18 #ifndef INCLUDED_UHD_TRANSPORT_NIRIO_NIRIO_PROXY_IMPL_V2_H    19 #define INCLUDED_UHD_TRANSPORT_NIRIO_NIRIO_PROXY_IMPL_V2_H    21 #include <boost/smart_ptr.hpp>    22 #include <boost/noncopyable.hpp>    28     typedef uint64_t
tAlignedU64 __attribute__ ((aligned(8)));
    33 namespace uhd {
namespace niusrprio
    42    #define IOCTL(type, function, access) \    43       CTL_CODE((0x8000+type), (0x800+function), METHOD_BUFFERED, access)    45    #define IOCTL_ACCESS_ANY       (FILE_ANY_ACCESS)    46    #define IOCTL_ACCESS_READ      (FILE_READ_ACCESS)    47    #define IOCTL_ACCESS_WRITE     (FILE_WRITE_ACCESS)    48    #define IOCTL_ACCESS_RW        (FILE_READ_ACCESS | FILE_WRITE_ACCESS)    50    #define IOCTL_TRANSPORT_GET32 IOCTL(0, 0, IOCTL_ACCESS_READ)    51    #define IOCTL_TRANSPORT_SET32 IOCTL(0, 1, IOCTL_ACCESS_WRITE)    52    #define IOCTL_TRANSPORT_GET_STRING IOCTL(0, 2, IOCTL_ACCESS_READ)    53    #define IOCTL_TRANSPORT_SET_STRING IOCTL(0, 3, IOCTL_ACCESS_WRITE)    54    #define IOCTL_TRANSPORT_RESET IOCTL(1, 1, IOCTL_ACCESS_WRITE)    55    #define IOCTL_TRANSPORT_ADD_INPUT_FIFO_RESOURCE IOCTL(2, 0, IOCTL_ACCESS_ANY)    56    #define IOCTL_TRANSPORT_ADD_OUTPUT_FIFO_RESOURCE IOCTL(2, 1, IOCTL_ACCESS_ANY)    57    #define IOCTL_TRANSPORT_SET_DEVICE_CONFIG IOCTL(2, 3, IOCTL_ACCESS_WRITE)    58    #define IOCTL_TRANSPORT_FIFO_CONFIG IOCTL(4, 0, IOCTL_ACCESS_ANY)    59    #define IOCTL_TRANSPORT_FIFO_START IOCTL(4, 1, IOCTL_ACCESS_ANY)    60    #define IOCTL_TRANSPORT_FIFO_STOP IOCTL(4, 2, IOCTL_ACCESS_ANY)    61    #define IOCTL_TRANSPORT_FIFO_READ IOCTL(4, 3, IOCTL_ACCESS_READ)    62    #define IOCTL_TRANSPORT_FIFO_WRITE IOCTL(4, 4, IOCTL_ACCESS_WRITE)    63    #define IOCTL_TRANSPORT_FIFO_WAIT IOCTL(4, 5, IOCTL_ACCESS_ANY)    64    #define IOCTL_TRANSPORT_FIFO_GRANT IOCTL(4, 6, IOCTL_ACCESS_ANY)    65    #define IOCTL_TRANSPORT_FIFO_STOP_ALL IOCTL(4, 7, IOCTL_ACCESS_ANY)    66    #define IOCTL_TRANSPORT_PEEK64 IOCTL(5, 2, IOCTL_ACCESS_READ)    67    #define IOCTL_TRANSPORT_PEEK32 IOCTL(5, 3, IOCTL_ACCESS_READ)    68    #define IOCTL_TRANSPORT_POKE64 IOCTL(5, 6, IOCTL_ACCESS_WRITE)    69    #define IOCTL_TRANSPORT_POKE32 IOCTL(5, 7, IOCTL_ACCESS_WRITE)    70    #define IOCTL_TRANSPORT_POST_OPEN IOCTL(8, 0, IOCTL_ACCESS_ANY)    71    #define IOCTL_TRANSPORT_PRE_CLOSE IOCTL(8, 1, IOCTL_ACCESS_ANY)   307         virtual nirio_status open(
const std::string& interface_path);
   308         virtual void close(
void);
   319             uint32_t& maintenance,
   325             uint32_t& attrValue);
   329             const uint32_t value);
   331         virtual nirio_status peek(uint32_t offset, uint32_t& value);
   333         virtual nirio_status peek(uint32_t offset, uint64_t& value);
   335         virtual nirio_status poke(uint32_t offset,
const uint32_t& value);
   337         virtual nirio_status poke(uint32_t offset,
const uint64_t& value);
   340             uint32_t fifo_instance,
   361             uint32_t requested_depth,
   362             uint8_t requires_actuals,
   363             uint32_t& actual_depth,
   364             uint32_t& actual_size);
   368             uint32_t elements_requested,
   369             uint32_t scalar_type,
   374             uint32_t& elements_acquired,
   375             uint32_t& elements_remaining);
   379             uint32_t elements_to_grant);
   383             uint32_t elements_to_read,
   385             uint32_t buffer_datatype_width,
   386             uint32_t scalar_type,
   389             uint32_t& number_read,
   390             uint32_t& number_remaining);
   394             uint32_t elements_to_write,
   396             uint32_t buffer_datatype_width,
   397             uint32_t scalar_type,
   400             uint32_t& number_remaining);
   404             virtual void _close();
 Definition: niriok_proxy_impl_v2.h:212
Definition: niriok_proxy_impl_v2.h:256
int32_t status
Definition: niriok_proxy_impl_v2.h:288
int32_t status
Definition: niriok_proxy_impl_v2.h:84
uint32_t read
Definition: niriok_proxy_impl_v2.h:194
uint32_t offset
Definition: niriok_proxy_impl_v2.h:258
tAlignedU64 buf
Definition: niriok_proxy_impl_v2.h:201
int32_t status
Definition: niriok_proxy_impl_v2.h:104
uint32_t numberElements
Definition: niriok_proxy_impl_v2.h:187
Definition: niriok_proxy_impl_v2.h:298
int32_t status
Definition: niriok_proxy_impl_v2.h:292
Definition: niriok_proxy_impl_v2.h:114
nirio_fifo_data_type_t dataType
Definition: niriok_proxy_impl_v2.h:216
Definition: niriok_proxy_impl_v2.h:246
uint32_t retVal__
Definition: niriok_proxy_impl_v2.h:263
uint32_t channel
Definition: niriok_proxy_impl_v2.h:133
int32_t status
Definition: niriok_proxy_impl_v2.h:244
Definition: niriok_proxy_impl_v2.h:282
Definition: niriok_proxy_impl_v2.h:149
uint32_t channel
Definition: niriok_proxy_impl_v2.h:167
tAlignedU64 retVal__
Definition: niriok_proxy_impl_v2.h:253
tAlignedU64 elementsRemaining
Definition: niriok_proxy_impl_v2.h:225
int32_t nirio_i32_t
Definition: niriok_proxy.h:67
uint32_t channel
Definition: niriok_proxy_impl_v2.h:155
int32_t status
Definition: niriok_proxy_impl_v2.h:99
nirio_version_t
Definition: niriok_proxy.h:54
Definition: niriok_proxy_impl_v2.h:110
Definition: niriok_proxy_impl_v2.h:153
int32_t status
Definition: niriok_proxy_impl_v2.h:147
uint32_t value
Definition: niriok_proxy_impl_v2.h:94
int32_t status
Definition: niriok_proxy_impl_v2.h:280
tAlignedU64 actualSize
Definition: niriok_proxy_impl_v2.h:162
int32_t status
Definition: niriok_proxy_impl_v2.h:254
int32_t status
Definition: niriok_proxy_impl_v2.h:274
Definition: niriok_proxy_impl_v2.h:272
tAlignedU64 requestedDepth
Definition: niriok_proxy_impl_v2.h:156
Definition: niriok_proxy_impl_v2.h:290
Definition: niriok_proxy_impl_v2.h:170
uint32_t channel
Definition: niriok_proxy_impl_v2.h:185
uint32_t nirio_u32_t
Definition: niriok_proxy.h:64
int32_t status
Definition: niriok_proxy_impl_v2.h:226
Definition: niriok_proxy_impl_v2.h:73
uint32_t offset
Definition: niriok_proxy_impl_v2.h:248
Definition: niriok_proxy.h:113
int32_t status
Definition: niriok_proxy_impl_v2.h:138
uint32_t baseAddress
Definition: niriok_proxy_impl_v2.h:134
Definition: niriok_proxy_impl_v2.h:106
int32_t status
Definition: niriok_proxy_impl_v2.h:157
Definition: niriok_proxy_impl_v2.h:238
int32_t status
Definition: niriok_proxy_impl_v2.h:190
tAlignedU64 value
Definition: niriok_proxy_impl_v2.h:269
tAlignedU64 buf
Definition: niriok_proxy_impl_v2.h:186
Definition: niriok_proxy_impl_v2.h:79
Definition: config.hpp:79
nirio_scalar_type_t
Definition: niriok_proxy.h:81
int32_t status
Definition: niriok_proxy_impl_v2.h:205
Definition: niriok_proxy_impl_v2.h:183
uint32_t channel
Definition: niriok_proxy_impl_v2.h:176
Definition: niriok_proxy_impl_v2.h:286
Definition: niriok_proxy_impl_v2.h:174
Definition: niriok_proxy_impl_v2.h:202
nirio_device_attribute32_t attribute
Definition: niriok_proxy_impl_v2.h:93
Definition: niriok_proxy_impl_v2.h:221
uint32_t attribute
Definition: niriok_proxy_impl_v2.h:146
Definition: niriok_proxy_impl_v2.h:140
Definition: niriok_proxy_impl_v2.h:165
Definition: niriok_proxy_impl_v2.h:131
uint32_t timeout
Definition: niriok_proxy_impl_v2.h:218
int32_t status
Definition: niriok_proxy_impl_v2.h:116
int32_t status
Definition: niriok_proxy_impl_v2.h:172
uint32_t depthInSamples
Definition: niriok_proxy_impl_v2.h:135
int32_t status
Definition: niriok_proxy_impl_v2.h:236
Definition: nirio_driver_iface.h:130
int32_t status
Definition: niriok_proxy_impl_v2.h:270
int32_t nirio_status
Definition: status.h:30
uint32_t channel
Definition: niriok_proxy_impl_v2.h:200
Definition: niriok_proxy_impl_v2.h:242
int32_t status
Definition: niriok_proxy_impl_v2.h:284
uint32_t stringLen
Definition: niriok_proxy_impl_v2.h:103
int32_t status
Definition: niriok_proxy_impl_v2.h:240
Definition: niriok_proxy_impl_v2.h:234
Definition: niriok_proxy_impl_v2.h:101
uint32_t channel
Definition: niriok_proxy_impl_v2.h:230
nirio_i32_t integerWordLength
Definition: niriok_proxy_impl_v2.h:76
uint32_t timeout
Definition: niriok_proxy_impl_v2.h:189
uint64_t tAlignedU64
Definition: niriok_proxy_impl_v2.h:30
int32_t status
Definition: niriok_proxy_impl_v2.h:142
Definition: niriok_proxy_impl_v2.h:261
int32_t status
Definition: niriok_proxy_impl_v2.h:168
int32_t status
Definition: niriok_proxy_impl_v2.h:210
Definition: niriok_proxy.h:146
int32_t status
Definition: niriok_proxy_impl_v2.h:177
tAlignedU64 actualDepth
Definition: niriok_proxy_impl_v2.h:161
uint32_t timeout
Definition: niriok_proxy_impl_v2.h:204
uint32_t offset
Definition: niriok_proxy_impl_v2.h:268
Definition: niriok_proxy_impl_v2.h:144
Definition: niriok_proxy_impl_v2.h:276
uint32_t value
Definition: niriok_proxy_impl_v2.h:279
int32_t status
Definition: niriok_proxy_impl_v2.h:181
Definition: niriok_proxy_impl_v2.h:198
int32_t status
Definition: niriok_proxy_impl_v2.h:151
Definition: niriok_proxy_impl_v2.h:203
int32_t status
Definition: niriok_proxy_impl_v2.h:89
Definition: niriok_proxy_impl_v2.h:231
int32_t status
Definition: niriok_proxy_impl_v2.h:264
Definition: niriok_proxy_impl_v2.h:81
Definition: niriok_proxy_impl_v2.h:91
Definition: niriok_proxy_impl_v2.h:192
Definition: niriok_proxy_impl_v2.h:251
Definition: niriok_proxy_impl_v2.h:266
uint32_t version
Definition: niriok_proxy_impl_v2.h:137
nirio_u32_t bitWidth
Definition: niriok_proxy_impl_v2.h:75
int32_t status
Definition: niriok_proxy_impl_v2.h:232
int32_t status
Definition: niriok_proxy_impl_v2.h:249
Definition: niriok_proxy_impl_v2.h:228
uint32_t channel
Definition: niriok_proxy_impl_v2.h:214
Definition: niriok_proxy_impl_v2.h:223
uint32_t retVal__
Definition: niriok_proxy_impl_v2.h:88
Definition: niriok_proxy_impl_v2.h:179
tAlignedU64 elementsAcquired
Definition: niriok_proxy_impl_v2.h:224
tAlignedU64 elementsRequested
Definition: niriok_proxy_impl_v2.h:215
Definition: niriok_proxy_impl_v2.h:83
int32_t status
Definition: niriok_proxy_impl_v2.h:163
int32_t status
Definition: niriok_proxy_impl_v2.h:108
int32_t status
Definition: niriok_proxy_impl_v2.h:196
uint32_t remaining
Definition: niriok_proxy_impl_v2.h:209
nirio_scalar_type_t scalarType
Definition: niriok_proxy_impl_v2.h:74
int32_t status
Definition: niriok_proxy_impl_v2.h:219
Definition: niriok_proxy_impl_v2.h:159
Definition: niriok_proxy_impl_v2.h:207
int32_t status
Definition: niriok_proxy_impl_v2.h:95
uint32_t offset
Definition: niriok_proxy_impl_v2.h:278
Definition: niriok_proxy_impl_v2.h:86
Definition: niriok_proxy_impl_v2.h:97
Definition: niriok_proxy_impl_v2.h:188
uint32_t remaining
Definition: niriok_proxy_impl_v2.h:195
int32_t status
Definition: niriok_proxy_impl_v2.h:112
Definition: niriok_proxy_impl_v2.h:136
Definition: niriok_proxy.h:69
int32_t status
Definition: niriok_proxy_impl_v2.h:300
int32_t status
Definition: niriok_proxy_impl_v2.h:259
Definition: niriok_proxy_impl_v2.h:294
int32_t status
Definition: niriok_proxy_impl_v2.h:296
bool output
Definition: niriok_proxy_impl_v2.h:217
