conn_t
63  SUBDEV_PROP_ENABLED, //rw, bool
65  SUBDEV_PROP_BANDWIDTH //rw, double
66  };
67
72 class UHD_API dboard_base : boost::noncopyable{
73 public:
74  typedef boost::shared_ptr<dboard_base> sptr;
80  typedef void * ctor_args_t;
81
82  //structors
83  dboard_base(ctor_args_t);
84  virtual ~dboard_base(void);
85
86  //interface
87  virtual void rx_get(const wax::obj &key, wax::obj &val) = 0;
88  virtual void rx_set(const wax::obj &key, const wax::obj &val) = 0;
89  virtual void tx_get(const wax::obj &key, wax::obj &val) = 0;
90  virtual void tx_set(const wax::obj &key, const wax::obj &val) = 0;
91
92 protected:
93  std::string get_subdev_name(void);
94  dboard_iface::sptr get_iface(void);
95  dboard_id_t get_rx_id(void);
96  dboard_id_t get_tx_id(void);
97
98 private:
99  UHD_PIMPL_DECL(impl) _impl;
100 };
101
107 public:
112
113  virtual ~xcvr_dboard_base(void);
114 };
115
121 public:
126
127  virtual ~rx_dboard_base(void);
128
129  //override here so the derived classes cannot
130  void tx_get(const wax::obj &key, wax::obj &val);
131  void tx_set(const wax::obj &key, const wax::obj &val);
132 };
133
139 public:
144
145  virtual ~tx_dboard_base(void);
146
147  //override here so the derived classes cannot
148  void rx_get(const wax::obj &key, wax::obj &val);
149  void rx_set(const wax::obj &key, const wax::obj &val);
150 };
151
152 }} //namespace
153
154 #endif /* INCLUDED_UHD_USRP_DBOARD_BASE_HPP */
Definition: dboard_id.hpp:28
Definition: dboard_base.hpp:41
Definition: dboard_base.hpp:64
Definition: dboard_base.hpp:52
Definition: dboard_base.hpp:57
Definition: dboard_base.hpp:65
Definition: dboard_base.hpp:55
Definition: dboard_base.hpp:53
Definition: config.hpp:76
Definition: dboard_base.hpp:60
Definition: dboard_base.hpp:56
Definition: dboard_base.hpp:120
Definition: dboard_base.hpp:138
Definition: dboard_base.hpp:106
Definition: wax.hpp:64
boost::shared_ptr< dboard_base > sptr
Definition: dboard_base.hpp:74
void * ctor_args_t
Definition: dboard_base.hpp:80
Definition: dboard_base.hpp:51
#define UHD_PIMPL_DECL(_name)
Definition: pimpl.hpp:42
Definition: dboard_base.hpp:43
Definition: dboard_base.hpp:58
Definition: dboard_base.hpp:63
Definition: dboard_base.hpp:54
Definition: dboard_base.hpp:61
Definition: dboard_base.hpp:42
Definition: dboard_base.hpp:59
Definition: dboard_base.hpp:44
subdev_conn_t
Definition: dboard_base.hpp:40
Definition: dboard_base.hpp:62
Definition: dboard_base.hpp:72
subdev_prop_t
Definition: dboard_base.hpp:50
