UHD  003.007.003-0-ge10df19c
property_tree.hpp
18 #ifndef INCLUDED_UHD_PROPERTY_TREE_HPP
19 #define INCLUDED_UHD_PROPERTY_TREE_HPP
24 #include <boost/function.hpp>
25 #include <vector>
26
27 namespace uhd{
28
33 template <typename T> class property : boost::noncopyable{
34 public:
35  typedef boost::function<void(const T &)> subscriber_type;
36  typedef boost::function<T(void)> publisher_type;
37  typedef boost::function<T(const T &)> coercer_type;
38
47  virtual property<T> &coerce(const coercer_type &coercer) = 0;
48
58  virtual property<T> &publish(const publisher_type &publisher) = 0;
59
67  virtual property<T> &subscribe(const subscriber_type &subscriber) = 0;
68
73  virtual property<T> &update(void) = 0;
74
82  virtual property<T> &set(const T &value) = 0;
83
90  virtual T get(void) const = 0;
91
97  virtual bool empty(void) const = 0;
98 };
99
107 struct fs_path : std::string{
108  UHD_API fs_path(void);
109  UHD_API fs_path(const char *);
110  UHD_API fs_path(const std::string &);
111  UHD_API std::string leaf(void) const;
112  UHD_API fs_path branch_path(void) const;
113 };
114
115 UHD_API fs_path operator/(const fs_path &, const fs_path &);
116 UHD_API fs_path operator/(const fs_path &, size_t);
117
121 class UHD_API property_tree : boost::noncopyable{
122 public:
123  typedef boost::shared_ptr<property_tree> sptr;
124
126  static sptr make(void);
127
129  virtual sptr subtree(const fs_path &path) const = 0;
130
132  virtual void remove(const fs_path &path) = 0;
133
135  virtual bool exists(const fs_path &path) const = 0;
136
138  virtual std::vector<std::string> list(const fs_path &path) const = 0;
139
141  template <typename T> property<T> &create(const fs_path &path);
142
144  template <typename T> property<T> &access(const fs_path &path);
145
146 private:
148  virtual void _create(const fs_path &path, const boost::shared_ptr<void> &prop) = 0;
149
151  virtual boost::shared_ptr<void> &_access(const fs_path &path) const = 0;
152
153 };
154
155 } //namespace uhd
156
157 #include <uhd/property_tree.ipp>
158
159 #endif /* INCLUDED_UHD_PROPERTY_TREE_HPP */
boost::function< void(const T &)> subscriber_type
Definition: property_tree.hpp:35
virtual property< T > & update(void)=0
Definition: property_tree.hpp:107
Definition: property_tree.hpp:123
virtual property< T > & publish(const publisher_type &publisher)=0
Definition: config.hpp:79
boost::function< T(const T &)> coercer_type
Definition: property_tree.hpp:37
virtual bool empty(void) const =0
virtual property< T > & coerce(const coercer_type &coercer)=0
boost::function< T(void)> publisher_type
Definition: property_tree.hpp:36
virtual property< T > & subscribe(const subscriber_type &subscriber)=0
Definition: property_tree.hpp:121
Definition: property_tree.hpp:33
