18 #ifndef INCLUDED_RPC_COMMON_HPP    19 #define INCLUDED_RPC_COMMON_HPP    21 #define USE_BINARY_ARCHIVE 0    27 #if (USE_BINARY_ARCHIVE)    28     #include <boost/archive/binary_oarchive.hpp>    29     #include <boost/archive/binary_iarchive.hpp>    31     #include <boost/archive/text_oarchive.hpp>    32     #include <boost/archive/text_iarchive.hpp>    35 namespace uhd {
namespace usrprio_rpc {
    41 #define build_client_id(host_id, process_id) \    42     ((static_cast<boost::uint64_t>(host_id) << 32) | static_cast<boost::uint64_t>(process_id))    43 #define get_process_id_from_client_id(client_id) \    44     (static_cast<boost::int32_t>(client_id))    45 #define get_host_id_from_client_id(client_id) \    46     (static_cast<boost::uint32_t>(client_id >> 32))    80     template<
typename data_t>
    81     void push(
const data_t& d) {
    85     template<
typename data_t>
    91     void store(std::vector<char>& data)
 const {
    92         const std::string& str = _stream.str();
    93         data.resize(str.length());
    94         data.assign((
char*)str.c_str(), ((
char*)str.c_str()) + str.length());
    98     std::ostringstream              _stream;
    99 #if (USE_BINARY_ARCHIVE)   100     boost::archive::binary_oarchive _archive;
   102     boost::archive::text_oarchive   _archive;
   111     template<
typename data_t>
   113         if (_archive) (*_archive) >> d;
   116     template<
typename data_t>
   122     void load(
const std::vector<char>& data) {
   123         _stream.str(std::string(data.begin(), data.end()));
   124 #if (USE_BINARY_ARCHIVE)   125         _archive.reset(
new boost::archive::binary_iarchive(_stream, boost::archive::no_header));
   127         _archive.reset(
new boost::archive::text_iarchive(_stream, boost::archive::no_header));
   132     std::istringstream                                  _stream;
   133 #if (USE_BINARY_ARCHIVE)   134     boost::scoped_ptr<boost::archive::binary_iarchive>  _archive;
   136     boost::scoped_ptr<boost::archive::text_iarchive>    _archive;
   143     #if (USE_BINARY_ARCHIVE)   144         typedef boost::archive::binary_oarchive archive_t;
   146         typedef boost::archive::text_oarchive   archive_t;
   148         std::ostringstream stream;
   149         archive_t dummy_archive(stream, boost::archive::no_header);
   150         return static_cast<boost::int32_t
>(dummy_archive.get_library_version());
   156 #undef USE_BINARY_ARCHIVE Definition: rpc_common.hpp:76
void pull(data_t &d) const
Definition: rpc_common.hpp:112
void push(const data_t &d)
Definition: rpc_common.hpp:81
static boost::int32_t get_version()
Definition: rpc_common.hpp:142
Definition: rpc_common.hpp:107
client_id_t client_id
Definition: rpc_common.hpp:53
Definition: rpc_common.hpp:49
boost::int32_t boost_archive_version
Definition: rpc_common.hpp:52
func_args_header_t header
Definition: rpc_common.hpp:71
void store(std::vector< char > &data) const
Definition: rpc_common.hpp:91
void load(const std::vector< char > &data)
Definition: rpc_common.hpp:122
boost::uint32_t version
Definition: rpc_common.hpp:50
func_args_writer_t()
Definition: rpc_common.hpp:78
boost::uint64_t client_id_t
Definition: rpc_common.hpp:39
boost::int32_t func_id_t
Definition: rpc_common.hpp:38
boost::uint32_t oldest_comp_version
Definition: rpc_common.hpp:51
Definition: rpc_common.hpp:140
std::vector< char > data
Definition: rpc_common.hpp:72
func_args_reader_t()
Definition: rpc_common.hpp:109
Definition: rpc_common.hpp:69
