UHD  003.007.000-0-g7fef199d
udp_zero_copy.hpp
18 #ifndef INCLUDED_UHD_TRANSPORT_UDP_ZERO_COPY_HPP
19 #define INCLUDED_UHD_TRANSPORT_UDP_ZERO_COPY_HPP
25
26 namespace uhd{ namespace transport{
27
38 class UHD_API udp_zero_copy : public virtual zero_copy_if{
39 public:
40  struct buff_params {
43  };
44
45  typedef boost::shared_ptr<udp_zero_copy> sptr;
46
61  static sptr make(
62  const std::string &addr,
63  const std::string &port,
64  const zero_copy_xport_params &default_buff_args,
65  udp_zero_copy::buff_params& buff_params_out,
66  const device_addr_t &hints = device_addr_t()
67  );
68 };
69
70 }} //namespace
71
72 #endif /* INCLUDED_UHD_TRANSPORT_UDP_ZERO_COPY_HPP */
boost::shared_ptr< udp_zero_copy > sptr
Definition: udp_zero_copy.hpp:45
Definition: zero_copy.hpp:140
Definition: udp_zero_copy.hpp:40
Definition: config.hpp:79
size_t send_buff_size
Definition: udp_zero_copy.hpp:42
Definition: udp_zero_copy.hpp:38
size_t recv_buff_size
Definition: udp_zero_copy.hpp:41
Definition: zero_copy.hpp:152
