UHD  003.002.000
serial.hpp
18 #ifndef INCLUDED_UHD_TYPES_SERIAL_HPP
19 #define INCLUDED_UHD_TYPES_SERIAL_HPP
22 #include <boost/shared_ptr.hpp>
24 #include <vector>
25
26 namespace uhd{
27
31  typedef std::vector<boost::uint8_t> byte_vector_t;
32
46  public:
47  typedef boost::shared_ptr<i2c_iface> sptr;
48
54  virtual void write_i2c(
55  boost::uint8_t addr,
56  const byte_vector_t &buf
57  ) = 0;
58
65  virtual byte_vector_t read_i2c(
66  boost::uint8_t addr,
67  size_t num_bytes
68  ) = 0;
69
76  virtual void write_eeprom(
77  boost::uint8_t addr,
78  boost::uint8_t offset,
79  const byte_vector_t &buf
80  );
81
89  virtual byte_vector_t read_eeprom(
90  boost::uint8_t addr,
91  boost::uint8_t offset,
92  size_t num_bytes
93  );
94  };
95
105  enum edge_t{
106  EDGE_RISE = 'r',
107  EDGE_FALL = 'f'
108  };
109
112
115
120  spi_config_t(edge_t edge = EDGE_RISE);
121  };
122
128  public:
129  typedef boost::shared_ptr<spi_iface> sptr;
130
140  virtual boost::uint32_t transact_spi(
141  int which_slave,
142  const spi_config_t &config,
143  boost::uint32_t data,
144  size_t num_bits,
145  bool readback
146  ) = 0;
147
156  virtual boost::uint32_t read_spi(
157  int which_slave,
158  const spi_config_t &config,
159  boost::uint32_t data,
160  size_t num_bits
161  );
162
170  virtual void write_spi(
171  int which_slave,
172  const spi_config_t &config,
173  boost::uint32_t data,
174  size_t num_bits
175  );
176  };
177
182  public:
183  typedef boost::shared_ptr<uart_iface> sptr;
184
190  virtual void write_uart(boost::uint8_t dev, const std::string &buf) = 0;
191
197  virtual std::string read_uart(boost::uint8_t dev) = 0;
198  };
199
200 } //namespace uhd
201
202 #endif /* INCLUDED_UHD_TYPES_SERIAL_HPP */
Definition: serial.hpp:127
Definition: serial.hpp:45
edge_t mosi_edge
on what edge is the mosi data valid?
Definition: serial.hpp:111
Definition: config.hpp:76
Definition: serial.hpp:100
std::vector< boost::uint8_t > byte_vector_t
Definition: serial.hpp:31
boost::shared_ptr< spi_iface > sptr
Definition: serial.hpp:129
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:114
Definition: serial.hpp:181
Definition: serial.hpp:183
edge_t
Definition: serial.hpp:105
boost::shared_ptr< i2c_iface > sptr
Definition: serial.hpp:47
