003.007.002-0-g25f67e01
include
uhd
config.hpp
1
2
// Copyright 2010-2011 Ettus Research LLC
3
4
// This program is free software: you can redistribute it and/or modify
5
// it under the terms of the GNU General Public License as published by
6
// the Free Software Foundation, either version 3 of the License, or
7
// (at your option) any later version.
8
9
// This program is distributed in the hope that it will be useful,
10
// but WITHOUT ANY WARRANTY; without even the implied warranty of
11
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
12
// GNU General Public License for more details.
13
14
// You should have received a copy of the GNU General Public License
15
// along with this program. If not, see <http://www.gnu.org/licenses/>.
16
18
#ifndef INCLUDED_UHD_CONFIG_HPP
19
#define INCLUDED_UHD_CONFIG_HPP
21
#include <boost/config.hpp>
22
23
#ifdef BOOST_MSVC
// suppress warnings
25
//# pragma warning(push)
26
//# pragma warning(disable: 4511) // copy constructor can't not be generated
27
//# pragma warning(disable: 4512) // assignment operator can't not be generated
28
//# pragma warning(disable: 4100) // unreferenced formal parameter
29
//# pragma warning(disable: 4996) // <symbol> was declared deprecated
30
# pragma warning(disable: 4355) // 'this' : used in base member initializer list
31
//# pragma warning(disable: 4706) // assignment within conditional expression
32
# pragma warning(disable: 4251) // class 'A<T>' needs to have dll-interface to be used by clients of class 'B'
33
//# pragma warning(disable: 4127) // conditional expression is constant
34
//# pragma warning(disable: 4290) // C++ exception specification ignored except to ...
35
//# pragma warning(disable: 4180) // qualifier applied to function type has no meaning; ignored
36
# pragma warning(disable: 4275) // non dll-interface class ... used as base for dll-interface class ...
37
//# pragma warning(disable: 4267) // 'var' : conversion from 'size_t' to 'type', possible loss of data
38
//# pragma warning(disable: 4511) // 'class' : copy constructor could not be generated
39
//# pragma warning(disable: 4250) // 'class' : inherits 'method' via dominance
40
# pragma warning(disable: 4200) // nonstandard extension used : zero-sized array in struct/union
41
42
// define logical operators
43
#include <ciso646>
44
45
// define ssize_t
46
#include <cstddef>
47
typedef
ptrdiff_t ssize_t;
48
49
#endif //BOOST_MSVC
50
51
//define cross platform attribute macros
52
#if defined(BOOST_MSVC)
53
#define UHD_EXPORT __declspec(dllexport)
54
#define UHD_IMPORT __declspec(dllimport)
55
#define UHD_INLINE __forceinline
56
#define UHD_DEPRECATED __declspec(deprecated)
57
#define UHD_ALIGNED(x) __declspec(align(x))
58
#define UHD_UNUSED(x) x
59
#elif defined(__GNUG__) && __GNUG__ >= 4
60
#define UHD_EXPORT __attribute__((visibility("default")))
61
#define UHD_IMPORT __attribute__((visibility("default")))
62
#define UHD_INLINE inline __attribute__((always_inline))
63
#define UHD_DEPRECATED __attribute__((deprecated))
64
#define UHD_ALIGNED(x) __attribute__((aligned(x)))
65
#define UHD_UNUSED(x) x __attribute__((unused))
66
#else
67
#define UHD_EXPORT
68
#define UHD_IMPORT
69
70
71
72
73
#endif
74
75
// Define API declaration macro
76
#ifdef UHD_DLL_EXPORTS
77
#define UHD_API UHD_EXPORT
78
#else
79
#define UHD_API UHD_IMPORT
80
#endif // UHD_DLL_EXPORTS
81
82
// Platform defines for conditional parts of headers:
83
// Taken from boost/config/select_platform_config.hpp,
84
// however, we define macros, not strings for platforms.
85
#if defined(linux) || defined(__linux) || defined(__linux__)
86
#define UHD_PLATFORM_LINUX
87
#elif defined(_WIN32) || defined(__WIN32__) || defined(WIN32)
88
#define UHD_PLATFORM_WIN32
89
#elif defined(macintosh) || defined(__APPLE__) || defined(__APPLE_CC__)
90
#define UHD_PLATFORM_MACOS
91
#elif defined(__FreeBSD__) || defined(__NetBSD__) || defined(__OpenBSD__)
92
#define UHD_PLATFORM_BSD
93
#endif
94
95
#endif
/* INCLUDED_UHD_CONFIG_HPP */
Generated by
1.8.13
