USRP Hardware Driver and USRP Manual  Version: 003.008.003-0-g87dfdc3c
udp_simple.hpp
2 // Copyright 2010,2014 Ettus Research LLC
18 #ifndef INCLUDED_UHD_TRANSPORT_UDP_SIMPLE_HPP
19 #define INCLUDED_UHD_TRANSPORT_UDP_SIMPLE_HPP
22 #include <uhd/types/serial.hpp>
23 #include <boost/asio/buffer.hpp>
25 #include <boost/shared_ptr.hpp>
26
27 namespace uhd{ namespace transport{
28
29 class UHD_API udp_simple : boost::noncopyable{
30 public:
31  typedef boost::shared_ptr<udp_simple> sptr;
32
33  virtual ~udp_simple(void) = 0;
34
36  static const size_t mtu = 1500 - 20 - 8; //default ipv4 mtu - ipv4 header - udp header
37
51  static sptr make_connected(const std::string &addr, const std::string &port);
52
65  static sptr make_broadcast(const std::string &addr, const std::string &port);
66
72  static uart_iface::sptr make_uart(sptr udp);
73
80  virtual size_t send(const boost::asio::const_buffer &buff) = 0;
81
89  virtual size_t recv(const boost::asio::mutable_buffer &buff, double timeout = 0.1) = 0;
90
95  virtual std::string get_recv_addr(void) = 0;
96 };
97
98 }} //namespace
99
100 #endif /* INCLUDED_UHD_TRANSPORT_UDP_SIMPLE_HPP */
Definition: udp_simple.hpp:29
Definition: config.hpp:79
size_t send(const send_buffs_type &buffs, size_t nsamps_per_buff, const tx_metadata_t &metadata, const io_type_t &io_type, send_mode_t send_mode, double timeout=0.1)
Definition: device_deprecated.ipp:74
Definition: serial.hpp:190
boost::shared_ptr< udp_simple > sptr
Definition: udp_simple.hpp:31
size_t recv(const recv_buffs_type &buffs, size_t nsamps_per_buff, rx_metadata_t &metadata, const io_type_t &io_type, recv_mode_t recv_mode, double timeout=0.1)
Definition: device_deprecated.ipp:130
