UHD  003.004.002-0-g7f44d838
property_tree.hpp
18 #ifndef INCLUDED_UHD_PROPERTY_TREE_HPP
19 #define INCLUDED_UHD_PROPERTY_TREE_HPP
24 #include <boost/function.hpp>
25 #include <vector>
26
27 namespace uhd{
28
33 template <typename T> class property : boost::noncopyable{
34 public:
35  typedef boost::function<void(const T &)> subscriber_type;
36  typedef boost::function<T(void)> publisher_type;
37  typedef boost::function<T(const T &)> coercer_type;
38
47  virtual property<T> &coerce(const coercer_type &coercer) = 0;
48
58  virtual property<T> &publish(const publisher_type &publisher) = 0;
59
67  virtual property<T> &subscribe(const subscriber_type &subscriber) = 0;
68
73  virtual property<T> &update(void) = 0;
74
82  virtual property<T> &set(const T &value) = 0;
83
90  virtual T get(void) const = 0;
91
97  virtual bool empty(void) const = 0;
98 };
99
107 struct fs_path : std::string{
108  UHD_API fs_path(void);
109  UHD_API fs_path(const char *);
110  UHD_API fs_path(const std::string &);
111  UHD_API std::string leaf(void) const;
112  UHD_API fs_path branch_path(void) const;
113 };
114
115 UHD_API fs_path operator/(const fs_path &, const fs_path &);
116
120 class UHD_API property_tree : boost::noncopyable{
121 public:
122  typedef boost::shared_ptr<property_tree> sptr;
123
125  static sptr make(void);
126
128  virtual sptr subtree(const fs_path &path) const = 0;
129
131  virtual void remove(const fs_path &path) = 0;
132
134  virtual bool exists(const fs_path &path) const = 0;
135
137  virtual std::vector<std::string> list(const fs_path &path) const = 0;
138
140  template <typename T> property<T> &create(const fs_path &path);
141
143  template <typename T> property<T> &access(const fs_path &path);
144
145 private:
147  virtual void _create(const fs_path &path, const boost::shared_ptr<void> &prop) = 0;
148
150  virtual boost::shared_ptr<void> &_access(const fs_path &path) const = 0;
151
152 };
153
154 } //namespace uhd
155
156 #include <uhd/property_tree.ipp>
157
158 #endif /* INCLUDED_UHD_PROPERTY_TREE_HPP */
boost::function< void(const T &)> subscriber_type
Definition: property_tree.hpp:35
virtual property< T > & update(void)=0
Definition: property_tree.hpp:107
Definition: property_tree.hpp:122
virtual property< T > & publish(const publisher_type &publisher)=0
Definition: config.hpp:76
boost::function< T(const T &)> coercer_type
Definition: property_tree.hpp:37
virtual bool empty(void) const =0
virtual property< T > & coerce(const coercer_type &coercer)=0
boost::function< T(void)> publisher_type
Definition: property_tree.hpp:36
virtual property< T > & subscribe(const subscriber_type &subscriber)=0
Definition: property_tree.hpp:120
Definition: property_tree.hpp:33
