18 #ifndef INCLUDED_UHD_UTILS_ATOMIC_HPP    19 #define INCLUDED_UHD_UTILS_ATOMIC_HPP    23 #include <boost/thread/thread.hpp>    24 #include <boost/thread/mutex.hpp>    25 #include <boost/thread/condition_variable.hpp>    26 #include <boost/interprocess/detail/atomic.hpp>    28 #include <boost/version.hpp>    29 #if BOOST_VERSION >= 104800    30 #  define BOOST_IPC_DETAIL boost::interprocess::ipcdetail    32 #  define BOOST_IPC_DETAIL boost::interprocess::detail    47         UHD_INLINE boost::uint32_t
cas(boost::uint32_t newval, boost::uint32_t cmp){
    48             return BOOST_IPC_DETAIL::atomic_cas32(&_num, newval, cmp);
    53             BOOST_IPC_DETAIL::atomic_write32(&_num, newval);
    58             return BOOST_IPC_DETAIL::atomic_read32(&_num);
    63             return BOOST_IPC_DETAIL::atomic_inc32(&_num);
    68             return BOOST_IPC_DETAIL::atomic_dec32(&_num);
    71     private:
volatile boost::uint32_t _num;
   102             if (_size == 1)
return;
   105             _entry_counter.inc();
   106             _entry_counter.cas(0, _size);
   107             boost::mutex::scoped_lock lock(_mutex);
   108             while (_entry_counter.read() != 0)
   110                 this->check_interrupt();
   111                 _cond.timed_wait(lock, boost::posix_time::milliseconds(1));
   118             _exit_counter.cas(0, _size);
   119             while (_exit_counter.read() != 0) this->check_interrupt();
   125             while (_entry_counter.read() != (_size-1)) this->check_interrupt();
   134         boost::condition_variable _cond;
   138             if (_done.
read() != 0)
throw boost::thread_interrupted();
   139             boost::this_thread::interruption_point();
   140             boost::this_thread::yield();
   153         boost::uint32_t value,
   156         if (cond.
read() == value)
return true;
   158         while (cond.
read() != value){
   160             boost::this_thread::interruption_point();
   161             boost::this_thread::yield();
 UHD_INLINE boost::uint32_t read(void)
Gets the current value of the atomic integer.
Definition: atomic.hpp:57
UHD_INLINE void wait(void)
Wait on the barrier condition.
Definition: atomic.hpp:100
UHD_INLINE void release(void)
Definition: atomic.hpp:176
Definition: atomic.hpp:78
Definition: time_spec.hpp:39
A 32-bit integer that can be atomically accessed.
Definition: atomic.hpp:38
UHD_INLINE void wait_others(void)
Definition: atomic.hpp:123
UHD_INLINE bool spin_wait_with_timeout(atomic_uint32_t &cond, boost::uint32_t value, const double timeout)
Definition: atomic.hpp:151
static time_spec_t get_system_time(void)
Definition: config.hpp:79
UHD_INLINE boost::uint32_t cas(boost::uint32_t newval, boost::uint32_t cmp)
Compare with cmp, swap with newval if same, return old value.
Definition: atomic.hpp:47
UHD_INLINE bool claim_with_wait(const double timeout)
Definition: atomic.hpp:180
#define UHD_INLINE
Definition: config.hpp:69
UHD_INLINE atomic_uint32_t(void)
Create a new atomic 32-bit integer, initialized to zero.
Definition: atomic.hpp:42
UHD_INLINE void write(const boost::uint32_t newval)
Sets the atomic integer to a new value.
Definition: atomic.hpp:52
UHD_INLINE boost::uint32_t inc(void)
Increment by 1 and return the old value.
Definition: atomic.hpp:62
simple_claimer(void)
Definition: atomic.hpp:172
UHD_INLINE boost::uint32_t dec(void)
Decrement by 1 and return the old value.
Definition: atomic.hpp:67
void resize(const size_t size)
Resize the barrier for N threads.
Definition: atomic.hpp:86
reusable_barrier(const size_t size)
Definition: atomic.hpp:83
Definition: atomic.hpp:170
reusable_barrier()
Definition: atomic.hpp:81
void interrupt(void)
Definition: atomic.hpp:94
