uhd::niusrprio::niriok_proxy Member List
This is the complete list of members for uhd::niusrprio::niriok_proxy, including all inherited members.
_close()=0uhd::niusrprio::niriok_proxyprotectedpure virtual
_device_handleuhd::niusrprio::niriok_proxyprotected
_interface_numuhd::niusrprio::niriok_proxyprotected
_rio_quirksuhd::niusrprio::niriok_proxyprotected
_synchronizationuhd::niusrprio::niriok_proxyprotectedstatic
add_fifo_resource(const nirio_fifo_info_t &fifo_info)=0uhd::niusrprio::niriok_proxypure virtual
close(void)=0uhd::niusrprio::niriok_proxypure virtual
configure_fifo(uint32_t channel, uint32_t requested_depth, uint8_t requires_actuals, uint32_t &actual_depth, uint32_t &actual_size)=0uhd::niusrprio::niriok_proxypure virtual
get_attribute(const nirio_device_attribute32_t attribute, uint32_t &attrValue)=0uhd::niusrprio::niriok_proxypure virtual
get_cached_session(uint32_t &session)=0uhd::niusrprio::niriok_proxypure virtual
get_interface_num()uhd::niusrprio::niriok_proxyinline
get_rio_quirks()uhd::niusrprio::niriok_proxyinline
get_version(nirio_version_t type, uint32_t &major, uint32_t &upgrade, uint32_t &maintenance, char &phase, uint32_t &build)=0uhd::niusrprio::niriok_proxypure virtual
grant_fifo(uint32_t channel, uint32_t elements_to_grant)=0uhd::niusrprio::niriok_proxypure virtual
make_and_open(const std::string &interface_path)uhd::niusrprio::niriok_proxystatic
map_fifo_memory(uint32_t fifo_instance, size_t size, nirio_driver_iface::rio_mmap_t &map)=0uhd::niusrprio::niriok_proxypure virtual
niriok_proxy()uhd::niusrprio::niriok_proxy
open(const std::string &interface_path)=0uhd::niusrprio::niriok_proxypure virtual
peek(uint32_t offset, uint32_t &value)=0uhd::niusrprio::niriok_proxypure virtual
peek(uint32_t offset, uint64_t &value)=0uhd::niusrprio::niriok_proxypure virtual
poke(uint32_t offset, const uint32_t &value)=0uhd::niusrprio::niriok_proxypure virtual
poke(uint32_t offset, const uint64_t &value)=0uhd::niusrprio::niriok_proxypure virtual
read_fifo(uint32_t channel, uint32_t elements_to_read, void *buffer, uint32_t buffer_datatype_width, uint32_t scalar_type, uint32_t bit_width, uint32_t timeout, uint32_t &number_read, uint32_t &number_remaining)=0uhd::niusrprio::niriok_proxypure virtual
reset()=0uhd::niusrprio::niriok_proxypure virtual
set_attribute(const nirio_device_attribute32_t attribute, const uint32_t value)=0uhd::niusrprio::niriok_proxypure virtual
set_device_config()=0uhd::niusrprio::niriok_proxypure virtual
sptr typedefuhd::niusrprio::niriok_proxy
start_fifo(uint32_t channel)=0uhd::niusrprio::niriok_proxypure virtual
stop_all_fifos()=0uhd::niusrprio::niriok_proxypure virtual
stop_fifo(uint32_t channel)=0uhd::niusrprio::niriok_proxypure virtual
unmap_fifo_memory(nirio_driver_iface::rio_mmap_t &map)=0uhd::niusrprio::niriok_proxypure virtual
wait_on_fifo(uint32_t channel, uint32_t elements_requested, uint32_t scalar_type, uint32_t bit_width, uint32_t timeout, uint8_t output, void *&data_pointer, uint32_t &elements_acquired, uint32_t &elements_remaining)=0uhd::niusrprio::niriok_proxypure virtual
write_fifo(uint32_t channel, uint32_t elements_to_write, void *buffer, uint32_t buffer_datatype_width, uint32_t scalar_type, uint32_t bit_width, uint32_t timeout, uint32_t &number_remaining)=0uhd::niusrprio::niriok_proxypure virtual
~niriok_proxy()uhd::niusrprio::niriok_proxyvirtual
