UHD  003.007.001-0-g8f46b048
multi_usrp.hpp
18 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP
19 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP
21 //define API capabilities for compile time detection of new features
22 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API
23 #define UHD_USRP_MULTI_USRP_GET_RATES_API
24 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
25 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
26 #define UHD_USRP_MULTI_USRP_BW_RANGE_API
27 #define UHD_USRP_MULTI_USRP_USER_REGS_API
28 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
29
30 #include <uhd/config.hpp>
31 #include <uhd/device.hpp>
32 #include <uhd/deprecated.hpp>
33 #include <uhd/types/ranges.hpp>
34 #include <uhd/types/stream_cmd.hpp>
37 #include <uhd/types/sensors.hpp>
38 #include <uhd/usrp/subdev_spec.hpp>
40 #include <boost/shared_ptr.hpp>
41 #include <boost/utility.hpp>
42 #include <complex>
43 #include <string>
44 #include <vector>
45
46 namespace uhd{ namespace usrp{
47
94 class UHD_API multi_usrp : boost::noncopyable{
95 public:
96  typedef boost::shared_ptr<multi_usrp> sptr;
97
99  static const size_t ALL_MBOARDS = size_t(~0);
100
102  static const size_t ALL_CHANS = size_t(~0);
103
105  static const std::string ALL_GAINS;
106
112  static sptr make(const device_addr_t &dev_addr);
113
119  virtual device::sptr get_device(void) = 0;
120
122  virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args) = 0;
123
125  virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args) = 0;
126
134  virtual dict<std::string, std::string> get_usrp_rx_info(size_t chan = 0) = 0;
135
143  virtual dict<std::string, std::string> get_usrp_tx_info(size_t chan = 0) = 0;
144
145  /*******************************************************************
146  * Mboard methods
147  ******************************************************************/
148
159  virtual void set_master_clock_rate(double rate, size_t mboard = ALL_MBOARDS) = 0;
160
166  virtual double get_master_clock_rate(size_t mboard = 0) = 0;
167
172  virtual std::string get_pp_string(void) = 0;
173
179  virtual std::string get_mboard_name(size_t mboard = 0) = 0;
180
186  virtual time_spec_t get_time_now(size_t mboard = 0) = 0;
187
193  virtual time_spec_t get_time_last_pps(size_t mboard = 0) = 0;
194
206  virtual void set_time_now(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
207
220  virtual void set_time_next_pps(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
221
237  virtual void set_time_unknown_pps(const time_spec_t &time_spec) = 0;
238
245  virtual bool get_time_synchronized(void) = 0;
246
257  virtual void set_command_time(const uhd::time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
258
264  virtual void clear_command_time(size_t mboard = ALL_MBOARDS) = 0;
265
278  virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan = ALL_CHANS) = 0;
279
288  virtual void set_clock_config(const clock_config_t &clock_config, size_t mboard = ALL_MBOARDS) = 0;
289
298  virtual void set_time_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
299
305  virtual std::string get_time_source(const size_t mboard) = 0;
306
312  virtual std::vector<std::string> get_time_sources(const size_t mboard) = 0;
313
321  virtual void set_clock_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
322
328  virtual std::string get_clock_source(const size_t mboard) = 0;
329
335  virtual std::vector<std::string> get_clock_sources(const size_t mboard) = 0;
336
345  virtual void set_clock_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
346
355  virtual void set_time_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
356
360  virtual size_t get_num_mboards(void) = 0;
361
368  virtual sensor_value_t get_mboard_sensor(const std::string &name, size_t mboard = 0) = 0;
369
375  virtual std::vector<std::string> get_mboard_sensor_names(size_t mboard = 0) = 0;
376
384  virtual void set_user_register(const boost::uint8_t addr, const boost::uint32_t data, size_t mboard = ALL_MBOARDS) = 0;
385
386  /*******************************************************************
387  * RX methods
388  ******************************************************************/
397  virtual void set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
398
404  virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard = 0) = 0;
405
411  virtual size_t get_rx_num_channels(void) = 0;
412
418  virtual std::string get_rx_subdev_name(size_t chan = 0) = 0;
419
425  virtual void set_rx_rate(double rate, size_t chan = ALL_CHANS) = 0;
426
432  virtual double get_rx_rate(size_t chan = 0) = 0;
433
439  virtual meta_range_t get_rx_rates(size_t chan = 0) = 0;
440
447  virtual tune_result_t set_rx_freq(
448  const tune_request_t &tune_request, size_t chan = 0
449  ) = 0;
450
456  virtual double get_rx_freq(size_t chan = 0) = 0;
457
467  virtual freq_range_t get_rx_freq_range(size_t chan = 0) = 0;
468
474  virtual freq_range_t get_fe_rx_freq_range(size_t chan = 0) = 0;
475
483  virtual void set_rx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
484
486  void set_rx_gain(double gain, size_t chan = 0){
487  return this->set_rx_gain(gain, ALL_GAINS, chan);
488  }
489
497  virtual double get_rx_gain(const std::string &name, size_t chan = 0) = 0;
498
500  double get_rx_gain(size_t chan = 0){
501  return this->get_rx_gain(ALL_GAINS, chan);
502  }
503
511  virtual gain_range_t get_rx_gain_range(const std::string &name, size_t chan = 0) = 0;
512
514  gain_range_t get_rx_gain_range(size_t chan = 0){
515  return this->get_rx_gain_range(ALL_GAINS, chan);
516  }
517
524  virtual std::vector<std::string> get_rx_gain_names(size_t chan = 0) = 0;
525
531  virtual void set_rx_antenna(const std::string &ant, size_t chan = 0) = 0;
532
538  virtual std::string get_rx_antenna(size_t chan = 0) = 0;
539
545  virtual std::vector<std::string> get_rx_antennas(size_t chan = 0) = 0;
546
552  UHD_DEPRECATED bool get_rx_lo_locked(size_t chan = 0){
553  return this->get_rx_sensor("lo_locked", chan).to_bool();
554  }
555
561  virtual void set_rx_bandwidth(double bandwidth, size_t chan = 0) = 0;
562
568  virtual double get_rx_bandwidth(size_t chan = 0) = 0;
569
575  virtual meta_range_t get_rx_bandwidth_range(size_t chan = 0) = 0;
576
583  UHD_DEPRECATED double read_rssi(size_t chan = 0){
584  return this->get_rx_sensor("rssi", chan).to_real();
585  }
586
594  virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan = 0) = 0;
595
602  virtual sensor_value_t get_rx_sensor(const std::string &name, size_t chan = 0) = 0;
603
609  virtual std::vector<std::string> get_rx_sensor_names(size_t chan = 0) = 0;
610
623  virtual void set_rx_dc_offset(const bool enb, size_t chan = ALL_CHANS) = 0;
624
632  virtual void set_rx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
633
641  virtual void set_rx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
642
643  /*******************************************************************
644  * TX methods
645  ******************************************************************/
654  virtual void set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
655
661  virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard = 0) = 0;
662
668  virtual size_t get_tx_num_channels(void) = 0;
669
675  virtual std::string get_tx_subdev_name(size_t chan = 0) = 0;
676
682  virtual void set_tx_rate(double rate, size_t chan = ALL_CHANS) = 0;
683
689  virtual double get_tx_rate(size_t chan = 0) = 0;
690
696  virtual meta_range_t get_tx_rates(size_t chan = 0) = 0;
697
704  virtual tune_result_t set_tx_freq(
705  const tune_request_t &tune_request, size_t chan = 0
706  ) = 0;
707
713  virtual double get_tx_freq(size_t chan = 0) = 0;
714
724  virtual freq_range_t get_tx_freq_range(size_t chan = 0) = 0;
725
731  virtual freq_range_t get_fe_tx_freq_range(size_t chan = 0) = 0;
732
740  virtual void set_tx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
741
743  void set_tx_gain(double gain, size_t chan = 0){
744  return this->set_tx_gain(gain, ALL_GAINS, chan);
745  }
746
754  virtual double get_tx_gain(const std::string &name, size_t chan = 0) = 0;
755
757  double get_tx_gain(size_t chan = 0){
758  return this->get_tx_gain(ALL_GAINS, chan);
759  }
760
768  virtual gain_range_t get_tx_gain_range(const std::string &name, size_t chan = 0) = 0;
769
771  gain_range_t get_tx_gain_range(size_t chan = 0){
772  return this->get_tx_gain_range(ALL_GAINS, chan);
773  }
774
781  virtual std::vector<std::string> get_tx_gain_names(size_t chan = 0) = 0;
782
788  virtual void set_tx_antenna(const std::string &ant, size_t chan = 0) = 0;
789
795  virtual std::string get_tx_antenna(size_t chan = 0) = 0;
796
802  virtual std::vector<std::string> get_tx_antennas(size_t chan = 0) = 0;
803
809  UHD_DEPRECATED bool get_tx_lo_locked(size_t chan = 0){
810  return this->get_tx_sensor("lo_locked", chan).to_bool();
811  }
812
818  virtual void set_tx_bandwidth(double bandwidth, size_t chan = 0) = 0;
819
825  virtual double get_tx_bandwidth(size_t chan = 0) = 0;
826
832  virtual meta_range_t get_tx_bandwidth_range(size_t chan = 0) = 0;
833
841  virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan = 0) = 0;
842
849  virtual sensor_value_t get_tx_sensor(const std::string &name, size_t chan = 0) = 0;
850
856  virtual std::vector<std::string> get_tx_sensor_names(size_t chan = 0) = 0;
857
864  virtual void set_tx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
865
873  virtual void set_tx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
874
875  /*******************************************************************
876  * GPIO methods
877  ******************************************************************/
878
884  virtual std::vector<std::string> get_gpio_banks(const size_t mboard) = 0;
885
902  virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const boost::uint32_t value, const boost::uint32_t mask = 0xffffffff, const size_t mboard = 0) = 0;
903
920  virtual boost::uint32_t get_gpio_attr(const std::string &bank, const std::string &attr, const size_t mboard = 0) = 0;
921
922 };
923
924 }}
925
926 #endif /* INCLUDED_UHD_USRP_MULTI_USRP_HPP */
Definition: multi_usrp.hpp:514
Definition: stream_cmd.hpp:46
UHD_DEPRECATED bool get_tx_lo_locked(size_t chan=0)
Definition: multi_usrp.hpp:809
Definition: tune_result.hpp:29
Definition: multi_usrp.hpp:757
#define UHD_DEPRECATED
Definition: config.hpp:70
Definition: multi_usrp.hpp:743
Definition: time_spec.hpp:39
Definition: device.hpp:41
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:96
Definition: multi_usrp.hpp:500
Definition: tune_request.hpp:33
Definition: stream.hpp:126
A wildcard gain element name.
Definition: multi_usrp.hpp:105
Definition: config.hpp:79
Definition: sensors.hpp:38
Definition: multi_usrp.hpp:94
Definition: stream.hpp:40
UHD_DEPRECATED bool get_rx_lo_locked(size_t chan=0)
Definition: multi_usrp.hpp:552
Definition: multi_usrp.hpp:486
UHD_DEPRECATED double read_rssi(size_t chan=0)
Definition: multi_usrp.hpp:583
Definition: ranges.hpp:68
Definition: stream.hpp:198
Definition: multi_usrp.hpp:771
