UHD  003.006.000-0-g7788c692
msg_task.hpp
2 // Copyright 2011-2013 Ettus Research LLC
18 #ifndef INCLUDED_UHD_UTILS_MSG_TASK_HPP
19 #define INCLUDED_UHD_UTILS_MSG_TASK_HPP
24 #include <boost/function.hpp>
26 #include <boost/optional/optional.hpp>
27 #include <vector>
28
29 namespace uhd{
30  class UHD_API msg_task : boost::noncopyable{
31  public:
32  typedef boost::shared_ptr<msg_task> sptr;
33  typedef std::vector<uint8_t> msg_payload_t;
34  typedef std::pair<uint32_t, msg_payload_t > msg_type_t;
35  typedef boost::function<boost::optional<msg_type_t>(void)> task_fcn_type;
36
37  /*
38  * During shutdown message queues for radio control cores might not be available anymore.
39  * Such stranded messages get pushed into a dump queue.
40  * With this function radio_ctrl_core can check if one of the messages meant for it got stranded.
41  */
42  virtual msg_payload_t get_msg_from_dump_queue(boost::uint32_t sid) = 0;
43
44  inline static std::vector<uint8_t> buff_to_vector(uint8_t* p, size_t n) {
45  if(p and n > 0){
46  std::vector<uint8_t> v(n);
47  memcpy(&v.front(), p, n);
48  return v;
49  }
50  return std::vector<uint8_t>();
51  }
52
69  static sptr make(const task_fcn_type &task_fcn);
70  };
71 } //namespace uhd
72
73 #endif /* INCLUDED_UHD_UTILS_MSG_TASK_HPP */
74
boost::shared_ptr< msg_task > sptr
Definition: msg_task.hpp:32
std::vector< uint8_t > msg_payload_t
Definition: msg_task.hpp:33
boost::function< boost::optional< msg_type_t >void)> task_fcn_type
Definition: msg_task.hpp:35
Definition: msg_task.hpp:30
Definition: config.hpp:76
std::pair< uint32_t, msg_payload_t > msg_type_t
Definition: msg_task.hpp:34
static std::vector< uint8_t > buff_to_vector(uint8_t *p, size_t n)
Definition: msg_task.hpp:44
