UHD  003.004.002-0-g7f44d838
convert.hpp
18 #ifndef INCLUDED_UHD_CONVERT_HPP
19 #define INCLUDED_UHD_CONVERT_HPP
22 #include <uhd/types/ref_vector.hpp>
24 #include <boost/function.hpp>
25 #include <boost/operators.hpp>
26 #include <string>
27
28 namespace uhd{ namespace convert{
29
31  class converter{
32  public:
33  typedef boost::shared_ptr<converter> sptr;
36
38  virtual void set_scalar(const double) = 0;
39
41  UHD_INLINE void conv(const input_type &in, const output_type &out, const size_t num){
42  if (num != 0) (*this)(in, out, num);
43  }
44
45  private:
47  virtual void operator()(const input_type&, const output_type&, const size_t) = 0;
48  };
49
51  typedef boost::function<converter::sptr(void)> function_type;
52
54  typedef int priority_type;
55
57  struct id_type : boost::equality_comparable<id_type>{
58  std::string input_format;
59  size_t num_inputs;
60  std::string output_format;
61  size_t num_outputs;
62  std::string to_pp_string(void) const;
63  };
64
66  UHD_API bool operator==(const id_type &, const id_type &);
67
75  const id_type &id,
76  const function_type &fcn,
77  const priority_type prio
78  );
79
85  UHD_API function_type get_converter(const id_type &id);
86
93  const std::string &format, const size_t size
94  );
95
97  UHD_API size_t get_bytes_per_item(const std::string &format);
98
99 }} //namespace
100
101 #endif /* INCLUDED_UHD_CONVERT_HPP */
Identify a conversion routine in the registry.
Definition: convert.hpp:57
UHD_API void register_bytes_per_item(const std::string &format, const size_t size)
boost::function< converter::sptr(void)> function_type
Conversion factory function typedef.
Definition: convert.hpp:51
virtual void set_scalar(const double)=0
Set the scale factor (used in floating point conversions)
Convert an item format to a size in bytes.
uhd::ref_vector< const void * > input_type
Definition: convert.hpp:35
A conversion class that implements a conversion from inputs -> outputs.
Definition: convert.hpp:31
Definition: config.hpp:76
Definition: convert.hpp:60
#define UHD_INLINE
Definition: config.hpp:67
The public conversion method to convert inputs -> outputs.
Definition: convert.hpp:41
Definition: ref_vector.hpp:30
int priority_type
Priority of conversion routines.
Definition: convert.hpp:54
size_t num_inputs
Definition: convert.hpp:59
UHD_API void register_converter(const id_type &id, const function_type &fcn, const priority_type prio)
uhd::ref_vector< void * > output_type
Definition: convert.hpp:34
size_t num_outputs
Definition: convert.hpp:61
boost::shared_ptr< converter > sptr
Definition: convert.hpp:33
Definition: convert.hpp:58
