UHD  003.007.002-0-g25f67e01
metadata.hpp
18 #ifndef INCLUDED_UHD_TYPES_METADATA_HPP
19 #define INCLUDED_UHD_TYPES_METADATA_HPP
25 namespace uhd{
26
33
36  {
37  reset();
38  }
39
41  void reset()
42  {
43  has_time_spec = false;
44  time_spec = time_spec_t(0.0);
45  more_fragments = false;
46  fragment_offset = 0;
47  start_of_burst = false;
48  end_of_burst = false;
49  error_code = ERROR_CODE_NONE;
50  out_of_sequence = false;
51  }
52
55
58
66
73
76
79
94  enum error_code_t {
96  ERROR_CODE_NONE = 0x0,
98  ERROR_CODE_TIMEOUT = 0x1,
100  ERROR_CODE_LATE_COMMAND = 0x2,
102  ERROR_CODE_BROKEN_CHAIN = 0x4,
111  ERROR_CODE_OVERFLOW = 0x8,
113  ERROR_CODE_ALIGNMENT = 0xc,
115  ERROR_CODE_BAD_PACKET = 0xf
116  } error_code;
117
120
127  std::string to_pp_string(bool compact=true) const;
128
133  std::string strerror(void) const;
134  };
135
148
151
154
157
162  tx_metadata_t(void);
163  };
164
170  size_t channel;
171
174
177
183  EVENT_CODE_BURST_ACK = 0x1,
185  EVENT_CODE_UNDERFLOW = 0x2,
187  EVENT_CODE_SEQ_ERROR = 0x4,
189  EVENT_CODE_TIME_ERROR = 0x8,
191  EVENT_CODE_UNDERFLOW_IN_PACKET = 0x10,
193  EVENT_CODE_SEQ_ERROR_IN_BURST = 0x20,
195  EVENT_CODE_USER_PAYLOAD = 0x40
196  } event_code;
197
201  boost::uint32_t user_payload[4];
202
203  };
204
205 } //namespace uhd
206
207 #endif /* INCLUDED_UHD_TYPES_METADATA_HPP */
time_spec_t time_spec
Time of the first sample.
Definition: metadata.hpp:57
bool end_of_burst
Definition: metadata.hpp:156
Definition: metadata.hpp:150
void reset()
Reset values.
Definition: metadata.hpp:41
Definition: time_spec.hpp:39
bool has_time_spec
Has time specification?
Definition: metadata.hpp:173
rx_metadata_t()
Default constructor.
Definition: metadata.hpp:35
size_t fragment_offset
Definition: metadata.hpp:72
event_code_t
Definition: metadata.hpp:181
Definition: metadata.hpp:32
Definition: metadata.hpp:141
Definition: config.hpp:79
bool has_time_spec
Definition: metadata.hpp:147
bool start_of_burst
Start of burst will be true for the first packet in the chain.
Definition: metadata.hpp:75
error_code_t
Definition: metadata.hpp:94
bool start_of_burst
Definition: metadata.hpp:153
bool has_time_spec
Definition: metadata.hpp:54
Definition: metadata.hpp:168
size_t channel
The channel number in a mimo configuration.
Definition: metadata.hpp:170
bool more_fragments
Definition: metadata.hpp:65
bool end_of_burst
End of burst will be true for the last packet in the chain.
Definition: metadata.hpp:78
When the async event occurred.
Definition: metadata.hpp:176
bool out_of_sequence
Out of sequence. The transport has either dropped a packet or received data out of order...
Definition: metadata.hpp:119
