18 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP    19 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP    22 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API    23 #define UHD_USRP_MULTI_USRP_GET_RATES_API    24 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API    25 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API    26 #define UHD_USRP_MULTI_USRP_BW_RANGE_API    27 #define UHD_USRP_MULTI_USRP_USER_REGS_API    28 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API    40 #include <boost/shared_ptr.hpp>    41 #include <boost/utility.hpp>    46 namespace uhd{
namespace usrp{
    96     typedef boost::shared_ptr<multi_usrp>
sptr;
   101     static const size_t ALL_MBOARDS = size_t(~0);
   104     static const size_t ALL_CHANS = size_t(~0);
   161     virtual void set_master_clock_rate(
double rate,
size_t mboard = ALL_MBOARDS) = 0;
   168     virtual double get_master_clock_rate(
size_t mboard = 0) = 0;
   174     virtual std::string get_pp_string(
void) = 0;
   181     virtual std::string get_mboard_name(
   188     virtual time_spec_t get_time_now(
   195     virtual time_spec_t get_time_last_pps(
   208     virtual void set_time_now(
const time_spec_t &time_spec,
   222     virtual void set_time_next_pps(
   239     virtual void set_time_unknown_pps(
const time_spec_t &time_spec) = 0;
   247     virtual bool get_time_synchronized(
void) = 0;
   259     virtual void set_command_time(
const uhd::time_spec_t &time_spec,
   266     virtual void clear_command_time(
   280     virtual void issue_stream_cmd(
const stream_cmd_t &stream_cmd,
size_t chan = ALL_CHANS) = 0;
   290     virtual void set_clock_config(
const clock_config_t &clock_config,
   300     virtual void set_time_source(
const std::string &source,
const size_t mboard = ALL_MBOARDS) = 0;
   307     virtual std::string get_time_source(
const size_t mboard) = 0;
   314     virtual std::vector<std::string> get_time_sources(
   323     virtual void set_clock_source(
   330     virtual std::string get_clock_source(
   337     virtual std::vector<std::string> get_clock_sources(
   347     virtual void set_clock_source_out(
const bool enb,
   357     virtual void set_time_source_out(
const bool enb,
   362     virtual size_t get_num_mboards(
void) = 0;
   370     virtual sensor_value_t get_mboard_sensor(
const std::string &name,
   377     virtual std::vector<std::string> get_mboard_sensor_names(
   386     virtual void set_user_register(
const boost::uint8_t addr,
const boost::uint32_t data,
   413     virtual size_t get_rx_num_channels(
void) = 0;
   420     virtual std::string get_rx_subdev_name(
size_t chan = 0) = 0;
   427     virtual void set_rx_rate(
double rate,
   434     virtual double get_rx_rate(
   458     virtual double get_rx_freq(
   469     virtual freq_range_t get_rx_freq_range(
   476     virtual freq_range_t get_fe_rx_freq_range(
   485     virtual void set_rx_gain(
double gain,
   489         return this->set_rx_gain(gain, ALL_GAINS, chan);
   499     virtual double get_rx_gain(
   503         return this->get_rx_gain(ALL_GAINS, chan);
   513     virtual gain_range_t get_rx_gain_range(
   517         return this->get_rx_gain_range(ALL_GAINS, chan);
   526     virtual std::vector<std::string> get_rx_gain_names(
   533     virtual void set_rx_antenna(
const std::string &ant,
   540     virtual std::string get_rx_antenna(
   547     virtual std::vector<std::string> get_rx_antennas(
   554     virtual void set_rx_bandwidth(
double bandwidth,
   561     virtual double get_rx_bandwidth(
   568     virtual meta_range_t get_rx_bandwidth_range(
   585     virtual sensor_value_t get_rx_sensor(
   592     virtual std::vector<std::string> get_rx_sensor_names(
   606     virtual void set_rx_dc_offset(
const bool enb,
   615     virtual void set_rx_dc_offset(
const std::complex<double> &offset,
   624     virtual void set_rx_iq_balance(
const std::complex<double> &correction,
   651     virtual size_t get_tx_num_channels(
void) = 0;
   658     virtual std::string get_tx_subdev_name(
   665     virtual void set_tx_rate(
double rate,
   672     virtual double get_tx_rate(
   696     virtual double get_tx_freq(
   707     virtual freq_range_t get_tx_freq_range(
   714     virtual freq_range_t get_fe_tx_freq_range(
   723     virtual void set_tx_gain(
double gain,
   727         return this->set_tx_gain(gain, ALL_GAINS, chan);
   737     virtual double get_tx_gain(
   741         return this->get_tx_gain(ALL_GAINS, chan);
   751     virtual gain_range_t get_tx_gain_range(
   755         return this->get_tx_gain_range(ALL_GAINS, chan);
   764     virtual std::vector<std::string> get_tx_gain_names(
   771     virtual void set_tx_antenna(
   778     virtual std::string get_tx_antenna(
   785     virtual std::vector<std::string> get_tx_antennas(
   792     virtual void set_tx_bandwidth(
double bandwidth,
   799     virtual double get_tx_bandwidth(
   806     virtual meta_range_t get_tx_bandwidth_range(
   823     virtual sensor_value_t get_tx_sensor(
   830     virtual std::vector<std::string> get_tx_sensor_names(
   838     virtual void set_tx_dc_offset(
   847     virtual void set_tx_iq_balance(
   858     virtual std::vector<std::string> get_gpio_banks(
   876     virtual void set_gpio_attr(
const std::string &bank,
const std::string &attr,
const boost::uint32_t value,
const boost::uint32_t mask = 0xffffffff,
const size_t mboard = 0) = 0;
   894     virtual boost::uint32_t get_gpio_attr(
Definition: multi_usrp.hpp:516
Definition: stream_cmd.hpp:46
Definition: tune_result.hpp:29
Definition: multi_usrp.hpp:740
Definition: multi_usrp.hpp:726
Definition: time_spec.hpp:39
Definition: device.hpp:41
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:96
Definition: multi_usrp.hpp:502
Definition: tune_request.hpp:33
Definition: stream.hpp:126
static const std::string ALL_GAINS
A wildcard gain element name.
Definition: multi_usrp.hpp:107
Definition: config.hpp:79
Definition: sensors.hpp:38
Definition: multi_usrp.hpp:94
Definition: stream.hpp:40
Definition: multi_usrp.hpp:488
Definition: stream.hpp:198
Definition: multi_usrp.hpp:754
