18 #ifndef INCLUDED_UHD_USRP_DBOARD_IFACE_HPP    19 #define INCLUDED_UHD_USRP_DBOARD_IFACE_HPP    24 #include <boost/shared_ptr.hpp>    25 #include <boost/cstdint.hpp>    29 namespace uhd{
namespace usrp{
    60     typedef boost::shared_ptr<dboard_iface>
sptr;
    71         ATR_REG_IDLE        = int(
'i'),
    72         ATR_REG_TX_ONLY     = int(
't'),
    73         ATR_REG_RX_ONLY     = int(
'r'),
    74         ATR_REG_FULL_DUPLEX = int(
'f')
    97     virtual special_props_t get_special_props(
void) = 0;
   106     virtual void write_aux_dac(
unit_t unit,
aux_dac_t which_dac,
double value) = 0;
   124     virtual void set_pin_ctrl(
   125         unit_t unit, boost::uint16_t value, boost::uint16_t mask = 0xffff
   134     virtual boost::uint16_t get_pin_ctrl(
unit_t unit);
   144     virtual void set_atr_reg(
   145         unit_t unit,
atr_reg_t reg, boost::uint16_t value, boost::uint16_t mask = 0xffff
   164     virtual void set_gpio_ddr(
   165         unit_t unit, boost::uint16_t value, boost::uint16_t mask = 0xffff
   174     virtual boost::uint16_t get_gpio_ddr(
unit_t unit);
   183     virtual void set_gpio_out(
   184         unit_t unit, boost::uint16_t value, boost::uint16_t mask = 0xffff
   193     virtual boost::uint16_t get_gpio_out(
unit_t unit);
   201     virtual void set_gpio_debug(
unit_t unit,
int which) = 0;
   209     virtual boost::uint16_t read_gpio(
unit_t unit) = 0;
   219     virtual void write_spi(
   222         boost::uint32_t data,
   235     virtual boost::uint32_t read_write_spi(
   238         boost::uint32_t data,
   248     virtual void set_clock_rate(
unit_t unit,
double rate) = 0;
   256     virtual double get_clock_rate(
unit_t unit) = 0;
   264     virtual std::vector<double> get_clock_rates(
unit_t unit) = 0;
   272     virtual void set_clock_enabled(
unit_t unit,
bool enb) = 0;
   281     virtual double get_codec_rate(
unit_t unit) = 0;
   286     virtual void _set_pin_ctrl(
unit_t unit, boost::uint16_t value) = 0;
   287     virtual void _set_atr_reg(
unit_t unit,
atr_reg_t reg, boost::uint16_t value) = 0;
   288     virtual void _set_gpio_ddr(
   289     virtual void _set_gpio_out(
aux_adc_t
Definition: dboard_iface.hpp:86
Definition: serial.hpp:45
Definition: config.hpp:76
aux_dac_t
Definition: dboard_iface.hpp:78
Definition: dboard_iface.hpp:58
bool soft_clock_divider
Definition: dboard_iface.hpp:39
Definition: serial.hpp:100
#define UHD_PIMPL_DECL(_name)
Definition: pimpl.hpp:42
Definition: dboard_iface.hpp:32
unit_t
Definition: dboard_iface.hpp:64
bool mangle_i2c_addrs
Definition: dboard_iface.hpp:49
atr_reg_t
possible atr registers
Definition: dboard_iface.hpp:70
