This application note describes the use of the board-mounted GPS Disciplined OCXO, as used with the USRP X300/X310. For information regarding the GPSDO that is compatible with the USRP N2xx or E1xx, please see Internal GPSDO (USRP-N2x0/E1X0 Models).
Phase noise:
| Offset | OCXO Phase noise power |
| 1Hz | -75dBc/Hz |
| 10Hz | -110dBc/Hz |
| 100Hz | -132dBc/Hz |
| 1kHz | -142dBc/Hz |
| 10kHz | -145dBc/Hz |
| 100kHz | -150dBc/Hz |
Antenna Types:
To install the GPSDO, you must insert it into the slot on the board near the 10 MHz Reference SMA. Keep in mind that the two sides of the GPSDO have a different number of pins. When inserting the GPSDO, make sure to press down firmly and evenly. When turning on the USRP X3x0 device, a green LED should illuminate on the GPSDO. This signifies that the unit has successfully been placed.
By default, if a GPSDO is detected at startup, the USRP will be configured to use it as a frequency and time reference. The internal VITA timestamp will be initialized to the GPS time, and the internal oscillator will be phase-locked to the 10MHz GPSDO reference. If the GPSDO is not locked to satellites, the VITA time will not be initialized.
