math.hpp
18 #ifndef INCLUDED_UHD_UTILS_MATH_HPP
19 #define INCLUDED_UHD_UTILS_MATH_HPP
23 #include <boost/numeric/conversion/bounds.hpp>
25
26 namespace uhd {
27
32 namespace math {
33
44  static const boost::int32_t BOOST_INT32_MAX = boost::numeric::bounds<boost::int32_t>::highest();
45  static const boost::int32_t BOOST_INT32_MIN = boost::numeric::bounds<boost::int32_t>::lowest();
46
63  static const float SINGLE_PRECISION_EPSILON = 1.19e-7f;
64  static const double DOUBLE_PRECISION_EPSILON = 2.22e-16;
65
66 namespace fp_compare {
67
81  template<typename float_t> class fp_compare_epsilon {
82  public:
83  UHD_INLINE fp_compare_epsilon(float_t value);
84  UHD_INLINE fp_compare_epsilon(float_t value, float_t epsilon);
87  UHD_INLINE void operator=(const fp_compare_epsilon& copy);
88
89  float_t _value;
90  float_t _epsilon;
91  };
92
93  /* A Note on Floating Point Equality with Epsilons
94  *
95  * There are obviously a lot of strategies for defining floating point
96  * equality, and in the end it all comes down to the domain at hand. UHD's
97  * floating-point-with-epsilon comparison algorithm is based on the method
98  * presented in Knuth's "The Art of Computer Science" called "very close
99  * with tolerance epsilon".
100  *
101  * [(|u - v| / |u|) <= e] && [(|u - v| / |v|) <= e]
102  *
103  * UHD's modification to this algorithm is using the denominator's epsilon
104  * value (since each float_t object has its own epsilon) for each
105  * comparison.
106  */
107
108  template<typename float_t> UHD_INLINE
110  template<typename float_t> UHD_INLINE
112  template<typename float_t> UHD_INLINE
113  bool operator<(fp_compare_epsilon<float_t> lhs, fp_compare_epsilon<float_t> rhs);
114  template<typename float_t> UHD_INLINE
115  bool operator<=(fp_compare_epsilon<float_t> lhs, fp_compare_epsilon<float_t> rhs);
116  template<typename float_t> UHD_INLINE
118  template<typename float_t> UHD_INLINE
120
121  /* If these operators are used with floats, we rely on type promotion to
122  * double. */
123  template<typename float_t> UHD_INLINE
124  bool operator==(fp_compare_epsilon<float_t> lhs, double rhs);
125  template<typename float_t> UHD_INLINE
126  bool operator!=(fp_compare_epsilon<float_t> lhs, double rhs);
127  template<typename float_t> UHD_INLINE
128  bool operator<(fp_compare_epsilon<float_t> lhs, double rhs);
129  template<typename float_t> UHD_INLINE
130  bool operator<=(fp_compare_epsilon<float_t> lhs, double rhs);
131  template<typename float_t> UHD_INLINE
132  bool operator>(fp_compare_epsilon<float_t> lhs, double rhs);
133  template<typename float_t> UHD_INLINE
134  bool operator>=(fp_compare_epsilon<float_t> lhs, double rhs);
135
136  template<typename float_t> UHD_INLINE
137  bool operator==(double lhs, fp_compare_epsilon<float_t> rhs);
138  template<typename float_t> UHD_INLINE
139  bool operator!=(double lhs, fp_compare_epsilon<float_t> rhs);
140  template<typename float_t> UHD_INLINE
141  bool operator<(double lhs, fp_compare_epsilon<float_t> rhs);
142  template<typename float_t> UHD_INLINE
143  bool operator<=(double lhs, fp_compare_epsilon<float_t> rhs);
144  template<typename float_t> UHD_INLINE
145  bool operator>(double lhs, fp_compare_epsilon<float_t> rhs);
146  template<typename float_t> UHD_INLINE
147  bool operator>=(double lhs, fp_compare_epsilon<float_t> rhs);
148
149 } // namespace fp_compare
150
151
158  static const float SINGLE_PRECISION_DELTA = 1e-3f;
159  static const double DOUBLE_PRECISION_DELTA = 1e-5;
160
162  static const double FREQ_COMPARISON_DELTA_HZ = 0.1;
163
164
165 namespace fp_compare {
166
180  template<typename float_t> class fp_compare_delta {
181  public:
182  UHD_INLINE fp_compare_delta(float_t value);
183  UHD_INLINE fp_compare_delta(float_t value, float_t delta);
184  UHD_INLINE fp_compare_delta(const fp_compare_delta<float_t>& copy);
185  UHD_INLINE ~fp_compare_delta();
186  UHD_INLINE void operator=(const fp_compare_delta& copy);
187
188  float_t _value;
189  float_t _delta;
190  };
191
192  template<typename float_t> UHD_INLINE
194  template<typename float_t> UHD_INLINE
196  template<typename float_t> UHD_INLINE
197  bool operator<(fp_compare_delta<float_t> lhs, fp_compare_delta<float_t> rhs);
198  template<typename float_t> UHD_INLINE
199  bool operator<=(fp_compare_delta<float_t> lhs, fp_compare_delta<float_t> rhs);
200  template<typename float_t> UHD_INLINE
202  template<typename float_t> UHD_INLINE
204
205  /* If these operators are used with floats, we rely on type promotion to
206  * double. */
207  template<typename float_t> UHD_INLINE
208  bool operator==(fp_compare_delta<float_t> lhs, double rhs);
209  template<typename float_t> UHD_INLINE
210  bool operator!=(fp_compare_delta<float_t> lhs, double rhs);
211  template<typename float_t> UHD_INLINE
212  bool operator<(fp_compare_delta<float_t> lhs, double rhs);
213  template<typename float_t> UHD_INLINE
214  bool operator<=(fp_compare_delta<float_t> lhs, double rhs);
215  template<typename float_t> UHD_INLINE
216  bool operator>(fp_compare_delta<float_t> lhs, double rhs);
217  template<typename float_t> UHD_INLINE
218  bool operator>=(fp_compare_delta<float_t> lhs, double rhs);
219
220  template<typename float_t> UHD_INLINE
221  bool operator==(double lhs, fp_compare_delta<float_t> rhs);
222  template<typename float_t> UHD_INLINE
223  bool operator!=(double lhs, fp_compare_delta<float_t> rhs);
224  template<typename float_t> UHD_INLINE
225  bool operator<(double lhs, fp_compare_delta<float_t> rhs);
226  template<typename float_t> UHD_INLINE
227  bool operator<=(double lhs, fp_compare_delta<float_t> rhs);
228  template<typename float_t> UHD_INLINE
229  bool operator>(double lhs, fp_compare_delta<float_t> rhs);
230  template<typename float_t> UHD_INLINE
231  bool operator>=(double lhs, fp_compare_delta<float_t> rhs);
232
233 } // namespace fp_compare
234
235  UHD_INLINE bool frequencies_are_equal(double lhs, double rhs) {
236  return(fp_compare::fp_compare_delta<double>(lhs, FREQ_COMPARISON_DELTA_HZ)
237  == fp_compare::fp_compare_delta<double>(rhs, FREQ_COMPARISON_DELTA_HZ));
238  }
239
240 } // namespace math
241 } // namespace uhd
242
243 #include "fp_compare_epsilon.ipp"
244 #include "fp_compare_delta.ipp"
245
246 #endif /* INCLUDED_UHD_UTILS_MATH_HPP */
Definition: math.hpp:235
float_t _value
Definition: math.hpp:188
UHD_INLINE bool operator>=(fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs)
Definition: fp_compare_delta.ipp:97
UHD_INLINE bool operator>(fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs)
Definition: fp_compare_delta.ipp:91
Definition: fp_compare_delta.ipp:75
float_t _delta
Definition: math.hpp:189
float_t _epsilon
Definition: math.hpp:90
#define UHD_INLINE
Definition: config.hpp:69
UHD_INLINE ~fp_compare_epsilon()
Definition: fp_compare_epsilon.ipp:54
float_t _value
Definition: math.hpp:89
UHD_INLINE void operator=(const fp_compare_epsilon &copy)
Definition: fp_compare_epsilon.ipp:58
UHD_INLINE bool operator==(fp_compare_delta< float_t > lhs, fp_compare_delta< float_t > rhs)
Definition: fp_compare_delta.ipp:69
