18 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP    19 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP    22 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API    23 #define UHD_USRP_MULTI_USRP_GET_RATES_API    24 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API    25 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API    26 #define UHD_USRP_MULTI_USRP_BW_RANGE_API    27 #define UHD_USRP_MULTI_USRP_USER_REGS_API    28 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API    40 #include <boost/shared_ptr.hpp>    41 #include <boost/utility.hpp>    46 namespace uhd{
namespace usrp{
    96     typedef boost::shared_ptr<multi_usrp>
sptr;
    99     static const size_t ALL_MBOARDS = size_t(~0);
   102     static const size_t ALL_CHANS = size_t(~0);
   123         return this->get_device()->get_rx_stream(args);
   128         return this->get_device()->get_tx_stream(args);
   163     virtual void set_master_clock_rate(
double rate,
size_t mboard = ALL_MBOARDS) = 0;
   170     virtual double get_master_clock_rate(
size_t mboard = 0) = 0;
   176     virtual std::string get_pp_string(
void) = 0;
   183     virtual std::string get_mboard_name(
   190     virtual time_spec_t get_time_now(
   197     virtual time_spec_t get_time_last_pps(
   210     virtual void set_time_now(
const time_spec_t &time_spec,
   224     virtual void set_time_next_pps(
   241     virtual void set_time_unknown_pps(
const time_spec_t &time_spec) = 0;
   249     virtual bool get_time_synchronized(
void) = 0;
   261     virtual void set_command_time(
const uhd::time_spec_t &time_spec,
   268     virtual void clear_command_time(
   282     virtual void issue_stream_cmd(
const stream_cmd_t &stream_cmd,
size_t chan = ALL_CHANS) = 0;
   292     virtual void set_clock_config(
const clock_config_t &clock_config,
   302     virtual void set_time_source(
const std::string &source,
const size_t mboard = ALL_MBOARDS) = 0;
   309     virtual std::string get_time_source(
const size_t mboard) = 0;
   316     virtual std::vector<std::string> get_time_sources(
   325     virtual void set_clock_source(
   332     virtual std::string get_clock_source(
   339     virtual std::vector<std::string> get_clock_sources(
   344     virtual size_t get_num_mboards(
void) = 0;
   352     virtual sensor_value_t get_mboard_sensor(
const std::string &name,
   359     virtual std::vector<std::string> get_mboard_sensor_names(
   368     virtual void set_user_register(
const boost::uint8_t addr,
const boost::uint32_t data,
   395     virtual size_t get_rx_num_channels(
void) = 0;
   402     virtual std::string get_rx_subdev_name(
size_t chan = 0) = 0;
   409     virtual void set_rx_rate(
double rate,
   416     virtual double get_rx_rate(
   440     virtual double get_rx_freq(
   447     virtual freq_range_t get_rx_freq_range(
   454     virtual freq_range_t get_fe_rx_freq_range(
   463     virtual void set_rx_gain(
double gain,
   467         return this->set_rx_gain(gain, ALL_GAINS, chan);
   477     virtual double get_rx_gain(
   481         return this->get_rx_gain(ALL_GAINS, chan);
   491     virtual gain_range_t get_rx_gain_range(
   495         return this->get_rx_gain_range(ALL_GAINS, chan);
   504     virtual std::vector<std::string> get_rx_gain_names(
   511     virtual void set_rx_antenna(
const std::string &ant,
   518     virtual std::string get_rx_antenna(
   525     virtual std::vector<std::string> get_rx_antennas(
   533         return this->get_rx_sensor(
"lo_locked", chan).to_bool();
   541     virtual void set_rx_bandwidth(
double bandwidth,
   548     virtual double get_rx_bandwidth(
   555     virtual meta_range_t get_rx_bandwidth_range(
   564         return this->get_rx_sensor(
"rssi", chan).to_real();
   582     virtual sensor_value_t get_rx_sensor(
   589     virtual std::vector<std::string> get_rx_sensor_names(
   603     virtual void set_rx_dc_offset(
const bool enb,
   612     virtual void set_rx_dc_offset(
const std::complex<double> &offset,
   621     virtual void set_rx_iq_balance(
const std::complex<double> &correction,
   648     virtual size_t get_tx_num_channels(
void) = 0;
   655     virtual std::string get_tx_subdev_name(
   662     virtual void set_tx_rate(
double rate,
   669     virtual double get_tx_rate(
   693     virtual double get_tx_freq(
   700     virtual freq_range_t get_tx_freq_range(
   707     virtual freq_range_t get_fe_tx_freq_range(
   716     virtual void set_tx_gain(
double gain,
   720         return this->set_tx_gain(gain, ALL_GAINS, chan);
   730     virtual double get_tx_gain(
   734         return this->get_tx_gain(ALL_GAINS, chan);
   744     virtual gain_range_t get_tx_gain_range(
   748         return this->get_tx_gain_range(ALL_GAINS, chan);
   757     virtual std::vector<std::string> get_tx_gain_names(
   764     virtual void set_tx_antenna(
   771     virtual std::string get_tx_antenna(
   778     virtual std::vector<std::string> get_tx_antennas(
   786         return this->get_tx_sensor(
   794     virtual void set_tx_bandwidth(
double bandwidth,
   801     virtual double get_tx_bandwidth(
   808     virtual meta_range_t get_tx_bandwidth_range(
   825     virtual sensor_value_t get_tx_sensor(
   832     virtual std::vector<std::string> get_tx_sensor_names(
   840     virtual void set_tx_dc_offset(
   849     virtual void set_tx_iq_balance(
Definition: multi_usrp.hpp:494
Definition: stream_cmd.hpp:46
UHD_DEPRECATED bool get_tx_lo_locked(size_t chan=0)
Definition: multi_usrp.hpp:785
Definition: tune_result.hpp:29
Definition: multi_usrp.hpp:733
#define UHD_DEPRECATED
Definition: config.hpp:68
Definition: multi_usrp.hpp:719
Definition: time_spec.hpp:39
Definition: device.hpp:40
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:96
Definition: multi_usrp.hpp:480
Definition: tune_request.hpp:32
Definition: stream.hpp:125
static const std::string ALL_GAINS
A wildcard gain element name.
Definition: multi_usrp.hpp:105
Definition: config.hpp:76
Definition: sensors.hpp:38
Definition: multi_usrp.hpp:94
rx_streamer::sptr get_rx_stream(const stream_args_t &args)
Convenience method to get a RX streamer.
Definition: multi_usrp.hpp:122
Definition: stream.hpp:39
UHD_DEPRECATED bool get_rx_lo_locked(size_t chan=0)
Definition: multi_usrp.hpp:532
Definition: multi_usrp.hpp:466
UHD_DEPRECATED double read_rssi(size_t chan=0)
Definition: multi_usrp.hpp:563
Definition: stream.hpp:182
tx_streamer::sptr get_tx_stream(const stream_args_t &args)
Convenience method to get a TX streamer.
Definition: multi_usrp.hpp:127
Definition: multi_usrp.hpp:747
