UHD  003.006.000-0-g58f4af97
metadata.hpp
18 #ifndef INCLUDED_UHD_TYPES_METADATA_HPP
19 #define INCLUDED_UHD_TYPES_METADATA_HPP
25 namespace uhd{
26
35
38
46
53
56
59
74  enum error_code_t {
76  ERROR_CODE_NONE = 0x0,
78  ERROR_CODE_TIMEOUT = 0x1,
80  ERROR_CODE_LATE_COMMAND = 0x2,
82  ERROR_CODE_BROKEN_CHAIN = 0x4,
84  ERROR_CODE_OVERFLOW = 0x8,
86  ERROR_CODE_ALIGNMENT = 0xc,
88  ERROR_CODE_BAD_PACKET = 0xf
89  } error_code;
90  };
91
104
107
110
113
118  tx_metadata_t(void);
119  };
120
126  size_t channel;
127
130
133
139  EVENT_CODE_BURST_ACK = 0x1,
141  EVENT_CODE_UNDERFLOW = 0x2,
143  EVENT_CODE_SEQ_ERROR = 0x4,
145  EVENT_CODE_TIME_ERROR = 0x8,
147  EVENT_CODE_UNDERFLOW_IN_PACKET = 0x10,
149  EVENT_CODE_SEQ_ERROR_IN_BURST = 0x20,
151  EVENT_CODE_USER_PAYLOAD = 0x40
152  } event_code;
153
157  boost::uint32_t user_payload[4];
158
159  };
160
161 } //namespace uhd
162
163 #endif /* INCLUDED_UHD_TYPES_METADATA_HPP */
time_spec_t time_spec
Time of the first sample.
Definition: metadata.hpp:37
bool end_of_burst
Definition: metadata.hpp:112
Definition: metadata.hpp:106
Definition: time_spec.hpp:39
bool has_time_spec
Has time specification?
Definition: metadata.hpp:129
size_t fragment_offset
Definition: metadata.hpp:52
event_code_t
Definition: metadata.hpp:137
Definition: metadata.hpp:32
Definition: metadata.hpp:97
Definition: config.hpp:76
bool has_time_spec
Definition: metadata.hpp:103
bool start_of_burst
Start of burst will be true for the first packet in the chain.
Definition: metadata.hpp:55
error_code_t
Definition: metadata.hpp:74
bool start_of_burst
Definition: metadata.hpp:109
bool has_time_spec
Definition: metadata.hpp:34
Definition: metadata.hpp:124
size_t channel
The channel number in a mimo configuration.
Definition: metadata.hpp:126
bool more_fragments
Definition: metadata.hpp:45
bool end_of_burst
End of burst will be true for the last packet in the chain.
Definition: metadata.hpp:58
When the async event occurred.
Definition: metadata.hpp:132
