UHD  003.007.003-0-ge10df19c
serial.hpp
18 #ifndef INCLUDED_UHD_TYPES_SERIAL_HPP
19 #define INCLUDED_UHD_TYPES_SERIAL_HPP
22 #include <boost/shared_ptr.hpp>
24 #include <vector>
25
26 namespace uhd{
27
31  typedef std::vector<boost::uint8_t> byte_vector_t;
32
46  public:
47  typedef boost::shared_ptr<i2c_iface> sptr;
48
49  virtual ~i2c_iface(void);
50
52  i2c_iface::sptr eeprom16(void);
53
59  virtual void write_i2c(
60  boost::uint16_t addr,
61  const byte_vector_t &buf
62  ) = 0;
63
70  virtual byte_vector_t read_i2c(
71  boost::uint16_t addr,
72  size_t num_bytes
73  ) = 0;
74
81  virtual void write_eeprom(
82  boost::uint16_t addr,
83  boost::uint16_t offset,
84  const byte_vector_t &buf
85  );
86
94  virtual byte_vector_t read_eeprom(
95  boost::uint16_t addr,
96  boost::uint16_t offset,
97  size_t num_bytes
98  );
99  };
100
110  enum edge_t{
111  EDGE_RISE = 'r',
112  EDGE_FALL = 'f'
113  };
114
117
120
125  spi_config_t(edge_t edge = EDGE_RISE);
126  };
127
133  public:
134  typedef boost::shared_ptr<spi_iface> sptr;
135
136  virtual ~spi_iface(void);
137
147  virtual boost::uint32_t transact_spi(
148  int which_slave,
149  const spi_config_t &config,
150  boost::uint32_t data,
151  size_t num_bits,
152  bool readback
153  ) = 0;
154
163  virtual boost::uint32_t read_spi(
164  int which_slave,
165  const spi_config_t &config,
166  boost::uint32_t data,
167  size_t num_bits
168  );
169
177  virtual void write_spi(
178  int which_slave,
179  const spi_config_t &config,
180  boost::uint32_t data,
181  size_t num_bits
182  );
183  };
184
189  public:
190  typedef boost::shared_ptr<uart_iface> sptr;
191
192  virtual ~uart_iface(void);
193
198  virtual void write_uart(const std::string &buf) = 0;
199
206  virtual std::string read_uart(double timeout) = 0;
207  };
208
209 } //namespace uhd
210
211 #endif /* INCLUDED_UHD_TYPES_SERIAL_HPP */
Definition: serial.hpp:132
Definition: serial.hpp:45
edge_t mosi_edge
on what edge is the mosi data valid?
Definition: serial.hpp:116
Definition: config.hpp:79
Definition: serial.hpp:105
std::vector< boost::uint8_t > byte_vector_t
Definition: serial.hpp:31
boost::shared_ptr< spi_iface > sptr
Definition: serial.hpp:134
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:119
Definition: serial.hpp:188
Definition: serial.hpp:190
edge_t
Definition: serial.hpp:110
boost::shared_ptr< i2c_iface > sptr
Definition: serial.hpp:47
