USRP B2x0 Series
Comparative features list - B200/B210
  • Hardware Capabilities:
    • Integrated RF frontend (70 MHz - 6 GHz)
    • Configurable clock rate
    • Variable analog bandwidth (200 kHz - 56 MHz)
    • Internal GPSDO option (see Internal GPSDO Application Notes (USRP-B2x0 Models) for details)
    • B210 Only:
      • MICTOR Debug Connector
      • JTAG Connector
    • Revision 6 with GPIO header
  • FPGA Capabilities:
    • Timed commands in FPGA
    • Timed sampling in FPGA
Specify a Non-standard Image
UHD software will automatically select the USRP B2X0 images from the installed images package. The image selection can be overridden with the fpga and fw device address parameters.
Example device address string representations to specify non-standard images:
fpga=usrp_b200_fpga.bin
-- OR --
fw=usrp_b200_fw.hex
Changing the Master Clock Rate
The master clock rate feeds the RF frontends and the DSP chains. Users may select non-default clock rates to acheive integer decimations or interpolations in the DSP chains. The default master clock rate defaults to 32 MHz, but can be set to any rate between 5 MHz and 61.44 MHz.
The user can set the master clock rate through the usrp API call uhd::usrp::multi_usrp::set_master_clock_rate(), or the clock rate can be set through the device arguments, which many applications take: :
uhd_usrp_probe --args="master_clock_rate=52e6"
RF Frontend Notes
The B200 features an integrated RF frontend.
Frontend tuning
The RF frontend has individually tunable receive and transmit chains. On the B200, there is one transmit and one receive RF frontend. On the B210, both transmit and receive can be used in a MIMO configuration. For the MIMO case, both receive frontends share the RX LO, and both transmit frontends share the TX LO. Each LO is tunable between 50 MHz and 6 GHz.
Frontend gain
All frontends have individual analog gain controls. The receive frontends have 73 dB of available gain; and the transmit frontends have 89.5 dB of available gain. Gain settings are application specific, but it is recommended that users consider using at least half of the available gain to get reasonable dynamic range.
Frontend bandwidth
Reference
Indicators
Below is a table of the LED indicators and their meanings:
Component IDDescriptionDetails
LED600 Power Indicator off = no power applied
red = power applied (external or USB)
LED800 Channel 2 RX2 Activity off = no power applied
green = receiving
LED801 Channel 2 TX/RX Activity off = no activity
green = receiving
red = transmitting
orange = switching between transmitting and receiving
LED802 Channel 1 TX/RX Activity off = no activity green = receiving
red = transmitting
LED803 Channel 1 RX2 Activity off = no power applied
green = receiving
LED100 GPS lock indicator off = no lock
green = lock
TX LED indicators are on when transimitting data and off when no samples are available to transmit. RX LED indicators are on when sending samples to the host and off when unable to do so. This means that TX/RX activity LED indicators will blink off in a temporary transmit underflow or receive overflow condition, indicating that the host is not sending or receiving samples fast enough. The host will be notified of the condition and output a "U" or "O" as well.
Connections
Below is a table showing the external connections and respective power information:
Component ID Description Details
J601 External Power 6 V
3 A
J701 USB Connector USB 3.0
J104 External PPS Input 1.8 V - 5 V
J101 GPS Antenna GPSDO will supply nominal voltage to antenna.
J100 External 10 MHz Input +15 dBm max</td
J800 RF B: TX/RX TX power +20dBm max
RX power -15dBm max
J802 RF B: RX2 RX power -15dBm max
J803 RF A: RX2 RX power -15dBm max
J801 RF A: TX/RX TX power +20dBm max
RX power -15dBm max
On-Board Connectors and Switches
Below is a table showing the on-board connectors and switches:
J5021 Mictor Connector Interface to FPGA for I/O and inspection.
J5031 JTAG Header Interface to FPGA for programming and debugging.
J5042 GPIO Header Header running to the FPGA for GPIO purposes.
S700 FX3 Hard Reset Switch Resets the USB controller / System reset
U100 GPSDO socket Interface to GPS disciplined reference oscillator
1 Only on the B210
2 Only since rev. 6 (green board)
