multi_usrp.hpp
18 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP
19 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP
21 //define API capabilities for compile time detection of new features
22 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API
23 #define UHD_USRP_MULTI_USRP_GET_RATES_API
24 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
25 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
26 #define UHD_USRP_MULTI_USRP_BW_RANGE_API
27 #define UHD_USRP_MULTI_USRP_USER_REGS_API
28 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
29
30 #include <uhd/config.hpp>
31 #include <uhd/device.hpp>
32 #include <uhd/deprecated.hpp>
33 #include <uhd/types/ranges.hpp>
34 #include <uhd/types/stream_cmd.hpp>
37 #include <uhd/types/sensors.hpp>
38 #include <uhd/usrp/subdev_spec.hpp>
40 #include <boost/shared_ptr.hpp>
41 #include <boost/utility.hpp>
42 #include <complex>
43 #include <string>
44 #include <vector>
45
46 namespace uhd{ namespace usrp{
47
94 class UHD_API multi_usrp : boost::noncopyable{
95 public:
96  typedef boost::shared_ptr<multi_usrp> sptr;
97
98  virtual ~multi_usrp(void) = 0;
99
101  static const size_t ALL_MBOARDS = size_t(~0);
102
104  static const size_t ALL_CHANS = size_t(~0);
105
107  static const std::string ALL_GAINS;
108
114  static sptr make(const device_addr_t &dev_addr);
115
121  virtual device::sptr get_device(void) = 0;
122
124  virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args) = 0;
125
127  virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args) = 0;
128
136  virtual dict<std::string, std::string> get_usrp_rx_info(size_t chan = 0) = 0;
137
145  virtual dict<std::string, std::string> get_usrp_tx_info(size_t chan = 0) = 0;
146
147  /*******************************************************************
148  * Mboard methods
149  ******************************************************************/
150
161  virtual void set_master_clock_rate(double rate, size_t mboard = ALL_MBOARDS) = 0;
162
168  virtual double get_master_clock_rate(size_t mboard = 0) = 0;
169
174  virtual std::string get_pp_string(void) = 0;
175
181  virtual std::string get_mboard_name(size_t mboard = 0) = 0;
182
188  virtual time_spec_t get_time_now(size_t mboard = 0) = 0;
189
195  virtual time_spec_t get_time_last_pps(size_t mboard = 0) = 0;
196
208  virtual void set_time_now(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
209
222  virtual void set_time_next_pps(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
223
239  virtual void set_time_unknown_pps(const time_spec_t &time_spec) = 0;
240
247  virtual bool get_time_synchronized(void) = 0;
248
259  virtual void set_command_time(const uhd::time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
260
266  virtual void clear_command_time(size_t mboard = ALL_MBOARDS) = 0;
267
280  virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan = ALL_CHANS) = 0;
281
290  virtual void set_clock_config(const clock_config_t &clock_config, size_t mboard = ALL_MBOARDS) = 0;
291
300  virtual void set_time_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
301
307  virtual std::string get_time_source(const size_t mboard) = 0;
308
314  virtual std::vector<std::string> get_time_sources(const size_t mboard) = 0;
315
323  virtual void set_clock_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
324
330  virtual std::string get_clock_source(const size_t mboard) = 0;
331
337  virtual std::vector<std::string> get_clock_sources(const size_t mboard) = 0;
338
347  virtual void set_clock_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
348
357  virtual void set_time_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
358
362  virtual size_t get_num_mboards(void) = 0;
363
370  virtual sensor_value_t get_mboard_sensor(const std::string &name, size_t mboard = 0) = 0;
371
377  virtual std::vector<std::string> get_mboard_sensor_names(size_t mboard = 0) = 0;
378
386  virtual void set_user_register(const boost::uint8_t addr, const boost::uint32_t data, size_t mboard = ALL_MBOARDS) = 0;
387
388  /*******************************************************************
389  * RX methods
390  ******************************************************************/
399  virtual void set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
400
406  virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard = 0) = 0;
407
413  virtual size_t get_rx_num_channels(void) = 0;
414
420  virtual std::string get_rx_subdev_name(size_t chan = 0) = 0;
421
427  virtual void set_rx_rate(double rate, size_t chan = ALL_CHANS) = 0;
428
434  virtual double get_rx_rate(size_t chan = 0) = 0;
435
441  virtual meta_range_t get_rx_rates(size_t chan = 0) = 0;
442
449  virtual tune_result_t set_rx_freq(
450  const tune_request_t &tune_request, size_t chan = 0
451  ) = 0;
452
458  virtual double get_rx_freq(size_t chan = 0) = 0;
459
469  virtual freq_range_t get_rx_freq_range(size_t chan = 0) = 0;
470
476  virtual freq_range_t get_fe_rx_freq_range(size_t chan = 0) = 0;
477
485  virtual void set_rx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
486
488  void set_rx_gain(double gain, size_t chan = 0){
489  return this->set_rx_gain(gain, ALL_GAINS, chan);
490  }
491
499  virtual double get_rx_gain(const std::string &name, size_t chan = 0) = 0;
500
502  double get_rx_gain(size_t chan = 0){
503  return this->get_rx_gain(ALL_GAINS, chan);
504  }
505
513  virtual gain_range_t get_rx_gain_range(const std::string &name, size_t chan = 0) = 0;
514
516  gain_range_t get_rx_gain_range(size_t chan = 0){
517  return this->get_rx_gain_range(ALL_GAINS, chan);
518  }
519
526  virtual std::vector<std::string> get_rx_gain_names(size_t chan = 0) = 0;
527
533  virtual void set_rx_antenna(const std::string &ant, size_t chan = 0) = 0;
534
540  virtual std::string get_rx_antenna(size_t chan = 0) = 0;
541
547  virtual std::vector<std::string> get_rx_antennas(size_t chan = 0) = 0;
548
554  virtual void set_rx_bandwidth(double bandwidth, size_t chan = 0) = 0;
555
561  virtual double get_rx_bandwidth(size_t chan = 0) = 0;
562
568  virtual meta_range_t get_rx_bandwidth_range(size_t chan = 0) = 0;
569
577  virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan = 0) = 0;
578
585  virtual sensor_value_t get_rx_sensor(const std::string &name, size_t chan = 0) = 0;
586
592  virtual std::vector<std::string> get_rx_sensor_names(size_t chan = 0) = 0;
593
606  virtual void set_rx_dc_offset(const bool enb, size_t chan = ALL_CHANS) = 0;
607
615  virtual void set_rx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
616
624  virtual void set_rx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
625
626  /*******************************************************************
627  * TX methods
628  ******************************************************************/
637  virtual void set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
638
644  virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard = 0) = 0;
645
651  virtual size_t get_tx_num_channels(void) = 0;
652
658  virtual std::string get_tx_subdev_name(size_t chan = 0) = 0;
659
665  virtual void set_tx_rate(double rate, size_t chan = ALL_CHANS) = 0;
666
672  virtual double get_tx_rate(size_t chan = 0) = 0;
673
679  virtual meta_range_t get_tx_rates(size_t chan = 0) = 0;
680
687  virtual tune_result_t set_tx_freq(
688  const tune_request_t &tune_request, size_t chan = 0
689  ) = 0;
690
696  virtual double get_tx_freq(size_t chan = 0) = 0;
697
707  virtual freq_range_t get_tx_freq_range(size_t chan = 0) = 0;
708
714  virtual freq_range_t get_fe_tx_freq_range(size_t chan = 0) = 0;
715
723  virtual void set_tx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
724
726  void set_tx_gain(double gain, size_t chan = 0){
727  return this->set_tx_gain(gain, ALL_GAINS, chan);
728  }
729
737  virtual double get_tx_gain(const std::string &name, size_t chan = 0) = 0;
738
740  double get_tx_gain(size_t chan = 0){
741  return this->get_tx_gain(ALL_GAINS, chan);
742  }
743
751  virtual gain_range_t get_tx_gain_range(const std::string &name, size_t chan = 0) = 0;
752
754  gain_range_t get_tx_gain_range(size_t chan = 0){
755  return this->get_tx_gain_range(ALL_GAINS, chan);
756  }
757
764  virtual std::vector<std::string> get_tx_gain_names(size_t chan = 0) = 0;
765
771  virtual void set_tx_antenna(const std::string &ant, size_t chan = 0) = 0;
772
778  virtual std::string get_tx_antenna(size_t chan = 0) = 0;
779
785  virtual std::vector<std::string> get_tx_antennas(size_t chan = 0) = 0;
786
792  virtual void set_tx_bandwidth(double bandwidth, size_t chan = 0) = 0;
793
799  virtual double get_tx_bandwidth(size_t chan = 0) = 0;
800
806  virtual meta_range_t get_tx_bandwidth_range(size_t chan = 0) = 0;
807
815  virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan = 0) = 0;
816
823  virtual sensor_value_t get_tx_sensor(const std::string &name, size_t chan = 0) = 0;
824
830  virtual std::vector<std::string> get_tx_sensor_names(size_t chan = 0) = 0;
831
838  virtual void set_tx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
839
847  virtual void set_tx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
848
849  /*******************************************************************
850  * GPIO methods
851  ******************************************************************/
852
858  virtual std::vector<std::string> get_gpio_banks(const size_t mboard) = 0;
859
876  virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const boost::uint32_t value, const boost::uint32_t mask = 0xffffffff, const size_t mboard = 0) = 0;
877
894  virtual boost::uint32_t get_gpio_attr(const std::string &bank, const std::string &attr, const size_t mboard = 0) = 0;
895
896 };
897
898 }}
899
900 #endif /* INCLUDED_UHD_USRP_MULTI_USRP_HPP */
Definition: multi_usrp.hpp:516
Definition: stream_cmd.hpp:46
Definition: tune_result.hpp:29
Definition: multi_usrp.hpp:740
Definition: multi_usrp.hpp:726
Definition: time_spec.hpp:39
Definition: device.hpp:41
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:96
Definition: multi_usrp.hpp:502
Definition: tune_request.hpp:33
Definition: stream.hpp:184
A wildcard gain element name.
Definition: multi_usrp.hpp:107
Definition: config.hpp:79
Definition: sensors.hpp:38
Definition: multi_usrp.hpp:94
Definition: stream.hpp:57
Definition: multi_usrp.hpp:488
Definition: ranges.hpp:68
Definition: stream.hpp:256
Definition: multi_usrp.hpp:754
