UHD  003.007.003-0-ge10df19c
usrprio_rpc_common.hpp
2 // Copyright 2013 Ettus Research LLC
18 #ifndef INCLUDED_USRPRIO_RPC_COMMON_HPP
19 #define INCLUDED_USRPRIO_RPC_COMMON_HPP
22
23 namespace uhd { namespace usrprio_rpc {
25 //Function IDs
26
27 static const func_id_t NIUSRPRIO_FUNC_BASE = 0x100;
28
29 static const func_id_t NIUSRPRIO_ENUMERATE = NIUSRPRIO_FUNC_BASE + 0;
30 static const func_id_t NIUSRPRIO_OPEN_SESSION = NIUSRPRIO_FUNC_BASE + 1;
31 static const func_id_t NIUSRPRIO_CLOSE_SESSION = NIUSRPRIO_FUNC_BASE + 2;
32 static const func_id_t NIUSRPRIO_RESET_SESSION = NIUSRPRIO_FUNC_BASE + 3;
33 static const func_id_t NIUSRPRIO_DOWNLOAD_BITSTREAM_TO_FPGA = NIUSRPRIO_FUNC_BASE + 4;
34 static const func_id_t NIUSRPRIO_GET_INTERFACE_PATH = NIUSRPRIO_FUNC_BASE + 5;
35 static const func_id_t NIUSRPRIO_DOWNLOAD_FPGA_TO_FLASH = NIUSRPRIO_FUNC_BASE + 6;
36
37 //Function Args
38
40  boost::uint32_t interface_num;
41  std::string resource_name;
42  std::string pcie_serial_num;
43  std::string interface_path;
44
45  template <typename Archive>
46  void serialize(Archive& ar, const unsigned int version)
47  {
48  if (version || !version) { //Suppress unused warning
49  ar & interface_num;
50  ar & resource_name;
51  ar & pcie_serial_num;
52  ar & interface_path;
53  }
54  }
55 };
56 typedef std::vector<usrprio_device_info> usrprio_device_info_vtr;
57
58 #define NIUSRPRIO_ENUMERATE_ARGS \
59  usrprio_device_info_vtr& device_info_vtr
60
61 #define NIUSRPRIO_OPEN_SESSION_ARGS \
62  const std::string& resource, \
63  const std::string& path, \
64  const std::string& signature, \
65  const boost::uint16_t& download_fpga
66
67 #define NIUSRPRIO_CLOSE_SESSION_ARGS \
68  const std::string& resource
69
70 #define NIUSRPRIO_RESET_SESSION_ARGS \
71  const std::string& resource
72
73 #define NIUSRPRIO_DOWNLOAD_BITSTREAM_TO_FPGA_ARGS \
74  const std::string& resource
75
76 #define NIUSRPRIO_GET_INTERFACE_PATH_ARGS \
77  const std::string& resource, \
78  std::string& interface_path
79
80 #define NIUSRPRIO_DOWNLOAD_FPGA_TO_FLASH_ARGS \
81  const std::string& resource, \
82  const std::string& bitstream_path
83 }}
84
85 #endif /* INCLUDED_USRPRIO_RPC_COMMON_HPP */
Definition: usrprio_rpc_common.hpp:39
Definition: usrprio_rpc_common.hpp:40
void serialize(Archive &ar, const unsigned int version)
Definition: usrprio_rpc_common.hpp:46
Definition: usrprio_rpc_common.hpp:42
boost::int32_t func_id_t
Definition: rpc_common.hpp:38
std::vector< usrprio_device_info > usrprio_device_info_vtr
Definition: usrprio_rpc_common.hpp:56
Definition: usrprio_rpc_common.hpp:41
Definition: usrprio_rpc_common.hpp:43
