UHD  003.004.005-0-g22103c8f
multi_usrp.hpp
18 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP
19 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP
21 //define API capabilities for compile time detection of new features
22 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API
23 #define UHD_USRP_MULTI_USRP_GET_RATES_API
24 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
25 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
26 #define UHD_USRP_MULTI_USRP_BW_RANGE_API
27 #define UHD_USRP_MULTI_USRP_USER_REGS_API
28
29 #include <uhd/config.hpp>
30 #include <uhd/device.hpp>
31 #include <uhd/deprecated.hpp>
32 #include <uhd/types/ranges.hpp>
33 #include <uhd/types/stream_cmd.hpp>
36 #include <uhd/types/sensors.hpp>
37 #include <uhd/usrp/subdev_spec.hpp>
39 #include <boost/shared_ptr.hpp>
40 #include <boost/utility.hpp>
41 #include <complex>
42 #include <string>
43 #include <vector>
44
45 namespace uhd{ namespace usrp{
46
93 class UHD_API multi_usrp : boost::noncopyable{
94 public:
95  typedef boost::shared_ptr<multi_usrp> sptr;
96
98  static const size_t ALL_MBOARDS = size_t(~0);
99
101  static const size_t ALL_CHANS = size_t(~0);
102
104  static const std::string ALL_GAINS;
105
111  static sptr make(const device_addr_t &dev_addr);
112
118  virtual device::sptr get_device(void) = 0;
119
122  return this->get_device()->get_rx_stream(args);
123  }
124
127  return this->get_device()->get_tx_stream(args);
128  }
129
130  /*******************************************************************
131  * Mboard methods
132  ******************************************************************/
133
144  virtual void set_master_clock_rate(double rate, size_t mboard = ALL_MBOARDS) = 0;
145
151  virtual double get_master_clock_rate(size_t mboard = 0) = 0;
152
157  virtual std::string get_pp_string(void) = 0;
158
164  virtual std::string get_mboard_name(size_t mboard = 0) = 0;
165
171  virtual time_spec_t get_time_now(size_t mboard = 0) = 0;
172
178  virtual time_spec_t get_time_last_pps(size_t mboard = 0) = 0;
179
191  virtual void set_time_now(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
192
205  virtual void set_time_next_pps(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
206
222  virtual void set_time_unknown_pps(const time_spec_t &time_spec) = 0;
223
230  virtual bool get_time_synchronized(void) = 0;
231
242  virtual void set_command_time(const uhd::time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
243
249  virtual void clear_command_time(size_t mboard = ALL_MBOARDS) = 0;
250
263  virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan = ALL_CHANS) = 0;
264
273  virtual void set_clock_config(const clock_config_t &clock_config, size_t mboard = ALL_MBOARDS) = 0;
274
283  virtual void set_time_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
284
290  virtual std::string get_time_source(const size_t mboard) = 0;
291
297  virtual std::vector<std::string> get_time_sources(const size_t mboard) = 0;
298
306  virtual void set_clock_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
307
313  virtual std::string get_clock_source(const size_t mboard) = 0;
314
320  virtual std::vector<std::string> get_clock_sources(const size_t mboard) = 0;
321
325  virtual size_t get_num_mboards(void) = 0;
326
333  virtual sensor_value_t get_mboard_sensor(const std::string &name, size_t mboard = 0) = 0;
334
340  virtual std::vector<std::string> get_mboard_sensor_names(size_t mboard = 0) = 0;
341
349  virtual void set_user_register(const boost::uint8_t addr, const boost::uint32_t data, size_t mboard = ALL_MBOARDS) = 0;
350
351  /*******************************************************************
352  * RX methods
353  ******************************************************************/
362  virtual void set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
363
369  virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard = 0) = 0;
370
376  virtual size_t get_rx_num_channels(void) = 0;
377
383  virtual std::string get_rx_subdev_name(size_t chan = 0) = 0;
384
390  virtual void set_rx_rate(double rate, size_t chan = ALL_CHANS) = 0;
391
397  virtual double get_rx_rate(size_t chan = 0) = 0;
398
404  virtual meta_range_t get_rx_rates(size_t chan = 0) = 0;
405
412  virtual tune_result_t set_rx_freq(
413  const tune_request_t &tune_request, size_t chan = 0
414  ) = 0;
415
421  virtual double get_rx_freq(size_t chan = 0) = 0;
422
428  virtual freq_range_t get_rx_freq_range(size_t chan = 0) = 0;
429
437  virtual void set_rx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
438
440  void set_rx_gain(double gain, size_t chan = 0){
441  return this->set_rx_gain(gain, ALL_GAINS, chan);
442  }
443
451  virtual double get_rx_gain(const std::string &name, size_t chan = 0) = 0;
452
454  double get_rx_gain(size_t chan = 0){
455  return this->get_rx_gain(ALL_GAINS, chan);
456  }
457
465  virtual gain_range_t get_rx_gain_range(const std::string &name, size_t chan = 0) = 0;
466
468  gain_range_t get_rx_gain_range(size_t chan = 0){
469  return this->get_rx_gain_range(ALL_GAINS, chan);
470  }
471
478  virtual std::vector<std::string> get_rx_gain_names(size_t chan = 0) = 0;
479
485  virtual void set_rx_antenna(const std::string &ant, size_t chan = 0) = 0;
486
492  virtual std::string get_rx_antenna(size_t chan = 0) = 0;
493
499  virtual std::vector<std::string> get_rx_antennas(size_t chan = 0) = 0;
500
506  UHD_DEPRECATED bool get_rx_lo_locked(size_t chan = 0){
507  return this->get_rx_sensor("lo_locked", chan).to_bool();
508  }
509
515  virtual void set_rx_bandwidth(double bandwidth, size_t chan = 0) = 0;
516
522  virtual double get_rx_bandwidth(size_t chan = 0) = 0;
523
529  virtual meta_range_t get_rx_bandwidth_range(size_t chan = 0) = 0;
530
537  UHD_DEPRECATED double read_rssi(size_t chan = 0){
538  return this->get_rx_sensor("rssi", chan).to_real();
539  }
540
548  virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan = 0) = 0;
549
556  virtual sensor_value_t get_rx_sensor(const std::string &name, size_t chan = 0) = 0;
557
563  virtual std::vector<std::string> get_rx_sensor_names(size_t chan = 0) = 0;
564
577  virtual void set_rx_dc_offset(const bool enb, size_t chan = ALL_CHANS) = 0;
578
586  virtual void set_rx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
587
595  virtual void set_rx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
596
597  /*******************************************************************
598  * TX methods
599  ******************************************************************/
608  virtual void set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
609
615  virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard = 0) = 0;
616
622  virtual size_t get_tx_num_channels(void) = 0;
623
629  virtual std::string get_tx_subdev_name(size_t chan = 0) = 0;
630
636  virtual void set_tx_rate(double rate, size_t chan = ALL_CHANS) = 0;
637
643  virtual double get_tx_rate(size_t chan = 0) = 0;
644
650  virtual meta_range_t get_tx_rates(size_t chan = 0) = 0;
651
658  virtual tune_result_t set_tx_freq(
659  const tune_request_t &tune_request, size_t chan = 0
660  ) = 0;
661
667  virtual double get_tx_freq(size_t chan = 0) = 0;
668
674  virtual freq_range_t get_tx_freq_range(size_t chan = 0) = 0;
675
683  virtual void set_tx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
684
686  void set_tx_gain(double gain, size_t chan = 0){
687  return this->set_tx_gain(gain, ALL_GAINS, chan);
688  }
689
697  virtual double get_tx_gain(const std::string &name, size_t chan = 0) = 0;
698
700  double get_tx_gain(size_t chan = 0){
701  return this->get_tx_gain(ALL_GAINS, chan);
702  }
703
711  virtual gain_range_t get_tx_gain_range(const std::string &name, size_t chan = 0) = 0;
712
714  gain_range_t get_tx_gain_range(size_t chan = 0){
715  return this->get_tx_gain_range(ALL_GAINS, chan);
716  }
717
724  virtual std::vector<std::string> get_tx_gain_names(size_t chan = 0) = 0;
725
731  virtual void set_tx_antenna(const std::string &ant, size_t chan = 0) = 0;
732
738  virtual std::string get_tx_antenna(size_t chan = 0) = 0;
739
745  virtual std::vector<std::string> get_tx_antennas(size_t chan = 0) = 0;
746
752  UHD_DEPRECATED bool get_tx_lo_locked(size_t chan = 0){
753  return this->get_tx_sensor("lo_locked", chan).to_bool();
754  }
755
761  virtual void set_tx_bandwidth(double bandwidth, size_t chan = 0) = 0;
762
768  virtual double get_tx_bandwidth(size_t chan = 0) = 0;
769
775  virtual meta_range_t get_tx_bandwidth_range(size_t chan = 0) = 0;
776
784  virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan = 0) = 0;
785
792  virtual sensor_value_t get_tx_sensor(const std::string &name, size_t chan = 0) = 0;
793
799  virtual std::vector<std::string> get_tx_sensor_names(size_t chan = 0) = 0;
800
807  virtual void set_tx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
808
816  virtual void set_tx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
817
818 };
819
820 }}
821
822 #endif /* INCLUDED_UHD_USRP_MULTI_USRP_HPP */
Definition: multi_usrp.hpp:468
Definition: stream_cmd.hpp:46
UHD_DEPRECATED bool get_tx_lo_locked(size_t chan=0)
Definition: multi_usrp.hpp:752
Definition: tune_result.hpp:29
Definition: multi_usrp.hpp:700
#define UHD_DEPRECATED
Definition: config.hpp:68
Definition: multi_usrp.hpp:686
Definition: time_spec.hpp:39
Definition: device.hpp:40
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:95
Definition: multi_usrp.hpp:454
Definition: tune_request.hpp:32
Definition: stream.hpp:125
A wildcard gain element name.
Definition: multi_usrp.hpp:104
Definition: config.hpp:76
Definition: sensors.hpp:38
Definition: multi_usrp.hpp:93
rx_streamer::sptr get_rx_stream(const stream_args_t &args)
Convenience method to get a RX streamer.
Definition: multi_usrp.hpp:121
Definition: stream.hpp:39
UHD_DEPRECATED bool get_rx_lo_locked(size_t chan=0)
Definition: multi_usrp.hpp:506
Definition: multi_usrp.hpp:440
UHD_DEPRECATED double read_rssi(size_t chan=0)
Definition: multi_usrp.hpp:537
Definition: ranges.hpp:69
Definition: stream.hpp:182
tx_streamer::sptr get_tx_stream(const stream_args_t &args)
Convenience method to get a TX streamer.
Definition: multi_usrp.hpp:126
Definition: multi_usrp.hpp:714
