UHD  003.005.003-13-gf4c58120
device.hpp
18 #ifndef INCLUDED_UHD_DEVICE_HPP
19 #define INCLUDED_UHD_DEVICE_HPP
22 #include <uhd/stream.hpp>
23 #include <uhd/deprecated.hpp>
26 #include <boost/shared_ptr.hpp>
27 #include <boost/function.hpp>
28
29 namespace uhd{
30
31 class property_tree; //forward declaration
32
37 class UHD_API device : boost::noncopyable{
38
39 public:
40  typedef boost::shared_ptr<device> sptr;
41  typedef boost::function<device_addrs_t(const device_addr_t &)> find_t;
42  typedef boost::function<sptr(const device_addr_t &)> make_t;
43
50  static void register_device(
51  const find_t &find,
52  const make_t &make
53  );
54
64  static device_addrs_t find(const device_addr_t &hint);
65
77  static sptr make(const device_addr_t &hint, size_t which = 0);
78
80  virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args) = 0;
81
83  virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args) = 0;
84
91  virtual bool recv_async_msg(
92  async_metadata_t &async_metadata, double timeout = 0.1
93  ) = 0;
94
96  virtual boost::shared_ptr<property_tree> get_tree(void) const = 0;
97
98  #include <uhd/device_deprecated.ipp>
99
100 };
101
102 } //namespace uhd
103
104 #endif /* INCLUDED_UHD_DEVICE_HPP */
Definition: device.hpp:40
Definition: stream.hpp:125
Definition: config.hpp:76
std::vector< device_addr_t > device_addrs_t
A typedef for a vector of device addresses.
Definition: device_addr.hpp:88
boost::function< sptr(const device_addr_t &)> make_t
Definition: device.hpp:42
Definition: stream.hpp:39
Definition: metadata.hpp:124
Definition: device.hpp:37
Definition: stream.hpp:182
boost::function< device_addrs_t(const device_addr_t &)> find_t
Definition: device.hpp:41
