003.005.004-0-ga219f16c
This is the complete list of members for uhd::usrp::dboard_iface, including all inherited members.
| ATR_REG_FULL_DUPLEX enum value | uhd::usrp::dboard_iface | |
| ATR_REG_IDLE enum value | uhd::usrp::dboard_iface | |
| ATR_REG_RX_ONLY enum value | uhd::usrp::dboard_iface | |
| atr_reg_t enum name | uhd::usrp::dboard_iface | |
| ATR_REG_TX_ONLY enum value | uhd::usrp::dboard_iface | |
| AUX_ADC_A enum value | uhd::usrp::dboard_iface | |
| AUX_ADC_B enum value | uhd::usrp::dboard_iface | |
| aux_adc_t enum name | uhd::usrp::dboard_iface | |
| AUX_DAC_A enum value | uhd::usrp::dboard_iface | |
| AUX_DAC_B enum value | uhd::usrp::dboard_iface | |
| AUX_DAC_C enum value | uhd::usrp::dboard_iface | |
| AUX_DAC_D enum value | uhd::usrp::dboard_iface | |
| aux_dac_t enum name | uhd::usrp::dboard_iface | |
| dboard_iface(void) | uhd::usrp::dboard_iface | protected |
| get_atr_reg(unit_t unit, atr_reg_t reg) | uhd::usrp::dboard_iface | virtual |
| get_clock_rate(unit_t unit)=0 | uhd::usrp::dboard_iface | pure virtual |
| get_clock_rates(unit_t unit)=0 | uhd::usrp::dboard_iface | pure virtual |
| get_codec_rate(unit_t unit)=0 | uhd::usrp::dboard_iface | pure virtual |
| get_gpio_ddr(unit_t unit) | uhd::usrp::dboard_iface | virtual |
| get_gpio_out(unit_t unit) | uhd::usrp::dboard_iface | virtual |
| get_pin_ctrl(unit_t unit) | uhd::usrp::dboard_iface | virtual |
| get_special_props(void)=0 | uhd::usrp::dboard_iface | pure virtual |
| read_aux_adc(unit_t unit, aux_adc_t which_adc)=0 | uhd::usrp::dboard_iface | pure virtual |
| read_eeprom(boost::uint8_t addr, boost::uint8_t offset, size_t num_bytes) | uhd::i2c_iface | virtual |
| read_gpio(unit_t unit)=0 | uhd::usrp::dboard_iface | pure virtual |
| read_i2c(boost::uint8_t addr, size_t num_bytes)=0 | uhd::i2c_iface | pure virtual |
| read_write_spi(unit_t unit, const spi_config_t &config, boost::uint32_t data, size_t num_bits)=0 | uhd::usrp::dboard_iface | pure virtual |
| set_atr_reg(unit_t unit, atr_reg_t reg, boost::uint16_t value, boost::uint16_t mask=0xffff) | uhd::usrp::dboard_iface | virtual |
| set_clock_enabled(unit_t unit, bool enb)=0 | uhd::usrp::dboard_iface | pure virtual |
| set_clock_rate(unit_t unit, double rate)=0 | uhd::usrp::dboard_iface | pure virtual |
| set_gpio_ddr(unit_t unit, boost::uint16_t value, boost::uint16_t mask=0xffff) | uhd::usrp::dboard_iface | virtual |
| set_gpio_debug(unit_t unit, int which)=0 | uhd::usrp::dboard_iface | pure virtual |
| set_gpio_out(unit_t unit, boost::uint16_t value, boost::uint16_t mask=0xffff) | uhd::usrp::dboard_iface | virtual |
| set_pin_ctrl(unit_t unit, boost::uint16_t value, boost::uint16_t mask=0xffff) | uhd::usrp::dboard_iface | virtual |
| special_props_t typedef | uhd::usrp::dboard_iface | |
| sptr typedef | uhd::usrp::dboard_iface | |
| UNIT_RX enum value | uhd::usrp::dboard_iface | |
| unit_t enum name | uhd::usrp::dboard_iface | |
| UNIT_TX enum value | uhd::usrp::dboard_iface | |
| write_aux_dac(unit_t unit, aux_dac_t which_dac, double value)=0 | uhd::usrp::dboard_iface | pure virtual |
| write_eeprom(boost::uint8_t addr, boost::uint8_t offset, const byte_vector_t &buf) | uhd::i2c_iface | virtual |
| write_i2c(boost::uint8_t addr, const byte_vector_t &buf)=0 | uhd::i2c_iface | pure virtual |
1.8.13
