UHD  003.005.005-0-g3c6a906c
config.hpp
18 #ifndef INCLUDED_UHD_CONFIG_HPP
19 #define INCLUDED_UHD_CONFIG_HPP
21 #include <boost/config.hpp>
22
23 #ifdef BOOST_MSVC
24 // suppress warnings
25 //# pragma warning(push)
26 //# pragma warning(disable: 4511) // copy constructor can't not be generated
27 //# pragma warning(disable: 4512) // assignment operator can't not be generated
28 //# pragma warning(disable: 4100) // unreferenced formal parameter
29 //# pragma warning(disable: 4996) // <symbol> was declared deprecated
30 # pragma warning(disable: 4355) // 'this' : used in base member initializer list
31 //# pragma warning(disable: 4706) // assignment within conditional expression
32 # pragma warning(disable: 4251) // class 'A<T>' needs to have dll-interface to be used by clients of class 'B'
33 //# pragma warning(disable: 4127) // conditional expression is constant
34 //# pragma warning(disable: 4290) // C++ exception specification ignored except to ...
35 //# pragma warning(disable: 4180) // qualifier applied to function type has no meaning; ignored
36 # pragma warning(disable: 4275) // non dll-interface class ... used as base for dll-interface class ...
37 //# pragma warning(disable: 4267) // 'var' : conversion from 'size_t' to 'type', possible loss of data
38 //# pragma warning(disable: 4511) // 'class' : copy constructor could not be generated
39 //# pragma warning(disable: 4250) // 'class' : inherits 'method' via dominance
40 # pragma warning(disable: 4200) // nonstandard extension used : zero-sized array in struct/union
41
42 // define logical operators
43 #include <ciso646>
44
45 // define ssize_t
46 #include <cstddef>
47 typedef ptrdiff_t ssize_t;
48
49 #endif //BOOST_MSVC
50
51 //define cross platform attribute macros
52 #if defined(BOOST_MSVC)
53  #define UHD_EXPORT __declspec(dllexport)
54  #define UHD_IMPORT __declspec(dllimport)
55  #define UHD_INLINE __forceinline
56  #define UHD_DEPRECATED __declspec(deprecated)
57  #define UHD_ALIGNED(x) __declspec(align(x))
58 #elif defined(__GNUG__) && __GNUG__ >= 4
59  #define UHD_EXPORT __attribute__((visibility("default")))
60  #define UHD_IMPORT __attribute__((visibility("default")))
61  #define UHD_INLINE inline __attribute__((always_inline))
62  #define UHD_DEPRECATED __attribute__((deprecated))
63  #define UHD_ALIGNED(x) __attribute__((aligned(x)))
64 #else
65  #define UHD_EXPORT
66  #define UHD_IMPORT
67  #define UHD_INLINE inline
68  #define UHD_DEPRECATED
69  #define UHD_ALIGNED(x)
70 #endif
71
72 // Define API declaration macro
73 #ifdef UHD_DLL_EXPORTS
74  #define UHD_API UHD_EXPORT
75 #else
76  #define UHD_API UHD_IMPORT
77 #endif // UHD_DLL_EXPORTS
78
79 // Platform defines for conditional parts of headers:
80 // Taken from boost/config/select_platform_config.hpp,
81 // however, we define macros, not strings for platforms.
82 #if defined(linux) || defined(__linux) || defined(__linux__)
83  #define UHD_PLATFORM_LINUX
84 #elif defined(_WIN32) || defined(__WIN32__) || defined(WIN32)
85  #define UHD_PLATFORM_WIN32
86 #elif defined(macintosh) || defined(__APPLE__) || defined(__APPLE_CC__)
87  #define UHD_PLATFORM_MACOS
88 #elif defined(__FreeBSD__) || defined(__NetBSD__) || defined(__OpenBSD__)
89  #define UHD_PLATFORM_BSD
90 #endif
91
92 #endif /* INCLUDED_UHD_CONFIG_HPP */
