nirio_quirks.h
2 // Copyright 2013-2014 Ettus Research LLC
18
19 #ifndef INCLUDED_UHD_TRANSPORT_NIRIO_NIRIO_QUIRKS_H
20 #define INCLUDED_UHD_TRANSPORT_NIRIO_NIRIO_QUIRKS_H
21
22 #include <set>
23 #include <stdint.h>
24 #include <uhd/utils/log.hpp>
25
26 //Quirk#1: We need to verify RX zero-copy data transfers from the RIO
27 // driver if we are in full duplex mode.
28 // This option allows enabling this quirk.
29 #define UHD_NIRIO_RX_FIFO_XFER_CHECK_EN 0
30
31 namespace uhd { namespace niusrprio {
32
33 class nirio_quirks {
34 public:
35  nirio_quirks() : _tx_stream_count(0) {
36  }
37
38  UHD_INLINE void register_tx_streams(const uint32_t tx_stream_indices[]) {
39  for (size_t i = 0; i < sizeof(tx_stream_indices)/sizeof(*tx_stream_indices); i++) {
40  _tx_stream_fifo_indices.insert(tx_stream_indices[i]);
41  }
42  }
43
44  UHD_INLINE void add_tx_fifo(uint32_t index) {
45  if (_tx_stream_fifo_indices.find(index) != _tx_stream_fifo_indices.end()) {
46  if (_tx_stream_count == 0) {
47  UHD_LOG << "NI-RIO RX FIFO Transfer Check Quirk Enabled.";
48  }
49  _tx_stream_count++;
50  }
51  }
52
53  UHD_INLINE void remove_tx_fifo(uint32_t index) {
54  if (_tx_stream_fifo_indices.find(index) != _tx_stream_fifo_indices.end()) {
55  _tx_stream_count--;
56  if (_tx_stream_count == 0) {
57  UHD_LOG << "NI-RIO RX FIFO Transfer Check Quirk Disabled.";
58  }
59  }
60  }
61
62  //Quirk#1: We need to verify RX zero-copy data transfers from the RIO
63  // driver if we are in full duplex mode.
64  // This function returns true if the quirk is enabled for the
65  // current uhd_device configuration (dynamic)
67  //This function must be as fast as possible because it is in a high
68  //throughput data path
69  return _tx_stream_count > 0;
70  }
71
72 private:
73  std::set<uint32_t> _tx_stream_fifo_indices;
74  size_t _tx_stream_count;
75 };
76
77 }}
78
79 #endif /* INCLUDED_UHD_TRANSPORT_NIRIO_NIRIO_QUIRKS_H */
Definition: nirio_quirks.h:38
Definition: nirio_quirks.h:44
Definition: nirio_quirks.h:33
Definition: nirio_quirks.h:53
UHD_INLINE bool rx_fifo_xfer_check_en() const
Definition: nirio_quirks.h:66
#define UHD_INLINE
Definition: config.hpp:69
#define UHD_LOG
Definition: log.hpp:66
nirio_quirks()
Definition: nirio_quirks.h:35
