device.hpp
18 #ifndef INCLUDED_UHD_DEVICE_HPP
19 #define INCLUDED_UHD_DEVICE_HPP
22 #include <uhd/stream.hpp>
23 #include <uhd/deprecated.hpp>
24 #include <uhd/property_tree.hpp>
26 #include <boost/utility.hpp>
27 #include <boost/shared_ptr.hpp>
28 #include <boost/function.hpp>
29
30 namespace uhd{
31
32 class property_tree; //forward declaration
33
38 class UHD_API device : boost::noncopyable{
39
40 public:
41  typedef boost::shared_ptr<device> sptr;
42  typedef boost::function<device_addrs_t(const device_addr_t &)> find_t;
43  typedef boost::function<sptr(const device_addr_t &)> make_t;
44
47  ANY,
49  CLOCK
50  };
51  virtual ~device(void) = 0;
52
59  static void register_device(
60  const find_t &find,
61  const make_t &make,
62  const device_filter_t filter
63  );
64
75  static device_addrs_t find(const device_addr_t &hint, device_filter_t filter = ANY);
76
89  static sptr make(const device_addr_t &hint, device_filter_t filter = ANY, size_t which = 0);
90
96  virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args) = 0;
97
103  virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args) = 0;
104
106  uhd::property_tree::sptr get_tree(void) const;
107
109  device_filter_t get_device_type() const;
110
111  #include <uhd/device_deprecated.ipp>
112
113 protected:
116 };
117
118 } //namespace uhd
119
120 #endif /* INCLUDED_UHD_DEVICE_HPP */
Definition: device.hpp:41
Definition: device.hpp:47
Definition: property_tree.hpp:130
Definition: stream.hpp:126
Definition: config.hpp:79
device_filter_t
Device type, used as a filter in make.
Definition: device.hpp:46
std::vector< device_addr_t > device_addrs_t
A typedef for a vector of device addresses.
Definition: device_addr.hpp:88
uhd::property_tree::sptr _tree
Definition: device.hpp:114
boost::function< sptr(const device_addr_t &)> make_t
Definition: device.hpp:43
Definition: stream.hpp:40
Definition: device.hpp:38
Definition: stream.hpp:198
device_filter_t _type
Definition: device.hpp:115
Definition: device.hpp:48
boost::function< device_addrs_t(const device_addr_t &)> find_t
Definition: device.hpp:42
