18 #ifndef INCLUDED_UHD_CONVERT_HPP    19 #define INCLUDED_UHD_CONVERT_HPP    23 #include <boost/shared_ptr.hpp>    24 #include <boost/function.hpp>    25 #include <boost/operators.hpp>    28 namespace uhd{
namespace convert{
    33         typedef boost::shared_ptr<converter>
sptr;
    41         UHD_INLINE void conv(
const input_type &in,
const output_type &out,
const size_t num){
    42             if (num != 0) (*this)(in, out, num);
    47         virtual void operator()(
const input_type&,
const output_type&,
const size_t) = 0;
    57     struct id_type : boost::equality_comparable<id_type>{
    62         std::string to_pp_string(
void)
const;
    76         const function_type &fcn,
    77         const priority_type prio
    88         const priority_type prio = -1
    97         const std::string &format,
const size_t size
 UHD_API function_type get_converter(const id_type &id, const priority_type prio=-1)
Identify a conversion routine in the registry.
Definition: convert.hpp:57
UHD_API void register_bytes_per_item(const std::string &format, const size_t size)
boost::function< converter::sptr(void)> function_type
Conversion factory function typedef.
Definition: convert.hpp:51
virtual void set_scalar(const double)=0
Set the scale factor (used in floating point conversions)
UHD_API size_t get_bytes_per_item(const std::string &format)
Convert an item format to a size in bytes.
uhd::ref_vector< const void * > input_type
Definition: convert.hpp:35
UHD_API bool operator==(const id_type &, const id_type &)
A conversion class that implements a conversion from inputs -> outputs.
Definition: convert.hpp:31
Definition: config.hpp:76
std::string output_format
Definition: convert.hpp:60
#define UHD_INLINE
Definition: config.hpp:67
UHD_INLINE void conv(const input_type &in, const output_type &out, const size_t num)
The public conversion method to convert inputs -> outputs.
Definition: convert.hpp:41
Definition: ref_vector.hpp:30
int priority_type
Priority of conversion routines.
Definition: convert.hpp:54
size_t num_inputs
Definition: convert.hpp:59
UHD_API void register_converter(const id_type &id, const function_type &fcn, const priority_type prio)
uhd::ref_vector< void * > output_type
Definition: convert.hpp:34
size_t num_outputs
Definition: convert.hpp:61
boost::shared_ptr< converter > sptr
Definition: convert.hpp:33
std::string input_format
Definition: convert.hpp:58
