UHD  003.006.000-0-g58f4af97
udp_simple.hpp
18 #ifndef INCLUDED_UHD_TRANSPORT_UDP_SIMPLE_HPP
19 #define INCLUDED_UHD_TRANSPORT_UDP_SIMPLE_HPP
22 #include <uhd/types/serial.hpp>
23 #include <boost/asio/buffer.hpp>
25 #include <boost/shared_ptr.hpp>
26
27 namespace uhd{ namespace transport{
28
29 class UHD_API udp_simple : boost::noncopyable{
30 public:
31  typedef boost::shared_ptr<udp_simple> sptr;
32
34  static const size_t mtu = 1500 - 20 - 8; //default ipv4 mtu - ipv4 header - udp header
35
49  static sptr make_connected(const std::string &addr, const std::string &port);
50
63  static sptr make_broadcast(const std::string &addr, const std::string &port);
64
70  static uart_iface::sptr make_uart(sptr udp);
71
78  virtual size_t send(const boost::asio::const_buffer &buff) = 0;
79
87  virtual size_t recv(const boost::asio::mutable_buffer &buff, double timeout = 0.1) = 0;
88
93  virtual std::string get_recv_addr(void) = 0;
94 };
95
96 }} //namespace
97
98 #endif /* INCLUDED_UHD_TRANSPORT_UDP_SIMPLE_HPP */
Definition: udp_simple.hpp:29
Definition: config.hpp:76
Definition: serial.hpp:190
boost::shared_ptr< udp_simple > sptr
Definition: udp_simple.hpp:31
